Washer was working fine. Did 2 loads, no problems. On third load the water would come in for a few seconds and shut off, come in for a few seconds and shut off etc, then an alarm sounded and it stopped. I tried unplugging it for 30 seconds but the problem continues.
  • 11,896 Answers
There could be a couple different solutions. A couple things to check and test anyways. 1. Is the water valve that lets water in to machine. The one in the machine, If you are able to access it, make sure it is completely open, Check your drain and screen, make sure there is nothing in there from last rinse cycle. Otherwise machine might not fill if it senses clogged drain.
Last possibility is a bad water level sensor or door switch which both can be tested with ohmmeter or muti-tester to make sure they are both working.
Posted on Jul 24, 2009
Whirlpool awm 8125 fault code F09 followed by FA
The drain pump runs constantly in an effort to drain the water. Unplug the washer and, if the washer is overfilled, check the water inlet valve assembly for proper shut-off of water flow. If the water inlet valve assembly is defective, replace it. If the washer is empty when this error code appears, replace the water-level pressure switch.
Dec 16, 2013 | Whirlpool AWM8143 Front Load Washer
Spin cycle
sounds like a faulty timer unit.
Aug 26, 2013 | Frigidaire ATF6000ES Front Load Washer
Was working fine and went to put in 2nd load and water came out for a second and then all together stopped
hmm, I can think of a few things that would cause that.
First thought would be the water valve: this is a valve that has two solenoids on it, one for hot and one for cold they mix to one outlet that goes to a spout into your washtub. Try different temperature settings for the water. If cold does not work, see if warm does, if it's nothing but hot water coming out, then it's either the valve or your timer.
Second is the timer's not sending power to the water valve to turn it on.
Third would be the water level switch, if it is bad it may be prematurely telling the washer to go into agitate mode. If after the water stopped it went to agitate mode then it very well could be the water level switch.
Oct 30, 2009 | Maytag LAT3600A Top Load Washer
The machine stops after the wash cycle and won't finish.
The code is UE
load too small.
• Load is out of balance.
• The washer has an imbalance
detection and correction
system. If individual heavy
articles are loaded (bath
mat, bath robe, etc.) and the
imbalance is too great, the
washer will make several
attempts to restart the spin
cycle. If an imbalance is still
detected, the washer will stop
and the error code will be
displayed.
• Add 1 or 2 similar items to help balance the load.
• Rearrange items to help balance the load.
please rate this help to keep the service online
Aug 20, 2009 | LG Washing Machines
Washer trips circuit while filling tub
Sound like the inlet valve coil may be shorted. Remove console and check wires from water valve to control. If wires look ok, the inlet valve has a problem
Mar 18, 2009 | Maytag PAV2300 Top Load Washer
Clothes still wet at end of spin cycle
i would check your belt.the added stress of a full tub longer with water may have done it in.part#wh1x2026 God bless,tom
Jan 10, 2009 | GE WBSR3140DW Top Load Washer
Kenmore front loading washer/NOT SPINNING in cyle
replace your door lock switch it will run fine till you git to final spin then stops if i not missing the point the model no. will start with a 417 even door locks the switch is bad
Feb 24, 2008 | Washing Machines
Maytag top load won't drain
during spin is the tub making a slight roaring sound? if so the tub bearing is going bad causing the motor to work harder than normal causing it to heat up. this motor has a thermal protector which shuts it down , although the power to the timer remains therefore the timer still advances. this will require a new bearing and seal kit.
Feb 06, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
