Question about Garden
I found this power blower, i had it running for a week or 2. i saw that the primer bulb has been weathered i bought the bulb and it has not started.
  • 130 Answers
Check compresstion first if good.then check for fire if good then spray little startfluide in carb if ti starts rebuild carb if it dont start you have problem in blower some where like fire sparkplug timing on flywheel key take flywheel off check key.make sure kill switch wire is not shorting out somewhere.make sure magnet on flywheel is good.let me know if this helps you ok
Posted on Jul 25, 2009
After replacing primer bulb, engine hesitates and will not run full throttle
Make sure you connected the lines correctly. If this is a primer assy that has the 2 barbs on the back here is a picture of how the lines should be connected to it as well as the carburetor
Now if this is a primer bulb on top of the carburetor then disregard the previous answer because in this case, your carburetor needs the H needle adjusted. Go on you tube .com and type in how to adjust a 2 cycle carburetor. Many videos will appear.
Nov 21, 2015 | Garden
Diagram of fuel lines from tank to primer to carb and back to tank for a poulan 2050 chainsaw.
clip_image002.gifFuel components are onthe "Engine Assembly" & "Handle, Chassis, & BarAssembly" detail pages.
Replacement fuel lines can be found at yourlocal chainsaw seller/mechanic. They are different diameters.
Fuel Line Replacement
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Feb 21, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Poulan chainsaw primer bulb replacement
You can find replacement parts on amazon, here Amazon com poulan chainsaw chain parts. I hope this was helpful. Cheers
Mar 15, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Hi I have a PCN4545 Chainsaw have used it a lot this week sudenly lost power would only tick over Now it willnot run cleaned the carb etc.will only now run for a few seconds if I pump the primer bulb can...
Change your spark plug for a new one it sounds like it is gas fouled
Clean the air filter
Make sure your gas/oil mix is correct
You may have an air leak in the system
Mar 10, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Fuel lines have rotted off. need to replace then
Mr Tittle;
It isn't good but it's all there is.
What little fuel system system detail there is can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
If it is a 2375 WildThing find 2375LE Gas Saw Type ?. The last digit of your serial number should be a -1 or -2, the type.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The filtered hose from the fuel tank connects directly to the carburetor input connection.
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as the bulb reinflates).
  • The pressure side of the primer returns any excess fuel to the tank as it is depressed.
HTH
Lou
Oct 24, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
39cc McCulloch chain saw
The issue sounds just like a carburetor problem. I had a saw that did the same exact thing, and found that I hadn't been adjusting the carburetor properly for years. I managed to find the instructions on-line, and then it ran like a dream, just every time I store it, I have to go back through the motions again.
Let me know if you need adjustment guidance and I will see if I can dig up anything.
Oct 04, 2008 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Garden Logo
53 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
