Question about Dell Inspiron 2200 Notebook
Volume isn't working at all! Tried adjusting volume, turning mute on and off, and it still isn't working!
    Sergeant:
  • 310 Answers
Hi, best thing to check is the drivers, goto control panel, system, device manager and look for any yellow or red symbols beside any of the devices, if there is it probably just need the drivers installed if it aint probably the sound on the motherboard is gone and would suggest a external soundcard as it will cost alot to fix or replace the motherboard.
Hope it helps
John
Posted on Jul 24, 2009
Kenwood krf v73000d mute won't go off
Is there a "tape monitor" button by chance? If this is turned on, it will mute your audio as well.
Mar 22, 2013 | Audio Players & Recorders
Audio Issues
have you tryed to reset the device, also performing a software update useing your desktop software might fix the problem.
Jun 16, 2008 | GPS
Somehow the ringer got turned off. Can't figure
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Sep 12, 2011 | Uniden Lands Phones
I have no sound out of the front speakers. Mute button is off, speakers work fine. Only have sound (very little) if volume is turned way up.
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's
full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume
it's probably not there.
Carefully examine the front panel for clues like a misplaced Source Selection, Mute, Tape
Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead'
spot through defect or idleness and is causing your symptom. Turn the POWER OFF and operate
every control throughout its range a number of times, especially rarely-used ones like Tape
Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Jul 10, 2011 | Yamaha RX-V870 Receiver
Why does the audio out is so low???
check whether the volume is low...
double click on the speaker icon on the system tray and then check if all the options has the volume set to max..
Mar 14, 2011 | Toshiba Computers & Internet
I am trying to hook the mic up to my computer in the location for microphones and it is not working. i also tried via my tv and stereo system. it will work to receive sounds if plugged into the phones
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Feb 23, 2011 | Samson R31S Microphone
My volume will not turn up or down but does mute when both buttons are held down? Is this fixable?
I had the same problem, couldn't adjust the volume but could mute with both buttons (indicating that there wasn't anything wrong with the controls themselves). Tried re-connecting, turning off and on, etc. Nothing worked. Then I took the mains power supply out of my Samsung NC10 netbook that the speakers were connected to (so that it was running on battery power) and the volume controls started working! I don't know why this worked but it did.However, when I was trying to adjust the volume when the netbook was on mains power I got interference through the speakers which may be related. Hope this helps.
Jul 11, 2009 | JBL CREATURE II Computer Speakers
Volume
re install the driver for your audio device.compaq will have the download you need
Dec 30, 2008 | Compaq Presario Notebook
The mute wont turn on,on the dell inspiron
Have you tried going into the speaker settings? We'll assume with a new PC you have Vista installed, click the speaker icon on the right side of the tray, and selecting "Mixer" will enable access to volume control for the output devices and for applications.
If no speaker icon is visible To check the volume controls in Windows Vista, click Start and then click Control Panel. Choose Hardware And Sound and then click Adjust System Volume under the Sound section. The Volume Mixer window will open, and you should see volume sliders for Device and Applications. Click and drag the sliders to view the volume level percentages. If the speaker icons show a circle with a red slash, click the icon so the speakers are no longer muted.
Furthermore, you’ll want to double-check all of your master volume and mute settings.
Dec 29, 2008 | Dell Inspiron 4000 Notebook
Dell Inspiron 2200 Notebook Logo
94 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
