Question about Adobe Acrobat 6.0 Professional for PC
Same thing - just stopped working.
Solution of printing from WORD doesn't always work, sometimes sends to a temp file I can never find. And the whole purpose of having Pro is to do more than just convert a single WORD doc to pdf. I do more than that with my Acrobat Pro - or I used to I guess...
  • Rhonda Bartlett Jul 28, 2009
    Sorry - I couldn't figure out how to answer you. I don't get an error message. If I choose Create File while in Acrobat Pro 6.0 and choose a WORD file, it says it's creating the pdf, then it says opening the application that created the original, then it opens WORD and opens the doc in WORD, but never does the creation/conversion. If I open the doc in WORD and choose print, ADOBE pdf, it says it does the conversion, but saves it to a .tmp file that I can't find anywhere on my computer.
  • 30 Answers
Hi there - can you send me an error message - or the version of software you are using
Posted on Jul 24, 2009
Print dosent stop
u have to create your label at printer properties.
if prints doesn't fix your label, this problem appears.
( for 80x40 cm barcode: open printer properties-printing defaults - label size - new custom size or new label - write your sizes at size fileds- and save)
open your app, and create new file, type your sizes for new file, and print it!
Jun 25, 2013 | Zebra Eltron TLP 2844 Thermal Label...
Fuel gauge sensor
Yes, the sending unit is in the tank. If you unplug the connector at the tank and ground the gauge's sender unit wire to metal, with key on, the dash gauge should jump to full or near full. This verifies the dash gauge is working properly, and the problem is with the sender unit in the tank. If the gauge doesn't move when grounded, then the gauge or wiring from tank to gauge is not correct.
Good luck.
Jan 24, 2012 | 1988 Jeep Wrangler
My printer will not communicate to my printer, and it did recntly. just stopped working a month ago.
Do a normal power off (leave the printer powered on) on the computer and after 5 seconds re-power the computer on and you should hear the printer do a reset and become ready. I've had the same problem, it's in the printer.
Jul 22, 2011 | Lexmark X5650 All-in-One InkJet Printer
My printer does not print from the computer nor does it print copies.
Try this utility: Print Flush 1.3
Fix your printer with this small utility!
Has your printer quit working? Did you try to cancel a job and it broke the printer completely? I always do that. And the method to fix it usually involves rebooting, restarting the print spooler, trashing junk print files, and sometimes even more. Not anymore.
Print Flush has a simple function: clean the print spool. If your printer's driver is incorrectly installed, Print Flush cannot help you. If you have used your printer before and it worked fine then, but it doesn't now, Print Flush can probably help you.
It also works with Vista.
http://www.bradkovach.com/printflush/
  1. Save somewhere where you can find it.
  2. If you downloaded the zipped version... Unzip the file to the desktop or something
  3. Double-click the file
  4. Try printing again!
Jul 20, 2011 | Dell 946 All-In-One InkJet Printer
Voice frequently not working. this problem intermittent. what do i need to do to ensure voice always works? Turning sound off and on again sometimes works. Turning on before using sometimes gets voice...
Are you using a synth voice, or a sampled voice? If the latter, one of the voice files might be damaged, and in that case, as soon as the Tomtom accesses it, the whole voice function will shut down.
Try changing the voice and see what happens. The synth voice does not access any sample files and should always work (or never at all).
To restore the functionality, download again the voice files, or try restoring from the PC backup. At least, this worked for me when I had the same problem (but MY file was damaged at the end, so I was able to notice that the last thing the Tomtom said was always "In sevent*". The damaged file was, I suppose, the one with the word "seventy".
May 29, 2010 | Tomtom GO 910 GPS Receiver
Mechanical error - print cartridge cradle can't move
4 years is quite some time for a printer especially if it is a home printer. Manufactures practically make there printers to **** down. You should be glad it lasted this long. If it carries a memory module then it might of gone out. Printer hold print jobs in there memory so if it gets full, the will stop working.
Mar 12, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP Laser Jet 1020 will not print
Just some things to try...
First thing to do is put the printer CD in the carriage and try to print again. Before you press the print button cancel the CD if the printer CD starts to auto run. This is in case your computer is looking for files it cannot find. Sometimes you get lucky when you try to print and the computer finds and grabs the files you need off of the CD. May not work but always worth a try...
Not sure if you have re-installed lately. If not, you may want to see if your printer CD will do a "repair" on your printer.
Check your printer software find the option to "check for updates". Your drivers may need an update. You may need to go to the HP site for this.
Search the HP site - First find your printer on the site. Then you will find downloads and help for your particular printer.
If your printer has a "Toolbox option" (i.e. troubleshooting) try that. If there is no Toolbox with your software the help option will run you through a troubleshooter.
You may want to uninstall and re-install. If you have spy ware or a virus scanner sometimes these apps. will grab files they think are suspect when it is actually files you need for your computer or say printer. So if you have any apps. like that go to company site or get in touch with them. Ask them how to ensure their software is not interfering with printer drivers etc... or other apps. that may just stop working for no reason.
Hope something works for you
Good Luck!
Feb 25, 2009 | HP LaserJet 1020 Printer
RX620 inconsistently only prints part of the page
The epson printer RX 620 only prints partially for my photo while I want the whole picture. How do I get it to print the whole thing instead of it printing it partially?
Apr 13, 2008 | Epson RX620 All-In-One InkJet Photo...
AS400 Spool files stuck in outq in send mode
I have WiFi Zebra QL420. In my case a simple header label prints fine then the complex label (many fields, barcode, lines & boxes) gets stuck. Labels are in separate spol files. We have many other labels printing fine, just this one ALWAYS gets stuck.
If I send same data from PC to printer it works fine.
I can see with ethernet sniffer that header label data goes but complex label doesn't even leave the iSeries. My sniffer is too crude to tell me what LPR level protocol is saying.
Oct 10, 2007 | Printronix T5000 Thermal Printer
Won't print pdf files
try with print other pdf file may this particular file is corrupted
Sep 22, 2007 | Canon PIXMA MP460 All-In-One InkJet...
Adobe Acrobat 6.0 Professional for PC Logo
123 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
