Question about Jandy Aqualink Rs4 One Touch Control System Control System
Jet blower randomly starts ...
I've got a AquaLink RS4 that's jet blowers has began to self-start - when no programs are programmed, in the middle of the in night, randomly, filter nor spa are on ... what gives?
Most of the time this is caused by a faulty spa side controller. If you trace the line from the spa and disconnect it see if that solves the problem.
Posted on Aug 06, 2009
Aqualink rs4 manual pdf
hit cancel after that shows up for each program that will get rid of them or you can write down all the information then hit clear memory and reprogram all you auxs
Aug 27, 2014 | Jandy Aqualink RS4 Pool/Spa Combo -...
Aqualink rs4 owners manual
go to system set up then go to program highlight what you want to program then add start and stop time if to run all the time start 2:00am and stop 1:59 am it will shut off for 1 minute then restart
Jul 21, 2014 | Jandy Aqualink Rs4 One Touch Control...
How do I delete an Aqualink RS4 program? The filter is on all the time. When I set a new program start and stop time the controller keeps adding programs versus replacing an/the existing programs.
to delete a program go to system set up go to programs add or delete or edit if doing on its own disconnect spa side remote if goes away replace spa side remote if no spa side reset board clear memory and re program write down all auxs and JVAs
Dec 26, 2010 | Jandy Aqualink Rs4 One Touch Control...
Ryobi Leaf Blower
yes,,,,its a dirty carb jet or a blocked carb jet strip the carb and blow out all the running jets,dont go poking wire into any of the jets to clean them this could bistroy the jet/s
May 08, 2010 | Ryobi Snap In Primer Bulb Pump 683974 ...
Jandy Aqualink RS4 randomly turns on blower, pump, heater
I have has to deal with the same problem and have found that the spa switch is causing the problem. When I went into the lockout controls menu and locked out the spa switch I no longer had the problem. Once I figured this out and determined the spa switch was faulty I replaced the spa switch and everything is work correctly now.
Oct 09, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Filter clicks, but won't turn on. Pool lights
put your aqualink into service mode. then select components manually this will override any pre-programmed options
Jul 21, 2009 | Jandy Aqualink Rs4 One Touch Control...
AquaLink RS 4 top lights flashing red bottom lights flash yellow
I don't have the "one-touch", but on the "all-button" there's a hole on the left side of the unit. A paperclip inserted in this hole will reset the unit. I had a problem with the display on mine and this fixed it.
Apr 19, 2009 | Jandy Aqualink Rs4 One Touch Control...
Need to clear a program from my aqualink
Start with the cancel button. It will then prompt you to cancel the desired program. Go through the menu as you would with a program but follow the prompts to cancel. Remember, press cancel to start.
Dec 26, 2008 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy Aqualink Rs4 One Touch Control System Control System Logo
259 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
