I have a modelLFA 7600 the agitator does not work
  • 6,784 Answers
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction. Another issue that might cuase this dissruption is the Motor coupler.
Washers with a direct drive motor have a motor coupler instead of a belt. The motor coupler consists of three plastic disks (or tri-stars) with interlocking tabs. Those tabs can wear and break which results in slippage. The slippage causes little or no power to be transferred to the transmission. A worn motor coupling can result in weak or no movement of the agitator and spin basket. Inspecting the motor couplers requires removing the motor, which is fairly easy to do.
Remove the cabinet. Locate the motor. The pump is mounted to one side of the motor. You do not have to remove the hoses from the pump unless they prevent you from moving the pump out of your way. If you must remove the hoses, label where they connect first. To disconnect the hoses, pinch the wire clamps with pliers (or loosen the screw) and slide the clamp farther up the hose. Slide the hose off of the pump port.
There are two clips that secure the pump housing to the motor. Use a screwdriver to pry up the clips and remove the cover. Next, slide off the pump to reveal the motor. Disconnect the wiring harness from the motor, do not pull on the wires themselves. The motor typically is secured with retaining clips and bolts. Remove the bolts and use a screwdriver to pry up the clips (if present). Remove the motor.
Mounted on the shaft of the back of the motor you will find the motor coupler. Separate the three disks and inspect them for damage. If you find cracks or excessive wear, replace the coupler.
**(((If the motor couple is in good condition, replace the agitator components and clutch assembly as well.)))
Posted on Jul 24, 2009
Nokia 7600
Get the Unlock code for Nokia 7600 at here
Mobileunlocksolutions.com/nokia-7600/rs1wp9/
and unlock it simply.
Nov 27, 2011 | Nokia 7600 Cellular Phone
My scanner used to work just fine, but suddenly it won't work anymore. It is plugged in and everything, but suddenly in Photoshop, the Xerox 7600 option under File > Import disappeared, and the WIA...
Have you tried an other USB cable??? have you tried a different USB port on the computer??? try the scanner on an other computer as well, does it have POWER???... eazy stepps to troubleshoot all types of devices is to first make sure the device has POWER, than concentrate on connectivity (cables, ports, etc...) than try it on an other computer, re-install drivers as well..., check for viruses also, when everything is clean and it still not working than replace the device... it's dead (send flowers) ha! just kidding!
Jul 23, 2011 | Xerox 7600 Flatbed Scanner
Will this product work with Win 7?
The system requirements for this unit are xp, vista.
Just so you know. Now if you have version 7600 of windows 7,
I would say yes it should work, but I put the requirements so you know.
I have not had anything not work with 7600, I have run XP requirements
in windows 7. 7600.
It would be best if you purchased this from a place you could return it.
Not because of windows, but who knows what kinds of errors you have created in the registry and it might not work because of other reasons.
I'm not trying to knock you, but I come across tons of problems that are because people can't run windows and create all kinds of problems but blame windows.
Windows is garbage, but usually made worse by its owners.
Feb 08, 2010 | Zalman Tech ZM-RSSC External Sound System
Epson Pro 7600 Service required error
Service required mean waste ink counter overflow. You need to reset it. SSC Service utility don't work with this type. The resetter is not for free, it's commercial. Only some distributor have it.
May 27, 2009 | Epson Stylus Pro 7600 InkJet Printer
Vista generic driver for usb scanner needed- is this possible
Hello ! I have the correct driver for the Visioneer 5300 / 7600 USB scanner. It will work with Windows XP and Vista. I can provide you a copy with complete installation instructions. Please e-mail me at: artb126@yahoo.com , Subj: 7600 driver.
Mar 21, 2009 | Visioneer One Touch 7600 USB
Lost installation cd for visioneer 7600 scanner usb one touch
Hi! I have the correct driver for the Visioner 5300 / 7600 that will work with Windows XP and Vista. I can provide you a copy with complete instructions for installation. Please e-mail me at: artb126@yahoo.com. Subj: 7600 driver.
Oct 14, 2008 | Visioneer One Touch 7600 USB
Find glass turntable replacement part
These are the glass trays listed to match the models you gave (NR961T is actually MR961T) and they are all shown as no longer available from standard suppliers:
MW-7600-04 MW-7600-06 MW-7600-11 MW-7600-13. MW-7600-12 should also work.
You can order one of the -11 or -12 trays by part number here.
It may take a week or two, and they may reply back that they were unable to find one, in which case they will not charge you.
If you can't find one, you can check eBay or Wal-Mart and other stores to see if they have a Rubbermaid or Nordic Ware (NordicWare) wind-up turntable like this "Micro-Go-Round". (I've seen them at Wal-Mart).
In some cases, two microwave-safe plates can serve as a makeshift replacement for a missing tray. You have to find a saucer that fits securely on your turntable support, though. Here;'s a photo of that, too.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 17, 2008 | Welbilt MR755T Microwave Oven
SDHC memory card compatability with 7600
no, will not take SDHC.
SD only sorry
Regards
Richard.
Jun 30, 2008 | Nikon Coolpix 7600 Digital Camera
Windows X-P
Here is the link of HOW TO:
http://www.visioneer-europe.com/support/faqs/15.htm
Dec 29, 2007 | Visioneer OneTouch 7600 Flatbed Scanner
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
