Question about HP OfficeJet 6110 All-In-One InkJet Printer
Power not turning on
Hi iam not able to turn on my printer
  • jimbo123 Nov 21, 2007
    I have reset up my computer after my daughter used it at another location
    and had the printer default for another printer . I have reset the default but I
    know there is a cable missing I have the cable connection to the cpu but not the power cable do you know what cable to buy.
    e-mail address is
    Thanks Jim
  • sfda410
    sfda410 May 11, 2010
    Fiend your solution direct from hp. Here is your solution...
  • 323 Answers
Here is the power cables description you requested, hope this helps
Posted on Feb 04, 2009
Posted on Oct 27, 2008
The problem has not been solved, i'm dstill not able to turn on the prnter. it work the day before i left the house turn off the printer, the folling day i turn the printer on , and it's not work (can not turn it on) since. please help me.
Posted on Sep 03, 2008
  • 42 Answers
Ur power cord is ok? ur traf unit is ok? if the answer is yes let me know.
Posted on Nov 21, 2007
Prinder show in control pannel but if iam give print command then printer show offline in control pannel. i does not give printout
Turn off the printer.
Disconnect the printer and unplug it from power.Do the same with the PC.
Reconnect them after a while.
Turn the printer on and start the PC.
Make sure the usb connections are well fixed.
Now print.
Hope this helps.Thanks!
Oct 10, 2011 | HP DeskJet D1460 InkJet Printer
Hi i have towa ax -100 and its write E3 iam
E3 error message is normally registration not completed.
Put the key in the turn power off,put key in P position put power back on.The system does a half clear.Go to R position and carry on with normal transactions.
May 26, 2010 | Epson Stylus CX4800 All-In-One InkJet...
My printer does not turn on?iam pushing the on button.
Unplug the power supply from the printer. The power supply is the black box behind the printer where the power cord is attached. With the other end of the power cord still plugged in to the power outlet, the power supply of your Lexmark X5650 should have a green light on around the silver contacts. If not, you might have a defective power supply. If that's the case, I suggest you contact Lexmark Technical Support for the power supply request. If there is, plug it back in the printer all the way through and in a correct position. Printer should power on automatically, otherwise, press the power button. If printer is still not powering on, it might be defective now. Contact Lexmark Technical Support for further troubleshooting.
May 11, 2010 | Lexmark X5650 All-in-One InkJet Printer
Hi, first; lets’ start from scratch. Turn off your (Computer), turn off the (Printer), unplug the printer from the power outlet; do not make any changes to the computer. Disconnect (all) the printer cables from the computer; reconnect the cables to the computer, and plug in to power outlet. Turn on the computer (first), turn on the printer. Go to; Control Panel, (Hardware and Sound), click Printer; if the Printer is present; click to open, Properties, click (Drivers): Update Drivers. Restart computer. Thanks paul7of9
Jan 13, 2010 | HP LaserJet P2015 Printer
Error code 5100 and belt that moves ink cartridge is making noise.
hi there....
since u dint specify ur printer model.... iam giving u a generic reset procedure..... first try this
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
5100 is a Carriage Home Position Error. if the above reset procedure dint help....
try cleaning the plastic strip that runs the length of the carriage, it may be contaminated.
Use alcohol and a swab.
check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
if even after cleaning the strip ur experiencing the problem then u can be rest assured that its time to call canon...
thank you for using Fixya...
have a nice day
Please rate this solution.
Aug 01, 2009 | Canon Office Equipment & Supplies
Power button brocken and not fixable is there any other way to turn on the computer
to turn it on, only do a short-circuit. or make another power button.
do that if you have study electronic and/or electricity
iam sorry for my bad english.
iam portuguese
May 21, 2009 | Gateway 7320GZ Notebook
Printer problem
Try doing power drain.
  1. T.S Steps.
  • Disconnect the printer from computer and power supply.
  • Press and hold th epower buton for 5 sec
  • Then simply turn the printer on. Then connect to the computer
Aug 22, 2008 | HP Officejet 4355 All-In-One InkJet...
Problem in canon 1120
will the manual be any help also more answers here
Canon Australia - LASER SHOT LBP-1120
Nov 11, 2007 | Canon LBP 1120 Laser Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
757 people viewed this question
Ben Johnson
