Question about Canon imageCLASS MF4270 All-In-One Laser Printer
I have a Canon Imageclass MF4270, anytime it prints there is a loud clicking noise coming from the paper feed inside. Any ideas?
SOURCE: Loud clicking sound
We had the same problem, with a slightly different solution... it turned out in our case that the new toner cartridge's internal drum was too stiff, so the printer was trying to turn the toner spindle and failing, resulting in the clicking noise. Our solution was to manually turn the black center gear by hand a few times, and in doing so loosen the drum up a little, so that the printer could turn it. We put it back into the printer, and voila! No more clicking noise.
Thanks to whitehorse1 for his (or her) solution... though it wasn't the exact same problem for us, it was what put us on the right track. :)
Posted on Oct 18, 2008
SOURCE: Loud clicking noise
Problem also experienced by us. Taking the printer apart revealed the fuser assembly had a broken ring gear. Couldn't find a replacement part and it probably would not be cost effective anyway.
Posted on Oct 22, 2008
canontech
  • 1219 Answers
SOURCE: paper jam in canon Imageclass D861 copy machine
Where inside in fixing unit, drum unit,...
It is problem if its fixing unit jam.Best take it to service
Posted on Jan 12, 2010
SOURCE: canon MX850 - paper feed
Look carefully because it is a cassette on the bottom of your canon mx850... so the solution is: or you fill that cassette or you switch your canon (it is a button for that) to take the paper from the top...
Posted on Feb 15, 2010
  • 12 Answers
SOURCE: Paper will not feed from tray and makes a loud
The paper is not feeding from the paper tray. The loud click is alarming, but not the problem. Check the adjustments in the paper tray. The left and right guides should be snug, but the rear guide should give between a 1/16 inch and a 1/8 inch of free play.
If the rear guide is tight, or even snug, that is the problem. You can check for this by depressing the lever on the right front of the tray. Depressing the lever should raise the stack of paper out of the tray so that it can slide forward.
If you remove the paper from the tray, you will see calibration marks for the paper size you are using. Unlock the rear paper guide, squeeze the release, and move the guide ot the mark for the size paper you are using. For example, it you are using letter size paper, the read guide should point to "LTR".
Posted on Feb 28, 2011
Canon imageclass d340 making a loud clicking sound
It sounds like you may have sheared a gear tooth off the roller drive or the traversing mechanism. If you are getting copies just leave it alone.
Oct 12, 2016 | Canon imageCLASS D340 All-In-One Laser...
Canon mf4270 aio
From your program select File - Print. In the window that opens up there should be a button marked Preferences or Properties. Select that to see the available options for your printer. There should be an option to select Black and White. They may call it monochrome too. Select that and it will print only using black ink.
Aug 02, 2016 | Canon imageCLASS MF4270 All-In-One Laser...
Imageclass MF 4270 scans are too light
you can Adjust the density level of scanned image manually from MF4270 read the manual
if you don't have manual please visit this link
Download Canon imageCLASS MF4270 Reference Manual
hope that it will solve your problem
Feb 04, 2014 | Canon Office Equipment & Supplies
How come my Canon ImageClass MF4122 printer gives fuzzy images?
That is best bet since it appears that your print head is fubar and Canon charges a fortune for them. Cheaper to get a new printer with warranty.
Aug 24, 2017 | Canon New Compatible Black Print Laser Ink...
USB connection not being recognized on Imageclass MF4270 all of a
First make sure that the USB cable is OK and use another if you have one. Then make sure that the laptops have working USB ports from Device Manager. If they are OK then try powering up the Canon again without the USB cable connected to see if any errors are reported and then plug it in to your laptop to see if it is recognised. Check the status of the Canon Print Driver settings. If this all fails then you may have defective USB ports on the Canon and will need to get them repaired.
Oct 06, 2009 | Canon imageCLASS MF4270 All-In-One Laser...
My canon imageclass mf4270 jams 90% of the time when i try to print. sometimes if i pull out the toner cart several times. it will print.
Hello sir; Check the paper path carefully is there have anything block over there, especial at both end. is the paper jam everytime at same place? cleaning up the roller with alcohol.
Aug 05, 2009 | Canon Office Equipment & Supplies
Indicating paper jam but there is not jam
turn off and unplug for a good 10 seconds, then plug in/power on. If it still shows jam, have another look inside, some torn paper might be jammed inside.
Aug 04, 2009 | Canon imageCLASS MF4270 All-In-One Laser...
Loud Squeaking noise when feeding paper through.
You need machine oil to lubercate the feeding rod witch is sold at any hardware store.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 22, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Slow copying
normally, it's because you are copying in a high resolution. have a look at your user manual, lower the scan resolution and it should be a lot faster. Check that you're scanning in black and white -that can speed things up as well.
Feb 12, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
Paper feed broken
You broke a part. It is a low end machine. The repair will cost close to the repalcement cost of the machine. I would replace it and start with a new warranty.
Mar 20, 2008 | Canon ImageClass MF5770 Laser Copier...
Canon imageCLASS MF4270 All-In-One Laser Printer Logo
174 people viewed this question
old marine
old marine
