Question about Canon PowerShot SD1000 Digital Camera
Canon Powershot SD1000 Lens won't focus
I went camping a few weeks ago and it got pretty cold at night and there was dew in the morning. My lens won't focus now, my brother said there is probably moisture in the lens. It seems like a simple problem, I really don't want to spend $100-$150 to get it fixed or get a new camera. Can anyone help???
  • 724 Answers
If you can get a hold of some dry nitrogen and setup a vacuum bottle of some sort using the food vacuum storage bag machine. Place the camera in the bottle. Seal the bottle with a top that has a dual vent idea where they both have a valve shutoff . One to the vacuum one piping in the nitrogen. Nitrogen is a no lethal non flameable drying agent they use in Binoculars to prevent fogging of the inside lenses.. Shut the Nitrogen side gas off. too. Open the vacuum side and pump down as much as possible there will be a max I do believe minus 25 foot pound per cubic inch of Mercury! Nature of this beast. Now shut that valve the camera is now vacuum packed. Turning on the Nitrogen open that port to the vacuum slowly not to make a sudden pressure change and let in all the Nitrogen it will take without blowing off the cap! If it is a pickle jar the top will pop like opening a sealed jar of pickles. .
Any moisture the nitrogen touches will be removes. This can be done if the camera's parts are not air tight. If they are then this problem would never had happened...
Simple and a cost of a very small jar of compressed Nitrogen is way less than 40 dollars. The vacuum machine should be a household item since you can afford a digital camera because you do preserve food and leftovers in savers bags
Posted on Jul 25, 2009
I was taking picture and they coming out fine. and then all of a sudden the pictures started coming out messed up. I think there is something wrong with the focus. any ideas?
Could be a lens error or display error. The latter can be tested by viewing the pictures on a PC or Mac. Lens errors in a Canon are tricky and usually of mechanical nature - such as a grain of sand in the mechanism. Let the lense expand / contract a few times to test it.
Jun 27, 2011 | Canon PowerShot SD1000 Digital Camera
My Canon PowerShot SD1000 won't focus. Most
Sounds like you may not be in "Auto" mode. Press the "Func/Set" button, then press Right or Left to select the "Auto" mode.
Nov 01, 2009 | Canon Powershot A1000IS 10MP Digital...
Canon SD1000 lens error
Turn off the Camera, remove the Battery pack, then press and hold the power button for 30 seconds.
Reinsert the Battery, then buzz around the lens for a few times then check if it works. Make sure that the Battery is fully charged.
The error message indicates that the lens is not able to adjust itself.
Oct 23, 2009 | Canon Cameras
My Canon Powershot SD1000 will not focus
You must need to reset all function of auto- focus setting.. its called as master reset. then see its works...
Jun 29, 2017 | Canon PowerShot SD1000 Digital Camera
Powershot SD1000 automatically shuts down in Camera mode
In any mode that the camera will stay on, press the "Menu" button and navigate to the RESET option and try to reset the camera. See if this will get the camera to function properly.
Jun 11, 2009 | Canon PowerShot SD1000 Digital Camera
Lens error please help!!!
If the sand is in the zoom gears or auto focus gears then the camera would need to be disassembled to remove. Nice thing about this camera is that no soldering is required to take apart. A few small screwdrivers, and some tweezers would be all that is required. Canned air and a needle might also be helpful for removing the sand. If the camera just buzzes then I would say that the sand is in the auto focus gears (the stepper motor will buzz). If the auto focus lens is not fully retracted then the camera lens will not go back in (to prevent the auto focus lens from bumping against the shutter assembly)
May 11, 2009 | Canon PowerShot SD1000 Digital Camera
Canon Powershot SD1000 Lens Will Not Retract
This is a huge recurring problem with Canon cameras. check out this website-give it a minute to load. You will see literally thousands of people with the same experience.
http://e18.bitnet.cx/comments.php?full=1
Aug 18, 2008 | Canon PowerShot SD1000 Digital Camera
Powershotsd1000 problem
Hello!!
Firstly switch off the camera
press and hold the ok button and turn the camera on and off for few times
whilst keeping this button depressed
Regards
Smilemaker.
Jul 19, 2008 | Canon PowerShot SD1000 Digital Camera
Canon SD1000 blurred pictures and blurred LCD, Camera wont focus! please help ive had it for 2 weeks
The best chance to use your SD1000 is to set to picture, push ISO (on top of the func. set ring) and set to hi. This works pretty well. Do not bother sending any camera to Canon, they charge the "standard charge" plus for all their manufacturing problems on all Canon cameras. Definately the worst customer service on the market.
Jul 07, 2008 | Canon PowerShot SD1000 Digital Camera
Won't Focus
You still have a bad lens the internal focus gear is out of alignment. or is offset. a repaired or new lens is required. Sorry :(
Feb 06, 2008 | Canon PowerShot SD1000 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
1,310 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
