Question about Vacuums
Bissell 9200 proheat carpet cleaner doesn t spray
Doesn't spray solution or water from bottom, only drips. everything else seems to work. suction is good. rollers turn. heater gets hot. cleaned both water and solution tanks and all lines seem to be clear of debris. only used about 6 times in last year. worked fine last time. after use was totally cleaned and left to dry before putting it up. followed directions bissell gave for re-priming with no change.
  • Bethanie D Lehman Jul 24, 2009
    the two red sprayers do not screw on they have clips that attached the spray ends to the tubes and that was the first thing I checked. they are clear. removed them both and blew air though to make sure. also checked and cleaned out all the other tubes. nothing found in any of them except one. not a clog, but a dust of sorts that was on the inside of the tube. clean it with a pipe cleaner. the tube I refer to is connected to a black connector on the side of a silver (maybe the cylinoid) thing in front of a water plastic tower looking thing.
    screen and all the individual pieces separated and cleaned. how to check the pump? just plug in and feel if there is air coming out?
    Top Expert:
  • Vacuums Master
  • 77,499 Answers
EITHER THE SWITCH IS DEFECTIVE OR THE PUMP IS DEFECTIVE, MOST LIKELY IT IS THE PUMP, CONSULT A LOCAL VACUUM REPAIR SHOP FOR DETAIL'S ON REPAIR.
Posted on Jul 25, 2009
  • 11,896 Answers
There is little jet nozzles that spray out the water, they to tend to clog with just the little gravel of sand. You can unscrew these and blow them out or clean with pin.
Posted on Jul 24, 2009
  • Nate Stansfield
    Nate Stansfield Jul 24, 2009
    Next thing would be to check the screen and hose in bottom of fill tank. And check the pump to make sure it is sending air pressure
Brushes not turning
It could be the belts. They are pretty easy to replace. Check the bottom of this tutorial http://www.diyvacuumrepair.com/carpet-cleaners/how-to-fix-a-bissell-proheat-that-wont-spray/
Feb 28, 2016 | Bissell 2X Proheat 9200 rug cleaner
Why does it have no suction?
The Bissell carpet cleaners and deep clean machines are a fantastic machine however they are prone to a couple of significant problems I find myself rebuilding a lot of these especially the 9200 series usually the biggest problem is they don't spray. in your case however I would think that you probably may have a blockage in the clean air duct for starters put the handle in the lower position to see if you have suction on the top of the machine also if you have an attachment for upholstery see if you're getting suction at the hose. Also check the red gaskets on both the cleaner tank and on the water tank to make sure that they are seated properly and they're not stuck in the machine they have to be attached to the tanks themselves. If everything seems to be ok then unfortunately it needs to be taken apart and the vacuum motor housing may have shifted or cracked o and therefore you're not getting the vacuum through the machine that you need to suck up the water. Good luck.
Feb 05, 2016 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissel pro2 carpet cleaner stopped sraying how to fix
Hey Diane! Sorry you're having difficulty with the spray on your ProHeat 2X. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Jan 15, 2013 | Bissell 2X Proheat 9200 rug cleaner
Bissell Steam Cleaner
my cleaner is not spraying or sucking up the water?
May 10, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell Pro Heat 9200 dirty water dripping out
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
rujr
Mar 20, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell ProHeat 2X(9200) hose to cleaner solution no suction
There are a couple areas to check:
1. The black gasket where clearview water collecting unit and the base's front meet. Ensure gasket is in good condition.
2. Check if you're getting sufficient suction: remove the water collecting unit. When you turn on the the unit, you'll feel suction out of a black hose pointing upwards next to the grey dial. If you're not getting sufficient suction you need to check that all the gaskets are seated properly. there are 3 gaskets: (1) an orange one seated between the black hose and the base unit (2 and 3): On the bottom of the unit there is a removeable panel. This panel has a gasket (red) and inside there is a white gasket.
Jun 30, 2009 | Bissell 9200 Upright Vacuum
Bissel proheat 2x main suction problems
bissel pro heat x2 does not suction up the cleaning fluid
May 25, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Steam cleaner will not **** up water
Apr 08, 2009 | Bissell 9200 Upright Vacuum
Schematic parts diagram for bissell proheat 9200 carpet cleaner
Hi, just go to amazon here: Amazon com bissell proheat carpet cleaner parts and you can find every needed parts. I hope this was helpful. Cheers
Jul 24, 2008 | Bissell 9200 Upright Vacuum
Vacuums Logo
181 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
