Question about Jl Audio 500/1 Car Audio Amplifier
JL Audio 500/1 Amplifier "Thermal" light flashing
I recently took my complete system out of my truck. I tried to install everything back into place but now when I try to listen, the thermal light on my amp flashes. I have power, and the subs will play for about 2 seconds then quit for about 5 seconds then start again. Can anyone help? JL Audio 500/1 and 2 10w6's.
  • cci589 Jul 24, 2009
    Thanks for the quick reply, but it did not solve the problem. Could the problem possibly be in the RCA connections?
    Novelist:
  • 123 Answers
Pooi
Posted on Jul 25, 2009
  • Ian Percy Jul 25, 2009
    Hi, It`s definitely shutting down because the uPC is detecting a load on the outputs. Remove ALL speaker connections and try switching on, does it come on and stay on??, If it does, switch off and try connecting the speakers one by one until you find the offending speaker/lead. If it still doesn`t stay on, it sounds like some damage has been done to the amp either when it was removed from your last vehicle or during re-fitment. Ian
    Novelist:
  • 123 Answers
Re-check all the connections to the speakers, The uPC monitors all the outputs and if any are taking more power than they should, the uPC shuts the amp down to protect the internal components. Don`t use tape joints alone, try to run the cable the full length without any joints. If you do have to piece the wires together, solder them and stagger the connections, in other words, make one lead shorter than the other so that if the tape does come off, the offending connection is well away from the other so they can never meet or connect to each other. Ian
Posted on Jul 24, 2009
My Jl Audio 500/1, power light comes on but no power to subs
maybe it dont have enough to push it ,,did you try it before you buy it?
Mar 01, 2010 | Jl Audio 500/1 Car Audio Amplifier
My jl 500/1 the thermal light goes on and off every once in a while and the speakers stop playing
you may have the ohm load to low and the amp is over heating or it need more air and ventilation. use a small computer fan or make sure it is clear on all side so air can get to it.
Jan 21, 2010 | Jl Audio 500/1 Car Audio Amplifier
Jl 500/1 amplifier will not turn on
you may have burned the channel you were using..try taking the cover off the amp and checkin for burned spots or any wires that may be loose or touching within the amp.
Feb 24, 2009 | Jl Audio 500/1 Car Audio Amplifier
Jl audio 500/1 amp low ohm light at high volume
I would try running the subs in parallel. Pos to Pos Dual Voice, Neg to Neg Dual Voice. Then Run + to + stereo - to - stereo on both channels.
So you have + and - running to one channel and + and - running to the other channel.
Also your LPF filter could be set too high.
Feb 07, 2009 | Jl Audio 500/1 Car Audio Amplifier
Jl audio 250/1 thermal light
Disconnect all speaker wires from the amp and disconnect the RCA cables from the amp. If it still goes into protect mode, use a multimeter to confirm that you have 12v on the B+ and remote terminals. Place the black meter probe on the ground terminal of the amp when measuring the voltage. If the voltage is sufficient and the amp goes into protect, it will have to be repaired. JL only accepts repairs from authorized dealers. You'll have to find one in your area or you'll have to find a repair shop willing to work on JL amps.
Let me know if you have any other questions.
Oct 15, 2008 | Jl Audio 250/1 Car Audio Amplifier
Jl audio 500/1 amp
You may have the amp set to turn on via an audio signal. Set the Signal Sensing switch to OFF.
Jun 13, 2008 | Jl Audio 500/1 Car Audio Amplifier
JL Audio 500/1 amp
I need the answers to the questions I posted to know the condition of the amplifier.
Jun 09, 2008 | Jl Audio 500/1 Car Audio Amplifier
Bad amplifier need help!!!!
if you unhook the rca's does it persist?
Mar 26, 2007 | Jl Audio 300/4 Car Audio Amplifier
Help me
It sounds like your running the amp to hard (gain too high) or on an impedance lower than 1.5 ohm. What type of subwoofer are you running? voice coil? how far around is the gain setting? e mail me a j_impala@hotmail.com if you like.
Nov 08, 2006 | Jl Audio 500/1 Car Audio Amplifier
Jl Audio 500/1 Car Audio Amplifier Logo
771 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Matthew Spark
Matthew Spark
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
