SOURCE: NEED RADIO CODE FOR 2003 VW MADE BY CLARION MODEL#PU-2354A VWZ9Z7C0107353
The dealer can get those for you.
SOURCE: 2002 vw jetta radio panel does not turn on nor the radio works.
Fuse number 42 is for the radio reset. Pull it out and put it back in. It's a warranty problem, expired now no doubt.
SOURCE: transmission fluid check on a vw jetta tdi
Never ever bring a jetta to a volkwagen dealer. They will bend you over and rape you.
All you have to do is remove the top plug with a hex wrench.
SOURCE: clicking noise inside dash board 2003 vw jetta
the relay is going bad. its freezing up. this will sometimes happen when it gets stuck in the on position.
SOURCE: 2003 vw jetta gl 2.0 have codes p0351,p0352 and p0353
p0351- ignition coil A primary or secondary fault
p0352- ,, ,,,,,, ,,,,, B ,,,,, ,,,,,,, ,,,,,,,,,,,,, ,,,,,
p0353 - ,,,,,,,,,,,,, C,,,,,,,,,,,,,, ,,,, .,,,,,,,,,,,,,,,,
you may have a problem with yuor ingnition system
