Microsoft MT-SYTPT3227AB 32 in. LCD TV
Problem for Microsoft MT-SYTPT3227AB 32 in. LCD TV
My soyo mtsytpt3227abms tuns on says soyo and then turns off
By snoel280 on Jul 24, 2009
I plug in the tv it turns on all the way to the blue screen just past the soyo logo and then immediately turns off
Comments:
Jul 24, 2009
- The TV does turn again and then turns off it keeps cycling. It does not turn on all of the way, but just keeps trying
Best Solution
posted on Jul 24, 2009
Helpful)
freetek
Rank: Guru
Rating: 85%, 1827 votes
Complete loss of power points to the main power supply, a weak point in the majority of set failures.
Leave the set unplugged overnight to allow any residual charge to bleed from the power supply. Open the back panel of the set and look for a separate board that appears related to the incoming AC and has larger components on it; cylindrical cased capacitors and blocks that are transformers and chokes. If you find this, it will likely be something you can remove and replace yourself. Take a picture before removing cables or the board, although different connectors normally preclude incorrect assembly. Look for a part number on that board and contact the manufacturer to inquire about repair or replacement costs. Even if repair is offered, it may not be much cheaper than a new board. If you go with a new board, don't toss the old one, there are smaller companies specialized in the repair of these and you will probably need a spare.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Dec 08, 2009
Not Rated)
luismonty
Rank: Apprentice
Rating: 0%, 0 votes
I have another problem... I Turn on but the imagne doesnpt appear just the sound...
Was this helpful?
Yes
No
Popular Solutions for Microsoft MT-SYTPT3227AB 32
Questions and Unsolved Problems for Microsoft MT-SYTPT3227AB 32
Do you recommend Microsoft MT-SYTPT3227AB 32 in. LCD TV?
Answer
Answer
I have a maxent brand 42 inch monitor that when turned on has clear sound but no picture, what is... (More)
Answer
We have a Maxent LCD MX-27X2 LCD TV/monitor and the power supply board is bad. Where can I buy a... (More)
Answer
my tv when turned on has clear sound but no picture, do you know the problem and where I can get it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repairmen
in , OH
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
