Question about Bosch 24 in. SHU43 Built-in Dishwasher
Dishawasher won't drain, sounds like a stuck garbage disposal
Shu43c
  • bowzerremy Jul 30, 2009
    I checked all of the lines and they're fine. The problem seems to be the pump (?), the water is not being pumped out and when it tries to it sounds like a loud buzzing. Any ideas?
    Thanks!
  • 67 Answers
Check for a kink in the discharge hose. Also, the hose must go up higher than the top of the dishwasher, then descend to the drain. Otherwise the waste water will flow back into the tub by siphon action.
Posted on Jul 24, 2009
Whirlpool dishwasher WDF520PADM5 won't drain. It will run through a cycle, but leaves a few inches of water at the bottom.
If the garbage disposal is clogged, the water from the dishwasher cannot drain. Most of the time the dishwasher drain hose is connected into the garbage disposal. Check to be sure water flows freely into the garbage disposal. You should hear it running into the bottom of the disposal when the dishwasher drains. The line connects to the garbage disposal at the top of the disposal with a hose clamp. If you undo it take the hose off and make sure the punch out inside the disposal tube is all the way punched out and there are no restrictions in their..ie stuck food particles or something else. Unplug the disposal when working on it. Just to be safe.
Hope this helps.
Dec 30, 2017 | Whirlpool Dishwashers
Kitchen sink won't drains only when garbage disposal is on
Remove tubular pipes under sink and clean out disposal.
Copy following links for steps for clogged disposal:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 29, 2012 | Badger 1 All Insinkerator 76039h 1/3 Hp...
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 | Dishwashers
Our sink and garbage disposal was clogged up. We got the sink unclogged, but the dishwasher had dirty water in the bottom and won't drain.
Your dishwasher drains into the garbage disposal. It you tried to use a plunger to clear your clogged sink or run the disposal with to much junk in it you may have force debris into the dishwasher drain hose. With both the dishwasher and garbage disposal disconnect from power disconnect the dishwasher drain hose from the garbage disposal. This is usually about a one inch black hose. Clear out any debris in the hose and inlet nipple on the garbage disposal. If debris is compacted far down the hose it will need to be disconnected from the dishwasher end and remove to clear the blockage.
Steve
Feb 10, 2012 | Asko 1385 Dishwasher
Won't drain water
New installation? Do you have a garbage disposal, there is a pluged port on the garbage disposal. Is the drain hose free to move, not crushed or twisted, Please provide model name and number.
InMrFixIt
Jun 19, 2011 | Dishwashers
BADGER DISPOSAL UNIT 5-81 SEEMS TO WORK, IT'S NOT STUCK BUT THE WATER WON'T GO DOWN IN THE SINK. ANY SUGGESTIONS.
Clean out the p-trap and tubular drain under the sink:
I wrote ez disposal replacement steps that cover how to take apart tubular drain pipe and put it back.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Jun 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My dishwasher is keeping water at the bottom of the washer and will not drain entirely How do I get into the machine to possibly clean out ay food trapped?
Try running the garbage disposal, most dishawashers discharge into the disposal.
After that, try running hotwater through the disposal (with it off) for 5-10 minutes to flush out any grease.
Then, run dishwasher again.
Sep 08, 2009 | Dishwashers
Dishawasher drains but right after lets all the
The check valve might be stuck. The valve is supposed to let the water out but stop it from flowing back in. Also make sure you discharge line has a loop. And check your air gap at the sink(if you have one) and make sure it is not plugged.
Aug 04, 2009 | GE HDA3500NWW Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
313 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
