Question about kawasaki Full Suspension Mountain Bike Men
Gas flowing out of overflow tube - kawasaki Full Suspension Mountain Bike Men
    Novelist:
  • 137 Answers
If there is any gas flowing out of a Mountain Bike you have serious problems.
In reality you have a Motorcycle, not a Mountain Bike.
It's almost surely a stuck float valve. Try banging on the float bowl with a rubber mallet, but not too hard. You should really take off the bowls and clean them out, then replace the float valve pins and check the floats for any holes or for sticking action. Sometimes the floats will stick open due to rust gunk or old gas gummed up in there. I use Sea Foam fuel additive to help keep the carb clean. You could try running a half bottle of that through a bit, but I'd start by getting that bugger unstuck first.
Posted on Jul 24, 2009
After engine is started fuel flows out of carb vent tube
Hi, Lou and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Carburetor is leaking gas out of overflow tube need help
http://www.instructables.com/answers/What-is-wrong-with-my-carburetor
gas pouring out of bowl vent hole and overflow tube on super Harley...
RM125 Carb keeps running fuel out overflow
Concours Owners GroupTM Sport touring at its finest SM
Dec 12, 2016 | Motorcycles
Why am I still getting fuel coming out of the over flow pipes ?
Hi, Nigel reset your float height to 21mm obviously thats not the problem and the other usual suspects are:
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have nice a day. xlch@mail.com
How to adjust the Float Height on Carburetor Metric Harley and Asian
My carb leaks fuel out of the overflow hose at the bottom of my carb
http://planetminis.com/forums/klx110-drz110-ttr90/180657-gas-coming-out-carb-overflow-tube.html
Mar 23, 2016 | Motorcycles
Gas leaking through overflow
Your carbs need cleaning and setting,, the needle and seats are what controls the flow of gas into the float bowls... the floats movement (up and down) regulate the movement (opening and closing) of the needle and seat
Dec 22, 2012 | 2007 Triumph Triumph Bonneville
2002 ttr 125 fuel leaking out overflow tube
Hi, Anonymous and the usual suspects are:
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
TTR125 dirtbike leaking gas from carburator overflow tube AR15 COM
TTR 125 Fuel Overflow Problem
YAMAHA TT R125 Owner Service Manual
OEM parts for Yamaha
YAMAHA TT R110E Owner Manual
Jul 21, 2012 | 2002 Yamaha TT-R 125
Gas flows out of overflow tube on the bottom of the carb. Re: KLR 250 Kawasaki year 2002
sounds like your carb float has stuck and letting the fuel overflow, remove float bowl or carb clean check if the float has a leak shake it and you will hear fuel inside , refit and check
Jan 16, 2010 | 2003 kawasaki KLR 250
When i turn the fuel on to start the bike gas pours out the clear tube that comes from the carb to under the bike some were is this line dis conected or broke or is it something more
it's probably just your overflow from the float. it doesn't connect to anything, it just let the fuel overflow come out when your float level is high. if you turn on the fuel petcock and it starts pouring out, your float needle is sticking. clean the carb and the float needle valve assembly and see what happens.
Dec 30, 2009 | 2003 Yamaha TT-R 125
Gas overflowing in carb. flowing out of the bottom tube
you might find that the needle isnt in properly check that first
Oct 24, 2009 | Yamaha YZ 125 Motorcycles
Gas leaking from hose that is under tank that is not for gas flow
is it an overflow from the carb? gas will only be in one of 2 tubes and they are the fuel line from the tank and the carb over flow. unless you have an electronic fuel pump then tubes go from tank to pump to carb. if its coming from the overflow then you are getting too much fuel into the carb float chamber. you may have a sticky float. thy getting some Berrymans B12 fuel additive and putting double the doseage in the tank. run engine til hot then leave it to stand overnight. this should break down any gum/varnish that has built up in the system
has this been in storage thru winter?
Apr 02, 2009 | 2001 Honda XR 250 R
Float hieght for 1984 IT 490
not sure of the exact height, but if you hold the carb level with fuel hose attached and pushing float up with finger, turn on petcok and slowly lower the float until it is just above horizontal. at this point, gas should start to flow out of the needle & seat.
if float turns off gas too soon, then engine will starve.
if float doesn't turn off gas, then it will flow out of the carb overflow tube.
Mar 14, 2009 | 1974 Yamaha DT 360
Gas Leak via Overflow
The usual culprit is a blocked vent tube. Verify it's open. The usual indicator is either a pressure release when you open the gas cap, or a vacuum "sucking" noise when opening it first thing in the morning. On a carb equipped bike, the carb overflow lines will leak, but in a fuel injected bike like yours, it'll be out the overflow vent. The next time it begins leaking, open the gas cap. It should stop immediately as pressure inside is released. Good luck.
Nov 20, 2008 | 2005 Ducati Monster 1000S
kawasaki Full Suspension Mountain Bike Men Logo
241 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
