Question about Fisher and Paykel DS605I Built-in Dishwasher
My DS603I leaks the rinse agent. How do I check
My DS603I leaks the rinse agent. How do I check and replace if necessary?
  • 67 Answers
I thought mine did, too. But that's the next dose, ready for the next load.
Posted on Jul 24, 2009
Rinse agent dispenser leaks won't allow to fill
If the dispenser is leaking, it's probably because of a faulty cap, or faulty or missing seal in the cap. And if you can't add any rinse-aid to the resevoir, It's probably full of water (which leaked in through the same faulty seal).
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Mar 20, 2015 | Kenmore Dishwashers
Rinse agent (blue liquid) is leaking into the bottom of the dishwasher compartment. Every time I refill, it leaks out within a few days. Any idea what is causing this?
There is a lot of info missing like brand and model, but it a general way they all work the same. A preset amount is dispensed in the last rinse cycle by an electric circuit. Sense this appears to leak the entire amount the valve/ opening is not shutting. A repairman would just replace the rinse aid dispenser assembly. They are hard to clean because the are a molded/sealed assembly.
Dec 29, 2014 | Dishwashers
I have Hobard LXIH dishwasher, it is working OK but during rinse cycle instead of taking in rinse agent it is actually fill rinse bottle back with water. Rinse pump is working, it was replaced in June
Check the rinse pump. The tubing needs to come from the supply into the bottom of the pump, and the pump should be running clockwise. If the pump tube is worn, the rinse pressure will blow through the pump filling the bottle
Dec 12, 2013 | Hobart Dishwashers
What is the rinse indicator clear knob inside door
That is the compartment for a liquid rinsing agent (Jet Dry). If you use it you can see if the compartment needs to be refilled by looking through the knob. Rinsing agent is supposed to keep glassware from having water spots but is not always necessary.
Jan 17, 2010 | Dishwashers
My Frigidaire dishwasher leaks the rinse agent into the tub. Therefore, the low rinse agent light is always on.
it may leak because:
1. Seal is bad. (o-ring?)
2. a spring on mechanism may be loose, missing or broken.
3. the container that holds the fluid may be cracked.
find schematic and parts for you model number here:
appliancepartspros.com
Nov 02, 2009 | Frigidaire Professional Series 24 in....
Dishwasher leaks when jet dry rinse is added everytime.
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Nov 27, 2008 | GE 25 in. Nautilus GSC3400J Free-standing...
DISHWASHER LEAKS FROM RINSE AGENT DISPENSER
Replace the Dispenser,This is not a problem you let continue! There is a risk of electrical short that can occur .And can cause fire.Take the inside front door panel off.Remove rinse Aid container and replace it.
Jun 08, 2008 | Whirlpool Dishwashers
Rinse agent runs out
Without the manufacturer and model number, it is very hard to help much. If this dishwasher is several years old, this may be the beginning of many, many problems so you may want to consider replacing the entire dishwasher.
It you want to attempt a repair, you start with removing the door panel screws around and near the door gasket. When you get it open, take some pictures of what you see. Closeups to hep you reassemble.
Zero in on the rinse agent dispenser reservoir and look for leaks. Identify what has failed and order either locally or on line.
Good Luck!
May 05, 2008 | GE 24 in. GSD3400G Built-in Dishwasher
DD603I with custom front panels... leaking rinse agent dispenser
That's crazy! That dispenser is very easy to change, you just need a torx bit screwdiver.
try http://www.fisherpaykelparts.net
Feb 19, 2008 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher and Paykel DS605I Built-in Dishwasher Logo
78 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
