Question about Janome Sewing Machines
How to replace the needle - Janome Sewing Machines
  • 46 Answers
Loosen the needle clamp screw. Turn toward you to the left. Remove old needle and then replace with schmetz brand flat side to the back and make sure the needle goes all the way up in the clamp until it stops before tightening the clamp. That should do it.
Posted on Jul 25, 2009
What is "needle maintenance?"
Using correct needle for job and not bending it.
Aug 27, 2017 | Sewing Machines
Needle threader won't work on my Singer 4423
The needle threader hook is very tiny and easily bent or damaged.
The needle threader is designed not to turn, if the needle is not at its most upper position to protect the threader - Turn hand wheel until needle reaches its highest position.
Needle not alining with threader hook - Replace needle.
Threader hook bent - Replace with new needle threader hook.
Hope this helps.
Read more from the link I attatched.
Good luck & have a nice day!
Automatic needle threader will not work
Jul 14, 2017 | Singer Sewing Machines
The needle is hitting the plate all of a sudden?
If it hit all of a sudden it most likely was your needle got bent. Replace needle and don't pull the material. Let the foot do the work.
Mar 27, 2017 | Sewing Machines
How do I replace a needle
There are a lot of web sites and videos available:
sewing machine replace needle Google Search
NOTE: Needles should be replaced often, ie every time you start a new project... Needles bend, dull, or get nicked. Your sewing experience will be so much more enjoyable and successful with fresh needles. They really are a "cheap" fix for many sewing problems.
Jan 27, 2016 | Sewing Machines
Replace needle on a Huskylock 905
Look in your owner's manual for needle replacement procedure. You have to unscrew the small screw holding the needle.
Be careful that the new needle is properly seated before screwing it tight. Otherwise, you might end up with it slightly askew.
Apr 01, 2014 | Husqvarna Huskylock Computerized 905
How to chang ethe needle
there should be a little hand screw near the top of the needle, loosen it enough to slide the broken needle out, replace with a new needle and tighten, Just remember, if you don't have the needle in properly you will ave issues. Usually, the flat part of the needle goes to the right, I have a brother sewing machine and the flat part on mune goes to the back though. Just take note when you remove the old needle as to the position. Also, a little known fact, a sewing machine needle should be replaced after 8 hours of use.
Jan 16, 2014 | Sewing Machines
I broke a needle and tried to replace both needles. Now I can't get my machine to chain. I have rethreaded it, and replaced the needles, closely following the manual and threading guide but still
it's possible that when the needle broke it could have caused the
machine to jump time and would need to be serviced to see if it
needs adjustment.
Mar 08, 2013 | Sewing Machines
Zigzag stitch problems on brothers pc-420 sewing machine
Sewing machine skips stitches
1.needle inserted incorrectly
flat side of the needle faces the shaft
round needle
groove of needle faces away from the shaft
Correct needle insertion is mandatory for proper use
Raise the needle bar to the highest point, then loosen the clamp screw to remove the needle.
Place the new needle in the clamp with the flat side of the needle facing the back of the machine.
If round needle--the groove in the needle faces away from the shaft
Push needle all the way up to the stop or as far as it will go.
3.possible bent needle--lay needle on flat surface & roll needle over, if the needle does not roll good -replace
4.blunt needle point--needle makes a popping sound when needle penetrates the fabric--replace needle
5.needle not all the way up in needle holder--loosen needle clamp screw & push the needle up until it stops then tighten screw
6.incorrect threading--one step missed in sequence of threading can cause machine to skip stitches
7.wrong needle in machine--check instruction manual--some machines can use a generic needle with no problem
8.size of needle & thread & the fabric are not compatable
Mar 30, 2012 | Brother PC-420
When it changes from straight stitch to sepintine and back to straight it skips lots of stitches. Just paid $300 for a new shaft.
try these suggestions & see if they help
1.needle inserted incorrectly--flat side of the needle faces the shaft
round needle--groove of needle faces away from the shaft
2.Correct needle insertion is mandatory for proper use.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the needle. Place the new needle in the clamp with the flat side of the needle facing the back of the machine.
7.wrong needle in machine--check instruction manual--some machines can use a generic needle with no problem--some can't--
8.size of needle & thread not compatible--
Using the wrong type needle can cause problems,,
A needle to fine for heavy fabric can bend or break when it hit's the fabric
And a too large needle can make puncture holes in the fabric and pull unevenly while stitching
Sep 15, 2011 | Baby Lock Sewing Machines
How do you change an embellisher needle
Unlike some other machines, you do not need to replace the entire needle shank when a needle breaks. The Embellisher comes with two alan key screwdrivers for changing needles. Insert the larger screwdriver at the red marking to loosen the entire needle shank. Remove the needle shank from the Embellisher and use the smaller screwdriver to loosen and remove the needle(s) you wish to change. Replace with new needle and tighten into position with small screwdriver. Then simply replace the needle shank with the red marking facing the front (towards you).
Dec 08, 2010 | Janome Sewing Machines
Sewing Machines Logo
77 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
