Question about LaCie (300770) 250 GB Hard Drive
Seems to be loose/intermittent connection hard drive cable
Appearance on desk top goes on and off with subsequent error ms. of Device removal, etc. Can I fix this or do I have to send it in to La Cie?
  • agibson270 Jul 24, 2009
    Yes, very helpful and I had checked on another computer but not with another cable! Will try that. Thanks. Anne
  • 813 Answers
Before you send it back to La Cie, try plugging in the drive to another USB port in your computer. If that doesn't help, try using a different USB cable as the cable might be damaged. You can also try checking this hard disk on some other computer. Check if it happens the same on some other computer as well? In case it does not happnen on another computer, then the problem is on your computer and not the hard disk. If it happens the same on another computer with another USB cable then the Hard Disk is at fault and you will need to send it to La Cie. Also let us know the complete and exact error messages that you get.
Posted on Jul 24, 2009
I have a firelight smart disk 40GB Model FWFL-40-N. I have an I have a Mac Mini. Both are about 5 years old. When I plug the device in it doesn't show up on my desk top. Thanks for any help/advice
The Mac searches for peripheral devices on startup.
Try plugging in the drive and turning it on and THEN starting the Mac.
If the Mac does not acknowledge or see the device, then
check your cable that connects the device. Use a known good cable
to connect it. Then repeat the above procedure.
Aug 29, 2011 | SmartDisk FireLite 40 GB Hard Drive
My Lap top HDD is not showing up when connected to my Desk top. my siemens lap top hinges broke. I tried working with it and damaged screen. Removed HDD drive and found a free case at home with the USB...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Jul 12, 2011 | Silver Jeans MOBILE DISK HD-234-U2P...
When i install MS windows server 2003 in IBM x3400 server it gives me message that setup could not find any hard desk installed in your computer.
The hard drive may only needs the data cables re-connecting or the hard drive may be faulty.
First - re-seat the harddisk and reboot the computer. If this does not work then reboot and go to theBIOS configuration to see if the BIOS detects the hard drive. If it doesn'tdetect the hard drive then it could be faulty. Then the hard drive needsto be replaced in the computer, Windows installed and the computer's device drivers plus your programs etc. to get a functioningcomputer again.
May 28, 2011 | IBM x3400 Server
I have a 1/4 red ring in the lower right how bad is this and what do i do
That denotes some sort of hardware error... there should also be an error o the screen when you boot up the Xbox...
E45: Unknown (possibly dashboard update related)
E64: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc.
E65: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc. This can also be caused by the tray not being fully closed on boot.
E66: DVD Drive Error: DVD model, or version does not match that of the version expected by the dashboard. OR the firmware version on the drive is older then the firmware version expected by the dashboard. Make sure the DVD drive is of the same version originally included with the console and that it is using either the original firmware included with the console or newer.
E67: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E68: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it, This can also be caused by a Hard Drive Eprom Error. Some also believe this might be caused by a problem with the fans.
E69: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E71: possibly a dashboard update error, Check below in the "Console Reset Codes" for instructions. If that does not work there is no other solution and the console must be sent back to MS for repair.
E72: (not yet known)
E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port.
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
E76: (not yet known)
E79: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
Apr 19, 2011 | Microsoft Xbox 360 Console
Wont let me play says send error report
Well most xbox units in the US will have a code with the xbox error report, you need that code when calling microsoft customer support at 18004myxbox. If it goes to a black screen and gives an error code here is a list of known codes.
If the xbox is telling you something is wrong via the rings of death just make note of what the colors were and where they were.
Sep 10, 2010 | Microsoft Xbox 360 Elite Console
E 73
moz-screenshot-3.pngmoz-screenshot-4.pngmoz-screenshot-5.pngmoz-screenshot-6.pngmoz-screenshot-7.pngThis problem is fixable, I had similiar problem with my clients XBOX360 console ( I run an electronic repair shop) and get customers frequently with this Error. I was able to fix couple of consoles with the help from this XBOX360 Repair Guide
You can download the repair guide and fix most common problems with your XBOX console. There are also other errors which are covered in the guide, so you can fix them as well!
Oct 05, 2009 | Microsoft Xbox 360 Console
No manual for 320 GB desk top hard drive
its a plug and play just connect to the sys and start working on it
but be careful that u connect the power to the Ext.HDD first and then after that connect it to the USB port
similarly safe remove from the Sys and remove it only after u see the msg It is safe to remove the USB drive disconnect the USB cable from the Sys wait for 20-30 secs ten power off the HDD for better performence of the Ext HDD
Jul 27, 2009 | Electronics - Others
Can't transfer items to hard drive
Go to the Iomega Web sight and find tech support or Manuals/Guides and go from There??
May 30, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
It has the bottom left ring
Hello my name is Tim Ehrhart and I hope this helps The Specific Type of hardware failure can be determined by the error code displayed on the screen.
If the screen is blank or you would like additional information follow the instructions for determining the secondary error code in the section below
Please leave feedback as I am new and wanne gain a good rep. Thnk You
Mar 12, 2009 | Microsoft Xbox 360 Console
Replaced my hard drive on my hp lap top and i cannot load the restore disk it is hp ze4800 i dont know how to get it load error code pxe e61
HP and Compaq Desktop PCs - Error: PXE-E61: Media Test Failure s.gif s.gif
This document pertains to HP or Compaq desktop computers with Windows XP. The following error message appears: PXE-E61: Media Test Failure This error is probably occurring because the main bootable hard drive is no longer "connected" to the computer and the next usable bootable device in the boot path is the network card. Use the following steps to resolve the error: NOTE: If the computer was recently moved or bumped, make sure the hard drive cables are firmly attached to the motherboard and the hard drive before using the steps in this document. Step 1: Remove all removable storage devices Remove connected devices, remove power, and restart the computer:
  1. Disconnect any, personal media drives, pocket media drives, USB or 1394 (Firewire) devices that are attached to the computer, especially USB thumb drives.
  2. Remove any CD and DVD discs from their drives.
  3. If the computer has a floppy disk drive, remove any floppy disks from the drive.
  4. Press and hold the Power button for 5 Seconds to turn off the computer.
  5. Disconnect the power cable to the computer.
  6. With the power cable disconnected, press the power button again for five seconds. This may reset the firmware for the hard drive to its defaults .
  7. Plug in the power cable only and turn on the computer.
  8. If the error persists, go to the next step. If the computer starts without the error, one of the removable storage volumes may be preventing the computer from starting or the hard drive was not reponding. Do not leave the removable device in the computer when shutting the computer off. You are done.
Step 2: Make sure a network device is not selected as the first boot device in BIOS The computer may be attempting to boot from the network device.
  1. Turn on the computer by pressing the power button on the PC and press the F1 key repeatedly when the first screen opens.
  2. Use the arrow keys to select the BOOT screen (from the menu at the top of the screen).
  3. Use the arrow keys to select the BOOT Device Priority (or similar).
  4. Press Enter .
  5. Read the instructions on the page to move any reference to a netwrok device to the bottom of the list. You should also move the optical drive (ODD) to the top of the list.
  6. Once the selections have been made, press F10 to Save settings and exit.
Step 3: Test the Hard Drive Test the hard drive using the SMART hard drive test:
  1. Press and hold the Power button for 5 Seconds to turn off the computer.
  2. Press the F1 key repeatedly after the computer is turned on. A BIOS setup utility should appear.
  3. After the BIOS Setup Utility is displayed, use the Down Arrow key to select the hard disk drive name and press Enter .
  4. Select SMART Extended Self-Test , press Enter , and wait for the test to complete.
  5. If the test fails, the hard drive should be replaced. If the test passes, go to the next step to update the BIOS.
Step 4: Update the BIOS Download and install the latest BIOS for your computer . If, after updating the BIOS and restarting the computer, the error goes away, you are done. If the error persists or a BIOS update is unavailable, go to the next step to recover the computer. Step 5: Recover the operating system To reinstall the Windows XP operating system, perform a system recovery (or reinstall Windows if the computer was upgraded to XP). You may need to start the computer from a set of recovery discs (or from a Windows Installation disc if Windows was upgraded to XP). For more information about how to recover the computer, refer to the HP support article Performing a System Recovery in Windows XP . Step 6: Repair the computer If the preceding steps do not resolve the error, the hard drive or BIOS may have failed and the computer should be serviced. if this service info does not work contact me.
Oct 13, 2008 | Computers & Internet
LaCie (300770) 250 GB Hard Drive Logo
71 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
