Question about Cell Phones
W910i Problems..... Hi all, Ok, I have a W910i that has started playing up a few weeks ago (turning its self off mainly at the most inconvenient moments), I started reading up about how to fix it the last week i started getting a Charging error. I thought as the phone didn't appear to be charging properly the Wallcharger must be faulty so i bought a new one which didn't fix the problem, yesterday i was using my phone with 1/4 battery life when it turned off and i couldn't get it back on. Now when i put it on charge the red light comes on and there is a ticking noise coming from the ear speaker, i have also tried to plug it into my computer in an attempt to et some stuff off it but the computer doesn't recognize it (probably as its off) and this time the red light is on but there is a Buzzing through the ear speaker. I am now left in a situation where my phone is not working and the shop i got it from doesn't want to know making up excuses that because its 8months into a contract i'm trying to get a new phone out of them??? I did some reading up and it looks like my Firm wear needs upgrading but the problem is i can't tell if the battery is fully charged even though a mate charged it up in his phone and the SE web site Updater won't run past the ''Press C down and plug the USB cable in'' Part. So can anyone point me in the right direction?
Poulan Leaf Blower red hot muffler
you need to turn the Hi screw on the carb in 1/4 of a turn.
Jul 22, 2013 | Poulan Garden
Poulan Leaf Blower
you may need to turn the Hi screw on the carb in 1/4 of a turn. Make sure the gas and mix are fresh.
TV turns off by its self
U might have sleep timer on?Push the menu to see it have 30,60,90,120.If u don't ur tv have problems.Call for warenty repair,or return it were u purchase for an exchange.
Feb 07, 2010 | Insignia IS-LCDTV32 32 in. Television
Laptop shuts off and wireless messed up
Ok.. Seems like you have lot of issues. Lets deal with them one by one.
The over heating issue is common on many laptops especially while playing games. The simplest fix would be to update your BIOS. This will resolve the issue more often than not.
As for the remaining problems your chipset drivers are probably screwed which in turn have affected the graphics and wireless drivers. I would suggest that you re-install them all so that this issue can be resolved.
You can find all the drivers here
First update the bios, then the chipset driver followed by the grphics, wireless and any other stuff you want to.
Hope this helps,
Sai.
Feb 03, 2009 | Acer Aspire 3680 Laptop
I have a Philips model 20pt1546/58.A few weeks ago is started to turn off by it self after aprox 20-30 minutes (with the power light on).I stoped using it for like 2 weeks and after that I plug it back...
for intermittent shut dow problems with this unit
it is a simple repair.
resolder conection on the yokes and check Capisitors C411=2200uf at 35v and c412 = 10uf at 50v on the main board
regards,
daniel.
Jan 15, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Freezing on 360, but different prblems on different games
Try researching it, that's what i did when it happened with CoD:4 (online) it may be overheating, you're obviously not having red lights, try unplugging it COMPLETELY and putting it near an open window
Dec 28, 2008 | Microsoft Xbox 360 Console
2nd Wii Remote will only not connect in Link's Crossbow Training
This is a ONE player game. It won't connect because the Wii isn't looking for any additional controllers. It's not a problem.
Jan 07, 2008 | Nintendo Wii Console
Problems With RCA Television (Gray Screen)
Your problem is the old rca tuner sheild repair thingy. Its a simple but tricky repair where the tuner grounds around the tuner sheild and under the bottom of the tuner sheild has to be resoldered. Most repair shops in the states that i know of charge like 65 to 125 .00 to do this simple repair. Now if you know how to solder you can get this reapir mod from sams photo facts and do it your self but its really an involved thing if you dont know what your doing as some of the serface mounted parts look like a spec of dirt and i've seen a few peeps clean off those specs and ruin the whole set. Best for you to take this set in for a repair. Good luck
May 05, 2006 | RCA F25645 25" TV
Cell Phones Logo
113 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
