F6 error code, new main controller doesnt solve it
  • paul929 Jul 25, 2009
    This is on a Kenmore Elite HE3 washer. I have ordered a new MCU and a spin control board from RepairClinic.com and will let you know what I find from there. Thanks.
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    If this is in reference to a Kenmore Elite or Whirlpool Duet front loader, this error code is a Motor Speed error. This indicates a problem with either the MOTOR CONTROL UNIT (MCU), DRIVE MOTOR, or INTERCONNECTING WIRING.
  • 15,935 Answers
The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 – is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
F6 error code whirpool duet
The F6 error code for this model indicates a drive motor tachometer error. The control board is unable to properly detect the motor speed.
Jan 09, 2016 | Washing Machines
I have an f6 code and the machine will not operate once it comes up
The F6 error code means that the computer on the control didnt detect that the motor reached a high speed on the spin cycle, sometimes it thinks the washer didnt spin fast enough because of a loose wire connection either on the motor or the control boards (motor &machine control) if you find that the washer did actually spin at high speed (clothes dont come out sopping wet at the end of cycle) the wire connections or the motor control board will be the potential causes of the F6 error code. Try unplugging the machine for five minutes to let the computer reset then try again. Next check the control panel wires. f6 code flashing on display Kenmore Elite HE3 Washing Machine
May 19, 2015 | Washing Machines
My kenmore washing machine is stopping mid-cycle and reading f6 on the panel
The F/06 error according to the official repair manual is a Motor Tachometer error . . the error is triggered because the main control board loses communication with the tachometer either a short in the wiring or a short in one of several other places. . The tachometer sits on the spindle of the motor and has two wires from the spindle to a wiring hub on the left side of the motor . . . two of the black wires are for the tach then feed to the MCU (Motor Control Unit) in the bottom left facing the washer which then feeds the info into the main control board which is at the top on the machine under the top cover. Some find that checking the connections with a volt meter is a starting point however in most cases you will not find issues with electrical continuity, the manual has the expected readings. The MCU is known to go bad in these machines so that would be the first suspect in resolving the error, however it could be the wiring, the motor or the main control board. The MCU costs around $200 so consider the possibility that it may not solve your issue. The error may even be sporadic only happening on heavier loads in the tub.
Nov 18, 2013 | Kenmore Washing Machines
F6 error on Hitachi washing machine Sk 120KJS
Jul 09, 2012 | Washing Machines
Getting an "F6" error on
HELLO.
An F6 error code typically indicates a controlpanel problem. Disconnect power and wait several minutes before plugging itback in. If the F6 error code comes back within a minute of restoring power,the control switch pulse return line is not connected properly. This willgenerally require professional repair.
Thanks.
Sep 21, 2011 | Kenmore Microwave Ovens
Im getting a f6 code on my digital control topside pack. what is this and how can i fix it
F6 typically doesnt indicate an error. This is usually a programming code that tells you spa to filter every 12 hours.
If it is a FLo code that just looks like an F6, then you need to either replace the filter, replace the flow switch , or make sure the pump is pushing enough water.
Mar 18, 2011 | Balboa Instruments BALBOA 30 kW HEATER W...
How to resolve the F6 E0 error code on the built-in Kitchenaid microwave oven? The unit was brand new and installed 2 and half years ago in my new house. One website mentions the description for this...
"F6" on a Whirlpool microwave means you have a shorted cook relay on your control board, which I can repair. Details here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 26, 2017 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Whirlpool Accubake Range - error F6 E4 , how do I stop the beeping
Replace the sensor as shown in the F6 code
F6 Computer logic interrupted (timing) Replace Electronic Range Control (ERC)
Error Code: E4
Cause: Shorted sensor
Example: Disables cooking in affected oven
Corrective Action: Check sensor
Nov 02, 2010 | KitchenAid KESC300 Electric Kitchen Range
Code F6, E0, "Communication Error"
Hi. this code represents a key pad or control board malfunction. you will have to make sure the key pad or control panel connectors are connected tightly and securely. If the wires and connectors are secure, the actual control board may be faulty and you will need to replace it at this point.
Mar 01, 2009 | KitchenAid Microwave Convection Oven
F6 Code
f6 communication error in ht emotor controll board, located in the lower left front of machine
Nov 07, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
171 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
