Question about Dell Inspiron 530s Desktop Computer
Not powering up with steady orange power light
Only the cpu fan turn for a second then stopped. opower supply and ram are good. what could be the problem?
  • 442 Answers
Did any one open the system, after which you are facing this problem?
If the 4 pin power connector is disconnected, you will face the same symptom.
This symptom can also appear if you have any external or internal devices electronically failed / Short circuited. Remove any external devices even external hard drive, flash memory devices, camera, printers etc and then restart the computer.
There is also a possibility of flea power, remove the power cable from the tower and press and hold the power button for 10 seconds, this will drain charge from the capacitors from the motherboard.
then connect the power cable and test if your issue is fixed.
if the issue is still not resolved, then we have to remove any internal devices, eg, add on sound card, video card, modem etc and then try powering up, if the issue persists there could be a problem with either the motherboard or power supply, which needs parts to be replaced and tested.
Posted on Jul 24, 2009
Why is my Sony VAIO VPCEB33FM green power light flashing?
It won't be the cpu. If it was, nothing would happen. I would look for a GPU issue, possible over heat.
Jan 01, 2015 | Sony Vaio Vpceb33fm
Dimension 3100 turns on the power button has a steady orange light there is also an orange light on motherboard cpu and power suplly fans working but wont bot up
Blinking amber (orange) indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this could indicate a problem with the power connections for the CPU on the system board (see "Power Problems" in your Owner's Manual).
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
It was just this morning when I tried to turn my pc on.. unfortunately it did not. ! when i press the power button on cpu it turns on for a few second like one or two but immediately after it drops the...
Try replacing the power supply - I had a similar problem that was fixed that way. If that doesn't work, it's probably the motherboard itself. The CPU is also possible - have you overclocked it or otherwise cooked it? Is the CPU cooler/fan blocked with fluff, or has the fan been slow (or stopped) - noisy fan is a sign of bearing stiffness/partial seizure which slows the fan and lets the CPU get too hot. If the CPU is fried, you get the symptoms you describe (MB won't start the PS)
Dec 23, 2010 | ASUS M2N-MX Motherboard
My Presario 8000T power on then off
Hi there. Seems you already have a clue on what you are doing (good job). Try to test the system with another RAM stick. It may be a bad RAM, bad CPU or most likely, bad motherboard. But, before you change the motherboard itself, do the RAM test. It is the best shot. There is a device that you plug to the PCI port of *********** board but by the time you pay for it you are better off testing the RAM first. Good luck (please, if this helped, leave a comment).
Jan 07, 2010 | Compaq Computers & Internet
I have HP 305W. When turns on the power, it stops within 5 scnds
sounds like your motherboard lost a control chip. that makes the power supply cycle off, when m/b doesn't send correct signals to continue boot.
Nov 27, 2009 | HP Computers & Internet
Dell C521 Power Issue
I would replace the power supply and if that does not help (after battery replacement and power supply), the ram could be faulty but usually faulty ram will beep a code. If ram has no avail i would suspect the mainboard and replace. Good Luck
Nov 24, 2009 | Dell Dimension C521 PC Desktop
Power supply Ok.But CPU fans started with seconds It's stop.
sounds to me like your mainboard is bad, i bet if you closely inspect the capacitors around the cpu one or more is bulged out or leaking
Feb 15, 2009 | Asrock P4S61 Motherboard
The bloe light turns on and the fan starts, then it all shuts off. I plugged it in and there is an orange light on it.
Can you get to the bios setting, by tapping the del or f2 key as it boots. Sound like a power supply - If you feel comfortable take cove off, unplug machine first. Remove Ram boards and re-insert them, plug in and turn on. Ram connectors get dirty and will give you this proble. Also sounds like a Bios or CPU bad. There is a tester for the power supply which will give you the reading for its voltage. good luck.
Jul 11, 2008 | Computers & Internet
DFI Infinity NF4 SLI won't start
Hi steve, PC repair is trial & error. I suggest you replace the power supply or test the power supply in another PC that also uses 4 SATA drives & two PCI-E slots for starters. Two boards with the same problem is odd. You must have the CPU & fan connected, memory installed, ATA 24_pin main power plugg connected (Page 17 in manual). 4-pin_12v power connected which is located (Just to the left of DDR1 memory slot). Looking at you're board the power supply should be no less than 500w.
CPU must have thermal grease between CPU & heat sink.
Even though you have fans running & LED's on & flashing, the power supply seems to be the first item to check. Make sure the bottom of the motherboard is not touching the PC case.
Try the above & post you're finding here.
Good Luck!
Mike
Jun 28, 2008 | DFI Computers & Internet
CPu fan turns for 1 second and then stops.
If all was working fine before, then, you have either not connected the cpu power cable, as is sometimes required other than being powered by the processor socket, or your power supply unit is not pentium 4 compatable and is unable to power the processor.
Apr 07, 2007 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
Dell Inspiron 530s Desktop Computer   Logo
302 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
