SOURCE: Powermate PM0535000-01 Manual
powermate went out of business , but this might help let me know http://www.powermate.com/contact.php
SOURCE: in need of manual for a coleman PM0435003 Powermate Generator...
try Play it again sports
they have a large network of used sports gear and network of stores that get all inds of used stuff
They are individually owned so be persistent
SOURCE: My Coleman Powermate Pulse 1750 generator shuts down
Your generator should run a power tool rated at 10 amps. The 15 amps you mentioned for the PM1750 is for the DC rating. The AC rating is 11.6 amps.
Testimonial: "Thanks for the update. Checked out everything again and tried different tools. You were right on the money. Thanks"
SOURCE: My coleman powermate generator will start but will not generate.
The voltage regulator controls the output. You will need to check that first.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: No Power Output
Okay, this is going to sound kind of hard but you can do it...you need to flash the field and try to get some 'excitation' back to the windings. It's a bit of a deal but here's how:
With gen not running, plug the battery charge plug in to the charger output and you need to reverse the leads at the battery. Hook the BLACK to the positive post. Then, just touch the red to the negative terminal for a second or two. That's it!
Then...start gen and check output. If it just needed a flash, that will do it, I'm serious!
