Circuit board schematic required. Amana PTC093A35AA
Where can I view or acquire
    Sergeant:
  • 296 Answers
Hi
please chek this site for the schematic,
http://www.flagshipmarine.com/GRAPHICSSCANS/FM120CW-chart.jpg
and please chek these sites too
http://www.zekfrivolous.com/faq/sam/vt46sch.gif
http://www.neighborhost.com/temp/Evenheat01.png
hope you will have an idea of your required schematic.
for further queary,please do let us know,
we will be happy to help you.
All the best
regards
Posted on Jul 24, 2009
Tip
Schematic Diagrams for KLH ASW10-120
After acquiring a fried KLH ASW10-120, I write to the tech folks at KLH and they sent me the upper and lower board schematics. I asked if I could publish them online, and explicitly asked if I could share them on FixYa.com, and they gave me permission to do just that.
Here's the lower board, which has the power supply:
KLH ASW 10-120 subwoofer schematic - lower board
Here's the upper board:
KLH ASW 10-120 subwoofer schematic - upper board
on Sep 25, 2009 | KLH ASW10-120 Subwoofer
Where is the Manual Heater Reset Switch on an Amana A/C and Heater Unit Model number PTH093B35AJ? The unit has several stickers that state it has a "Manual Heater Reset Switch".
Almost certainly it is a bad relay on the circuit board. Sometimes you can slap the side of the unit by the control box to temporarily unstick the relay, after which the heat will come on for a cycle or two. There are two relays on the circuit board marked "heater 1" and "heater 2". You can order a new circuit board for about $100 or replace the relays at $4 apiece (order online from Digi-Key, requires solder connections). Part number JTN1a-PA-F-DC5V.
Jul 18, 2014 | Amana PTH093B35AJ 9100 BTU ThruWallWindow...
SCHEMATIC FOR AMANA DRIER NED7200TW
Hi ,
You cannot jus change the timer.You need to change the user console and display board fully.
Here is the part.Can order online.
http://www.repairclinic.com/PartDetail/User-Control-and-Display-Board/35001269/1185581?modelNumber=NED7200TW10
Here is the parts manual
http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Dryer-Parts/Model-NED7200TW10/1268/0151200
Thank You
Nov 28, 2012 | Dryers
Have an AMANA PTC093A35AA unit electric heater which is driving me crazy! I've replaced the control board and the 250 mA 250 V fuse but it's still dead. When I first put a new fuse in the "fan only"...
I would change out capacitor in the event there is a short in it this would explain why certain functions are on or off. The capacitor sits in by the circuit board is round and is either silver or gray. Has several wires running into the top plug of the capacitor. Remember the way they are wired into the top of the capacitor so you can reinstall the same way. If that doesn't work you could have a short in the system that has disrupted you circuit board again. Have the circuit board checked at an electronics repair shop. They should be able to tell you if the board is bad or not without having to purchase another board.
Good luck hope this helped you some
Dave
Jan 25, 2010 | GE Zoneline AZ38H12DAD Split System Air...
Amana sxde25j high voltage board blown..
hi there,
you can try to this store to order the parts to be replaced part number & description was also indicated in HERE.
just let me know, for further assistance,
Apr 21, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana PTAC PTC093A35AA won't blow heat
The reset button is located behing a panel on the front of the unit that is labeled Heat Reset. If that label is gone then look around, it is a small hole, small enough for a paper clip to fit through.
That being said, I have 137 of these units in one of my hotels and have not had a single one needing to be reset. You probably are going to need a new control board kit. These can be purchased from Amana. They are $130. Make sure that you have pulled the heater coil out and inspected it first. Also, there was a recall years ago where Amana was supposed to contact and send out new voltage switches. These are the round black things that the Brown heater wires connect to on the upper and lower side of the heating coil. You should also try to replace those if you find the coil in good condition. I have had those resolve heating issues. Most of the heating issues were a result of a bad relay on the control board though.
Please remember to rate this fix.
Jan 23, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Amana D530M Dehumidifier won't run
We all appear to be in the same mess --Thanx Haier
This product says its Amana, but rest assured it is an Haier
The problem is most likely with the engineering design of the board. Im not an electrical engineer so be careful litning to me to closely :) There is only a half bridge rectifier on this board and 2 zener diodes that clamp down on the voltage. My guess on yours is the Zeners have been shorted and no longer clamping voltage down to aroun 24 volts for the low side of the board. I spoke with Haier and they have no schematics that state the zener specifications. They also said there was a 6 month backorder on ordering a new board. Oh and by the way if you want to order a new board and wait 6 months for the backorder it would cost you 75.00. All this jsut to repeat the problem again, because of bad design. O well ----- I wish products were not made better, so I wouldnt have to fill guilty about putting this in the landfills.
Nov 04, 2008 | Amana D530M Dehumidifier
Weak reception, broken surface mount component
You can not find any schematics for the Magellans.  The schematics are classified.  Even when repairing GPS's for Magellan we didn't receive full schematics.  If your talking about the RF cable connector on the I/O Board (the board attached to the rear housing), then it's an easy solder fix.  For the capacitor/resistor:  I'm not sure where you found the capacitor origin, but if it's black with four legs coming off and parallel with the IC then tell me and I'll msg you back the rest.
Oct 09, 2007 | Magellan RoadMate 700 GPS Receiver
Need RIO EX1000 Power Supply Board.
I don't have any solution for your problem BUT you can resolve mine : what color are the rings of the AR51 component (next to the big dissipator)
Regards
Sep 06, 2007 | Rio EX1000 CD Shelf System
Heating & Cooling Logo
147 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
