Question about Garden
HI, hope you can help. the motor will start but has only quarter revs and no power. Any suggestions. Thanks
  • susan_scully Jul 26, 2009
    The motor is gas. Thanks
  • woobie dog
    woobie dog May 11, 2010
    gas or electric??
    President:
  • 1,486 Answers
Check springs are connected on top of carberetor.And check throtle shaft not to tight.
Posted on Jul 24, 2009
1980s Suzuki 30 hp 2 stroke. I took it out to the lake pushed throttle a quarter of the way it was fine went half throttle and it seems to slip out of gear and revs high ? Back to quarter it goes ?
Hi Tommy
This condition is almost always caused by a spun propeller hub.
(See the link below)
We had the same issue a few years back with our Honda 15XL. Replaced the prop and the problem was solved.
Hope this helps you out.
-Steve
http://www.boatingmag.com/how-to-tell-if-youve-spun-your-propeller-hub
May 18, 2015 | Boating
Hi, i have a 1999 husqvarna 254xp... its abit hard to start and never idles more than 3secs.....from doing some looking into , i think maybe the L screw needs adj? if so could u explain in simple terms how...
In simple terms here we go, turn both L screw and H screw fully in until they stop ( clock wise ) now turn the L scew out one and a half turns out, and the H screw one and a quarter turns out, start the saw ans warm up the engine, allow the saw to idle, if need be turn the idle screw in to gain a slightly fast idle, start to turn the L screw in, the revs will start to increse as the mixture leans off, thet will reach a point where the engine then starts to die because it is too len, at this point unscrew the screw quarter turn, check the machine revs up clean, if there is a hesitation unscrew the jet a smaal bit at a time until it revs clean, now adjust the idle screw so the engine idles without the cutting chain rotating around the bar, the H screw should be about right however if it sounds too rich at full throttle srew the jet in a small amount until it sounds right, the maximum rpm should not exceed 13500, this should realy be check with a rev counter, if the engine revs too high there is a fear that it will over heat and seize.
Apr 13, 2011 | Husqvarna Forest & Garden No.967012396 345...
2000 pontiac grand am 3.4 motor auto trans 4 door.Car starts and drives okay motor seems to stumble slightly between 3000-4000 rpms. with car stopped in park try to rev motor will only go between 3200-4000...
Hi Tom your vehicle is equipped with a Rev limiter it will not allow you to rev the engine above 4000 with the trans in park; as for the first problem you may have one of two things, one of the spark plugs or spark plug wires is bad or you have a flat spot on the throttle positioning sensor in which case have be replaced. Good luck?
Mar 10, 2011 | 2001 Pontiac Grand Am SE
Hi , in ur panasonic microwave glass tray is not revolving plz suggest what to do? thanks
The motor assembly is fixed to the base of the oven usually with two screws and access i obtained by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate and disconnect the motor. Remove the motor and go and get a new one. Re fit it and put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Nov 04, 2010 | Panasonic Microwave Ovens
How to replace the blower motor in a dodge 2001 caravan
Removal & Installation
  1. Disconnect and isolate the negative battery cable.
  2. Remove the right quarter trim panel as follows:
    1. Remove first rear seat. Remove the second rear seat, if equipped.
    2. Remove the sliding door sill plate.
    3. Remove the quarter trim bolster.
    4. Remove the upper C-pillar trim and D-pillar trim panel.
    5. Remove the first and second rear seat belt anchors.
    6. Remove the screws securing the quarter trim to quarter panel from the bolster area.
    7. Remove the screws securing the rear edge of the quarter trim to the support bracket.
    8. Carefully disengage the hidden clips securing the front of the quarter trim to the quarter panel just rearward of the sliding door opening.
      Fig. Removing the trim panel to access the rear blower motor
    9. Disconnect the wiring harness connector from the accessory power outlet, if equipped.
    10. On long wheelbase wagons only, remove the quarter trim from the quarter panel and pull second rear seat belt through access hole.
    11. Pull first rear seat belt through the access hole.
    12. Remove the quarter trim panel from the vehicle.
  3. Remove the 5 screws mounting the A/C-heater blower motor housing to the rear HVAC unit (one mounting screw located on evaporator cover).
  4. Twist the blower motor out of scroll housing.
  5. Disconnect the blower motor wiring connector.
  6. Remove the blower motor from vehicle.
    Fig. The rear blower motor is held in place by four screws
To install:
  1. Install the blower motor unit into the vehicle.
  2. Reconnect the blower motor wiring connector.
  3. Secure the blower motor into scroll housing.
  4. Install and tighten the 5 screws mounting the A/C-heater blower motor housing to the rear HVAC unit (one mounting screw located on evaporator cover).
  5. Install the right quarter trim panel as follows:
    1. Install the quarter trim panel in position in the vehicle.
    2. Insert and pull the first rear seat belt through the access hole in quarter trim panel.
    3. On long wheelbase wagons only, insert and pull the second rear seat belt through access hole in quarter trim panel.
    4. Reconnect the wiring harness connector to the accessory power outlet, if equipped.
    5. Engage the hidden clips to secure the front of quarter trim to quarter panel rearward of sliding door opening.
    6. Install the retaining screws that secure the rear edge of quarter trim to support bracket.
    7. Install the retaining screws that secure the quarter trim to the quarter panel in bolster area.
    8. Install the second rear seat belt anchor (if equipped), and the first rear seat belt anchor.
    9. Install the D-pillar trim panel and upper C-pillar trim.
    10. Install the quarter trim bolster.
    11. Install the sliding door sill plate.
    12. Install the second rear seat, if equipped, and install the first rear seat.
  6. Reconnect the negative battery cable. Check blower motor operation.
Hope helps (remember to rate this).
Nov 01, 2010 | 2000 Dodge Caravan
1978-79 15 HP Evinrude boat motor hi low settings
High revs is 5500-5700. low revs is about 500. the low revs is in gear and idling.Hope this is the info you are after
Jun 05, 2009 | Boating
No power at low revs but works a treat at higher revs.
maybe its your carburetor it might need adjusting.
Jan 14, 2009 | 2000 Yamaha DT 125 R
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
