Question about Frigidaire Affinity ATF7000E Front Load Washer
Where is the filter located on a frigidaire Affinity washer ?
You have to take to back off the washer --be careful because the metal on the edges are sharp. The basket is located on the very bottom of the mechanical parts (sorry I can't be more specific) It is a strainer basket and fairly easy to remove and replace. Frigidaires' website has a schematic of the newer models to make the basket easier to find--I will try to attach the url for mine so you can find it.
http://www.frigidaire.com/manuals
Posted on Aug 01, 2009
erickg
  • 116 Answers
SOURCE: The washer door wont shut or lock on my frigidaire affinity
in the rubber seal around door to washer tub ensure there is nothing inbetween rubber.
Posted on Apr 21, 2009
localwonder
  • 6784 Answers
SOURCE: my frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
Posted on May 29, 2009
bozcro
  • 867 Answers
SOURCE: frigidaire affinity washer has started to smell
try doing a large load of white, lots of bleach, hot wash and hot rinse, heavy duty cycle
Posted on Jul 25, 2009
MakeupWizard
  • 39 Answers
SOURCE: What does error code E59 means on a Frigidaire
Hiya
if you have pressed any of the buttons during a wash cycle then you will be given an error message on the display to change the wash options once started you must 1st pause the wash before making any changes, this i think would be the main reason for such an error to appear however you can download your operaters manual at http://www.frigidaire.com/manuals
if you do not already have it & from there you may be able to have a read & work out why you received this message alternativly from the site you will get a link to a contact us section where you may be abal to ring the customer services & then have the assistant check the code for you..
Hope this helps
Posted on Apr 22, 2010
SOURCE: How do I go to clean cycle-Frigidaire affinity ATF6000fs
First, you put some bleach or tide washing machine cleaner inside. Then you make sure the washer is on and hold the spin speed button and the options button down at the same time for 10 seconds. You will see "Cln" appear on the display screen. Hit start and you are golden.
Posted on Jan 09, 2011
Frigidaire affinity error codes
I appreciate your inquiry, friend!
I see that you would like a list of Frigidaire Affinity washer error codes. I was unable to locate a full list of codes. Are you currently experiencing an issue with your washer? What error code is being displayed? With more information I will be able to assist you further. -Matt
Mar 12, 2015 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Tip
Affinity Washer Factory Service Manual
Here is the link to the Factory Repair Manual for your Frigidaire Affinity ATF6000 - 7000 Series Washing Machine.
Frigidaire Affinity Washer Repair Manual
Thanks
on Jan 21, 2009 | Frigidaire Affinity ATF7000E Front Load...
How do I take apart my frigidaire washer
Vanessa,
I will share a link with you that may put you happy and enthusiastic. It serves, as well as, a contact point for reasonably priced parts ; should you need them. Frigidaire Affinity Washer Disassembly . Take a look. And please share how you finished. Fare.Well.
Sep 20, 2014 | Frigidaire Affinity ATF7000E Front Load...
Where is the coin trap on my frigidaire affinity
Hello Friend, this is Z. That's a great question!
I understand you are seeking the location of the coin trap on your Frigidaire Affinity washer. Typically, the coin trap is located inside the sump to pump hose, inside the cabinet and under the tub. Hope this information helps to some degree! If there is anything else that I can help you with, please feel free to reconnect!
May 24, 2014 | Frigidaire ATF6000ES Front Load Washer
Where is the filter located on the affinity front load washer
Hi Kimberly,
I understand that you're trying to find out where the filter is on your affinity washer. You have to take the back of the washer off --be careful because the metal on the edges are sharp. The basket is located on the very bottom of the mechanical parts (sorry I can't be more specific) It is a strainer basket and fairly easy to remove and replace. Frigidaires' website has a schematic of the newer models to make the basket easier to find--I will try to attach the url for mine so you can find it.
Jan 03, 2014 | Frigidaire Affinity ATF7000E Front Load...
How to clean a affinity frigidaire front load washer drain pump filter?
remove the toe kick panel just below the front door and its located right below the drum
Oct 01, 2010 | Frigidaire Affinity ATF6000F Front Load...
Affinity ATF7000E Front Load Washer: where do i find what efo means on my affinity wash...
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
May 16, 2010 | Frigidaire Affinity ATF7000E Front Load...
Affinity Washers
Your Drain Is clogged, Try cleaning the drain filter underneath the Drum assembly. It will take some skill however.
Joe the Plumber
Mid-Hudson Heating & Plumbing
845 679-9158
Jun 14, 2008 | Frigidaire Affinity ATF7000E Front Load...
ERROR CODE 68 ON AFFINITY ATF7000EE
check tech sheet located inside washer cabinet at bottom. remove lower kick panel to access.
May 04, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF7000E Front Load Washer Logo
991 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
