Question about Meade Optics
Hi, I require the gear wheels for the DEC motor on my LX10. They are the ones that are situated outside the framework.
    Genius:
  • 1,027 Answers
You can call Meade for replacement parts, or try ScopeStuff.com to see if they have replacements.
Posted on Jul 24, 2009
Why won't it downshift or shift into 4th?
2005 Chevy Aveo - engine light and hold lights flash - Fixya
www.fixya.com/.../t1361856-2005_chevy_aveo_engine_light_hold_ligh...
Dec 11, 2008 - 2005 Chevy Aveo - engine light and hold lights flash Yesterday I had my ... When I started the car to come home they started flashing again.
Chevrolet Aveo Transmission Problems - Car Forums at Edmunds.com
forums.edmunds.com > Chevrolet > Chevrolet Aveo
Sep 23, 2010 - 30 posts - ‎19 authors
Next time it jumps out of gear to push the onstar button and have it towed to .... to either start in 3rd gear (absolutely no power from a cold start until .... The car has beenstuck in park in both situations, level ground and ... My automatic 2005 Chevy Aveo LS requires T-IV Automatic Transmission Fluid (GM pt.
Nov 14, 2015 | 2005 Chevrolet Aveo
I have recently brought a secondhand quigngo plus but it seems very unstable and pulls to one side, can anyone help
hi Martin, check the two outside balance wheels , they rods that steer them in align with the main front wheel can be become bent at worse loose....I feel the scooter is dangerous when this happens , i seen this many times and you need to tip the scooter on it's back and start looking a the alignment of the front wheel in reference to the two outside wheels , hopefully if nothing not bent or broken you will be able to align them correctly again... be warned in this situation the scooter can not steer correctly ...
Sorry i never seen any kind of manual for this scooter that is helpful...
if you require further assistance don't hesitate to contact me please...
Regards
Rob
www.gewizrepairs.co.uk
Feb 04, 2015 | Office Equipment & Supplies
Toyota recall list
I have toyota matrix 2009 basic and when I shift from drive to park mode the front wheel drive axle does not lock in with transmission gear in turn running away vehicle on uphill park if parking brake was not set firmly.Please help. I'm thinking there is some thing wrong with Park Pawl is not engage and not locking the gear.
Apr 13, 2014 | 2009 Toyota Matrix
Sony PS-LX10 turntable stylus wrong landing point
Hi, at the left side of the tonearm base you will find a grommet or hole. Insert flat blade screwdriver and adjust to set correct start stop position. Cheers John.
Jan 19, 2013 | Audio Players & Recorders
I have an older meade LX2000 EMC 10
The main problems encountered with the mechanics of the telescope centre around the mechanical swarf, grease compound, the liberal use of grease and the quality of machining of the main DEC and RA gears.
1. Remove the motors from the telescope. Be careful when removing either motor as there is a compression spring between the motor mounting frame and the worm shaft assembly.
The RA motor is located under the telescope body, removing the 4 screws and 2 Allen bolts will allow the bottom cover to be removed, thereby allowing access the the 2 Allen bolts holding the motor in place. Unplug the motor from the main PCB before removal.
The DEC motor is in the the fork arm containing the clutch and fine DEC adjustment control. (Never to be used with power applied to the scope). Remove the 3 small Allen screws holding the plastic cover plate in place and the DEC clutch knob to allow access to the motor. Remove the RJ45 connector located inside the telescope fork arm. Then remove the motor by unscrewing the 2 Allen bolts holding the motor in place.
2. Remove all grease from the motor worms, especially around the RA motor's magnetic pulse detector and the permanent magnet built into the worm shaft.
3. Remove all grease from the main DEC and RA gears, making sure to clean into the gear teeth.
4. Lightly re-grease with a Molybdenum Disulphide based grease (Castrol MS3 is great for this application if you can get it)
5. Assemble in reverse order. But before doing so, carry out the electrical adjustment above then, (a) relocate the the RA and DEC control PCB's in the vertical plane thereby gaining access to their respective backlash Allen screws. Adjust for 20thou max clearance when in final position. Note:- the DEC adjustment screw has to be replaced for a longer unit complete with a thin bolthead as this adjustment has to be carried out with a spanner....there is no room for an Allen key adjustment here.
6. A drop of Loctite must be applied after adjustment.
7. The final part of the process is to run in the gearing. Apply 12 volts to the motor wires, either at their respective plugs or to the motor direct. Allow to run for 2 to 3 hours in each direction by reversing the battery polarity to bed the teeth engagement. Remember to release the clutches.
Dec 28, 2011 | Optics
Parked in ice snow one front wheel drives the other dosnt .
This is normal. This allows you to turn corners, as one wheel travels the outside of the curve a far greater distance then the one on the inside of the curve.
However.. It requires that there be some resistance on both wheels in order to push you forward.
Some solutions in newer vehicles are
"Trac Lock" which detects slippage and partially locks the wheel in synchroisation to move away from the slippery area.
4 Wheel Drive or All WD. which pushs all wheels together. Some of these burn through tires rather quickly due to resistance to turning.
If your vehicles does not have one of these, the best you can do is to buy high quality all weather tires for best grip on ice and snow. (Providing traction to GENTLY pull out of the situation)
Dec 03, 2010 | Ford Transit Connect Cars & Trucks
Dec fix kit for Meade LX50. Need new gears for the Dec motor. There was an aftermarket fix for this, but so far I have been unable to locate.
Dr. Clay Sherrod performs telescope upgrades, he can probably help.
Try the following links: http://www.arksky.org/supercharge.htm
Here is one person's review: http://www.cloudynights.com/item.php?item_id=1361
May 05, 2009 | Meade LX50 (8105003) (500 x 203mm)...
4 wheel drive will not disengage.
If you have tried shifting stopped and moving, then I'd say the transfer servo could be broken. It is the motor on the transfer case that shifts it in and out of four wheel drive. If you know how to use a voltmeter, test the wires that run to the servo to see if it is getting the signals it should be. Newer vehicles usually have a computer associated with the transfer case motor. You could have the car plugged to a tester at auto zone to see if it is giving a code.
Dec 14, 2008 | 2000 Isuzu Rodeo
Grinding Sound
Only solution - Don't buy a FELLOWES shredder.
It is ludicrous that they cannot (will not) supply a spare gear wheel when there are thousands of instances of them failing. Or even think outside the box - fit metal ones?
Jul 07, 2006 | Fellowes PS80C-2 Shredder
Optics Logo
105 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Meade Optic Expert? Answer questions, earn points and help others
