Question about Sylvania LC320SS8 32 in. LCD Television
Sylvania LD37-SC8 won't power on
Did y
My sylvania 7" mini tablet won't start up. It only
It may need to be connected to a power source if this is the first tym u have turned it on.
Feb 24, 2013 | Computers & Internet
Sylvania 780 with windows 7 powers on but won't display
My sylvania cl772B turns on and shuts right off. what can I do?
Nov 10, 2012 | Sylvania CL772B 17" Flat Panel LCD Monitor
Sylvania HDTV Model LC370SS8 won't turn on.
u should check std-by volt .when u press power on , the power on volt must not b drop
Oct 09, 2012 | Sylvania LC320SS8 32 in. LCD Television
Have a sylvania lc26oss1 tv it won't turn on what is the problem
Check its main power regulator board. Check fuse. Check and repalce damaged component/s.
Oct 01, 2012 | Sylvania Televison & Video
My Sylvania 32" Tv Model #SRT2232S won't turn
Hello
There is a fuse inside the power supply bard of your sylvania TV. Check whether it has blown out. If bllown out, replace it with same type bothe in size and amperage. If the newly inserted fuse also blow up as soon as you switch on the set, make sure that the power supply section has some short circuit in it, and should be cheked well. OK.
Sep 28, 2011 | Sylvania SRT2232S 32" TV
I have a 32" CRT Sylvania Tv that won't turn
Hello
If the TV doesn't turn ON ata all, it is surely due to some fault with its power supply regulator section. You haven't given any otehr details of your tV, than it is only a 32 inch CRT Sylvanial Tv. No model number; so I only can provide you a solution in general.
Check the ON-OFF switch for its contact. Normally, TVs uses DPST type switches [Double Pole Single Throw]. If any one contact amoung them have any problem with its internal contacts, the set won't switch ON. If the switch is OK, come towards the power regulator section circuit board, and check whether the fuse has blown out or not. If it has blown out, replace it with same type and ampere rating. Never use higher ampere rating than specified. The ampere rating will be maiked either on the rims of the fuse, or at the printed circuit board, just under the fuse. After repalcing the fuse, switch ON the TV and see whether it works well or the replaced fuse blows up as soon as you switch ON the set. If the repalced switch burns out as soon as you switch ON the set, the power supply section has damaged [shorted components in it]; and should be replaced.
Normally for LCD TVs it will be good to replace the power supply as card basis. This power regulator card can be bought from most of the electronic spare part shops at your town, orby the authorised service center for Sylvania at your town. If you may have given its model number, I could send you the picture of the power card of your TV. OK.
Sep 28, 2011 | Sylvania 32 in. Diagonal LCD HDTV
Hi, I have a sony dav-sc8 dvd home theatre system and would likt to know if there is a way to make it multi region
These are the commands for the DAV-300 but hopefully they are the same for yours...hope it helps.
Region 0 is what you want, but here's all the commands for the 300 which hopefully work on the sc8 as well.
Put your player into "Standby" Mode and enter one of the following commands if
necessary,
: Remote control command Function
: [0] [RETURN] Default Default region code on the player
: [1] [RETURN] Region 1
: [2] [RETURN] Region 2
: [3] [RETURN] Region 3
: [4] [RETURN] Region 4
: [5] [RETURN] Region 5
: [6] [RETURN] Region 6
: [P. MODE] [RETURN] Only play DVD's with the selected region; auto switching
OFF
: [AUDIO] [RETURN] Default Auto switching ON
: [ANGLE] [RETURN] Enable video interference impulses (Macrovision ON)
: [SUBTITLE] [RETURN] Default Disable video interference impulses (Macrovision
OFF)
: [PREV] [RETURN] Enable user operation prohibitions* and access restrictions
: [NEXT] [RETURN] Default Disable user operation prohibitions* and access
restrictions.
Mar 17, 2011 | Sony DAV-SC8 System
My powersupply was not power can you get diagram?
Is this any good? http://www.scribd.com/doc/31727539/Sony-Hcd-sc5-Sc6-Sc8-v1-4
Nov 24, 2010 | Sony DAV-SC8 System
Sylvania LC320SS8 32 in. LCD Television Logo
199 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
