Question about Frigidaire ATF6000ES Front Load Washer
Black streaks on my laundry
I think they must be grease streaks since they dont come out when I rewash them. It used to be a random occurance but now its with every load.
    President:
  • 1,776 Answers
Marks on clothing in a washer are usually caused by a reaction between detergents and fabric softeners, especially cheaper bargain brands.
If you are sure that the black streaks are getting on the clothing in the washer versus the dryer, it could also be oil from the transmission getting into the washer tub. See if the spots will come out using a petroleum distillate of some kind. (paint thinner, etc). If a petroleum distillate will remove the marks, it is most likely something petroleum based that is making the marks.
This is a rare occurrence, and most marks on laundry are caused by the dryer. Typically, the drum rollers wear out and rubber and metal filings can get into the dryer and mark/streak clothing. Hope this helped and sorry for the problem you are having. Best wishes.
Posted on Jul 24, 2009
What should I do to stop washer from putting grease on clothes?
Good Afternoon Bernard,
I understand the washer of your Frigidaire laundry center, model# GLEH1642F, is leaving grease in your clothes. I also see that you noticed the grease in the detergent cup. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine where the grease is coming from to be able to repair your appliance. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire GLEH1642F Front Load Stacked...
White clothes come out with random black streaks
Drum is dirty from main barring leaking. This is job to fix by professional
Sep 22, 2012 | Asko W6021 Front Load Washer
Same thing
Liquid fabric softners usually cause spots and/or marks on light colored clothing . If you rewash the clothing and the marks dissapear , then try using dryer sheets instead . However , if you have an older dryer , then clothing could be getting rubbed between the rear drum seal and panel , but that would cause streaks but no spotting .
Jul 26, 2009 | Washing Machines
Leaving brown/black smudges
This is most likely caused by laundry getting stuck in the front seal of the washer.
Jul 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Clothing stains
Get a flash light and look very closely at the entire inside of the washer. what you are looking for is a little yellow grease, which is causing this problem. if you find the grease, remove it with a degreaser and you will be fine.
Jun 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Dirt streaks appear after laundering
Grease seal for the bearings need to be replace. Unless you are a DIYer this is an expensive repair. Labor to install a new grease seal is about 400 to 500 dollars depending on the area. Parts will run about 100 to 150 dollars. The grease seal is cheap about a $10.00 part, but since ypou have the washer torn apart, and the grease seal has fail, you should also replace the bearings.
May 17, 2009 | Frigidaire FWTBB30DS Front Load Washer
Black grease, wlll not drain or spin
u need the bearings changed the grease is from inside the bearing case
Dec 20, 2008 | Whirlpool LTG5243D Top Load Stacked Washer...
Fisher Paykel washer GWL15
I have noticed this same problem and wonder if it because my FP washer wasn't draining properly and dirty water couldn't get out. See my post on "eco smart won't drain, smells hot". I found one of my husband's socks when I removed the black motor/white plastic housing on bottom of washer. tip washer back and you'll see this electric motor. My post tells how to remove it. then you can look into that small space and see if there is something plugging it.
I am waiting on my replacemt motor, and hoping all the dirty streaks are gone. the water I drained out after i removed the sock was really grimy and gritty with dirt. I'm sure the sock has been holding a lot of junk in the bottom of the tub and it would end up on clothes during spin cycle. My issue has been going on for a few weeks and then the motor finally smoked which led to the sock discovery!
Oct 02, 2008 | Fisher Paykel EcoSmart GWL15
CLP-500 vertical streaks & a horizontal line with blotches appearing randomly
I've refilled the toner cartridges a few times now and never had a problem with vertical streaks until recently. I refilled both the cyan and magenta and when I ran the test page I had dark vertical streaks on both sides. I fiddled around cleaning things, running cleaning paper through, changing reset resistors but to no avail so eventually decided to buy a replacement refurbished cyan cartridge since the streaks looked mainly blue and bingo... well almost now I just have very light magenta streaks. The issue is obvious when I compared the old and new cartridge, the replacement toner is a much duller cyan and is of the wrong consistency since once it's been in the printer everything gets covered in it which is why I think it causes the banding to occur. I'm just trying to work out now whether to try refilling the magenta again (v. messy) or just go for another refurbished cartridge (£34).
Jun 12, 2008 | Samsung CLP-500 Laser Printer
Black marks
sounds like a bad rear bearing.causing grease to get into laundry.
May 27, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire ATF6000ES Front Load Washer Logo
854 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
