Question about Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool
Detroit digital safe. How do i change the combination.
I am currently using the safe with the default 4 digit combination. i also have the keys but i need to know haw i can change the combination as my daughter has figured it out.
lessmith49
  • 5 Answers
SOURCE: Lost combination Safe Guard Digital Safe
I used to work for a safe company.
The solution to your problem is not nice.
You need to find someone with a 9 inch grinder and a metal cutting blade.
Don't bother to try to cut the door off it is the strongest part.
If possible cut the back off. If not possible to get to the back start with the hinges if you know where they are, some hinges are concealed and are not where they appear to be.
This solution is messy dirty noisy and dangerous, that's what safes do to deter criminals.
If safe companies kept generic codes to open any kind of safe they wouldn't be,,,,,,,,,,,,,safe.
Posted on Feb 13, 2009
SOURCE: i have a gordon digital electronic safe # P45891,
Take the single screw off of the entry pad and remove the cover plate. Using the key that came with the safe, unlock the safe. Now, look for a little red button on the inner hinge. Push it in and you will note the yellow led on the the front of the safe turns on. Now, enter a 4 digit code of you choice. This is automatically saved and is the new 4 digit code you press to open the safe.
Posted on Jul 15, 2009
SOURCE: change code
Try this
Open the safe.
press the red button on inside of door
entry the new code you want followed by B
Should be good
Posted on Nov 28, 2009
SOURCE: YES I HAVE A GORDEN DIGITAL SAFE ALL I WANT TO
With the safe door open, you should see a red button, press, enter new code, then press either b or # depending on keypad.
Posted on Jan 20, 2010
  • 4090 Answers
SOURCE: Batteries are dead and I've lost the keys. Its an
Only through a licensed locksmith. Provide the key numbers and possibly even take the safe to him/her as proof of ownership. Locksmiths have to record all attemots to open safe's or maling f keysto the police.
Please provide a rating for my help++++Thanks for using FIXYA
Posted on Jun 15, 2010
Testimonial: "Cheers! Relieved I can at least have it opened without damaging the thing."
How do I change the combination on a door key safe
Once it is already OPEN there is probably something side the safe and on the back side of lock access that will allow you to change the combination. I do not know the model number but this is standard practice so that one must know the current combination to reset it to a new one. Specifically how would be in your manual. The key would allow the over ride to access this recombination. I have a digital door lock that works similarly and you can either enter the numbers or use a key to unlock it unlike a analog safe it has both a master code (which allow the ability to create new codes or delete old codes) and an access code.
Feb 01, 2015 | Home Security
Manual for stramm digital electronic safe manual
The Stramm safe we have is a small one that we use to store keys for our drivers. To change the combination, open the safe with the current combination. Sorry, can't help you if you don't know that. Inside the door is a plastic panel covering the batteries. Pinch the plastic catch at the top and open the panel. There is a small red button which you can press to change the combination. When you press it, you will hear a double beep. Enter your desired new combination. The trick is that the last digit must be either an "A" or a "B" which signals the end of your combination. For example, if you want your new combination to be 123456, you can't do that. The closest you can come is 123456A or 123456B. Hope this helps. Steve, Mbeya, Tanzania
Apr 06, 2013 | Safe International Digital Electronic Safe...
Factory reset la gard 3715 electronic safe
Welcome to FixYa.
How to reset or change your lock combination:
  • 1. Enter "zero" six times.
  • 2. Enter your existing six (6) digit combination one time. (or 123456, factory default if you haven't changed the combination yet.
  • 3. Enter your NEW six (6) digit combination two times.
  • 4. If a mistake is made wait thirty (30) seconds and repeat steps 1 - 3.
  • 5. Test lock operation several times before closing the door.
CAUTION: When selecting a combination do not use birthday or other predictable data that could give correlation between the user and combination.
• Valid Combination Entry - Double signal after valid six (6) digit combination is entered.
• Invalid Combination Entry - Triple signal indicates the old combination is still valid.
Thank you for using FixYa.
Have a great day.
Jas247
Aug 01, 2011 | Office Equipment & Supplies
My husband died 5 weeks ago and unfortunately did not tell anyone the combination.of his gun safe. It is approximately 5' tall. Is there any way to clear the old combination and reset? or am I going...
Some digital lock safes may have been provided with notes, manuals and papers; their manufacturer's websites filled with helpful instructions, documents and papers; however, this poses a problem on which one to choose. Simply read through everything that you can find, to eventually find the solution to your problem.
You haven't found any piece of useful paper of your digital safe's package; try reporting your problem to the manufacturer. You can contact manufacturers at their website or local offices. Send in a request for a tool key or a set of instructions on how to change your currently forgotten combination lock. While they do not keep records of safe combinations, they are the best group to consult on how to crack their own security codes.
http://ezinearticles.com/?Digital-Safe-Locks---Forgotten-Your-Code?&id=2123705
I would recommend calling a locksmith as it may be a cheaper solution than what the manufacturer has to offer.
May 18, 2011 | Computers & Internet
Detroit electronic digital safe lost code and keys
Help, just boughta Detroit digital safe, code number to open my instructions are locked inside.
Feb 19, 2010 | Sentry Fireproof Safe
I own a Bunker Hill digital floor safe sku #need code change data
To change the code: Your safe comes
preset with the default code of “159-A”.
To change the code, first open the safe.
On the inside of the door near the hinge,
there is a small red “reset” button. Press
this button until the Yellow LED on the
front panel lights up. Now, input your new
code up to 8 characters, followed by
either “A” or “B”. The Yellow LED will flash
to indicate that your new code has been
accepted. Warning: If the Yellow LED
does not flash, the code has not been
accepted, and you must start over.
NOTE: Be sure to test your new
combination before closing the door.
NOTE: Be sure to have the Override Key
available when setting a new
combination or changing batteries, in
case the door doesn’t open.
Good Luck
Nov 15, 2009 | Sentry Fireproof Safe
ACCIDENTLY LOST COMBINATION FOR DIGITAL SAFE , HAVE TO USE KEY
Take off front plate key will open, reset with default 159a should help
Sep 28, 2009 | Safe International Digital Electronic Safe...
Change the combination to a Sentry 2260 safe. I have original combination and all I just need to change the combination.
Safe and vault techs would advise you
1. Press the Program key.
2. Press it a second time.
3. Enter your 5-digit User Code. The green LED remains ON.
4. Enter the 5-digit Password of your choice (any combination
except 00000.) After 5 digits are entered, the green LED
turns OFF.
(To enter a new Password, repeat these steps. To erase the
Password, press Program twice, enter your User Code and then
enter 00000.)
Jun 08, 2009 | Sentry Fireproof Safe
How do I change an electronic safe combination?
hi, on mine if you open the door their is a red button press and hold for five seconds, then release put new code in then press again for 5 secs turn thelock to lock position do not close the door, put in the new code and see if it ulocks, if so, bingo, DO NOT CLOSE THE DOOR TILL YOU ARE CERTAIN THE CODE YOU PUT IN WORKS, hope this helps, mine only has a four digit code but i think its the same set up.
Feb 18, 2009 | Schylling Combination Steel Safe
Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool Logo
155 people viewed this question
Top Safe International Locks & Locksmithing Experts
Jim London
Jim London
john h
Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
