Question about Frigidaire Affinity ATF7000E Front Load Washer
How do I check for 120 VAC at the drain pump? I know where the drain pump is, Im just not sure how to check for 120VAC
    President:
  • 1,185 Answers
First you need a voltmeter
Set that to AC volts in the 200v range
Clip the black or blue lead to the earth post (thats the one with all of the green wires clamped on it)
Put the red or brown wire from the meter onto the brown or red wire of the pump (For safety you need to use an alligator clip or spring clip tipped probe to make the connection)
Switch the machine on to the pump cycle and you should read 120v .
Unless you have an electrical background I would not recommed that you work inside a machine which is live.
Posted on Jul 24, 2009
The converter on my motorhome does not convert 120vac to 12vdc anymore what could be the problem
Make sure that the the down transformer is good. That being the case then the items to check are the rectifiers- usually diodes that convert current from ac to dc. They all have to be working.
Mar 21, 2016 | Electrical Supplies
I know Dyson DC 35 uses a battery that converts ac charging source to low v DC power. Am asking about charging ac source of 220 v.
If your unit is set up for 120v (std American), I wouldn't suggest try 220. There are adapters, available that step down 220 to 120. Many of the people in the military who are stationed overseas (especially Europe) buy these devices for there US equipment. Try to "Google" 220 vac-120vac adapters. I'm sure there are places you can order them from.
Aug 02, 2015 | Dyson DC-35 Digital Slim Cordless...
I have a maytag neptune front load washer mah9700, and i need to know how to reset it. its on a quick wash cycle, but it has a delay for the door to lock , then when it does, it does nothing. it has a...
The "nd" error code on a Maytag Neptune MAH9700 means that the water level is not draining quickly enough or at all, in some cases a symptom of a restricted drain system or a hose twist. If you have the tools and don't want to call a repair technician, the service manual (found at http://www.applianceblog.com/manuals/16025909.pdf), recommends the following steps:
1. Check for restricted drain system. 2. In cold climates, check for frozen drain hose. 3. Check for 120 VAC at the pump when a spin cycle is selected. 4. Check pump motor winding resistance. (14.2 +/- 7% ohms) 5. Check that the machine control correctly senses the water level in the washer [by performing the] Board Input Test [found in the manual]. 6. [Perform the] Board Output Test and perform the Pump Out Test. 7. Check the Machine Control Board connections at CN10 (Pin 6) for the pump. Should see 110-120VAC.(Refer to the component testing procedure). 8. Check tub to pump hose for twist in hose.
I would recommend trying several of these steps that are within your comfort level. If the problem persists, it may best be solved by a licensed repairman.
Aug 29, 2011 | Washing Machines
The drum turns but no heat. I have checked the house fuse and it is OK. I see there is a fuse but don't know how to get to it.
I'd get a volt meter set on VAC.
Unplug dryer and using volt meter to measure following voltages at the wall :
"Top Left" to "Center Bottom" = 120vac
"Top Right" to "Center Bottom" = 120vac
"Top Left" to "Top Right" = 240vac
I suspect one of the 120vac legs is out by not providing the heat.
If one of the 120's is gone then its one side of a circuit breaker or a fuse thats blown.
If all voltages are present...then you'e looking at an element or thermal protection device on the element side.
Hope this helps.
Jul 18, 2011 | Dryers
I WANT TO KNOW HOW TO TEST A WALL SOCKET WHAT SETTING SHOULD I SET IT TO
To check for voltage, select VAC on meter. electric ranges require 240 vac. common to L1 should read 120 vac, same for common to L2. L1 to L2 should be 240vac. Gas range only needs standard 120vac.
Mar 24, 2011 | Kitchen Ranges
I have a whirlpool front loader...not sure of the style number at the moment...but about a month ago the clean pump light came on...so my partner and dad drained the filter at the front down the bottom and...
did they remove the bottom panel and remove the middle part of the pump and clean out the pump?unplug it,with the bottom off reach up and at the bottom of the door lock assy. there's like a tear drop shape tab made of plastic that you pull down,you'll hear a click and the door can be opened.to clean the pump,with a shop vac vac out all the water in the tub,then go to the pump,turn the middle piece counter clockwise until water starts to leak out,vac it up as it leaks out until it stops and then turn the middle piece all the way and remove it,you can stick the vac in the pump and vac out anything that's in there and then stick your finger in and feel around to make sure nothing is stuck in with the impellar,put the pump back together,add some water and put it on drain spin,if the water drains out you're all done if not you have to install a new pump.part number 280187 and it's around 120 sollars
Feb 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
E20 Error sign
Plug off the mains. First drain out all your water by lowering the exit hose into a bucket or drain. You have to look for screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
May 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Error code E21
E21 Water not pumping out fast enough. .
Check for Restriction in drain pump or hose...
No restriction. Go to step (2).
2. Start the washer and check for 120 VAC at the
drain pump. if no voltage Replace the control board.
120 VAC. Remove the pump and check for
blockage. If blocked, remove the restriction,
if not, replace the pump.
Aug 23, 2008 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Dryer LER7646EQ1 Not heating
If your drive motor is turning, but your timer and heating circuits are not working, it sounds like you could be missing one leg of your 220 service. The dryer timer and heating circuits utilize the full 220 from the receptacle, while the drive motor only uses 120 VAC. Unplug your dryer and check the voltage at the wall receptacle. You should read 220-240 VAC across the two hot leads (these are the two large slots). The wires are BLACK - L1 & RED - L2. If you only read 120, check each slot to the NEUTRAL slot (white wire) to determine which one is missing. Chances are, you may have a break in the L2 (red wire) line. Here's the wiring scheme depending in which type of power cord you may have:
3-prong color code:
BLACK (HOT – 110-120VAC) – May also be referred to as L1
RED (HOT – 110-120VAC) – May also be referred to as L2
WHITE (NEUTRAL – 0VAC) – Usually grounded to the equipment frame via a jumper wire or metal strap.
4-prong color code:
WHITE (NEUTRAL – 0VAC) – DO NOT ground to equipment frame.
GREEN (GROUND) – Attach to equipment frame.
Please doublecheck and let me know. If your source voltage is correct, perform continuity checks from the end of the power cord to the terminal block in the back of the dryer. Inspect for any burned or broken wires. If you are not able to isolate a problem at this point, please post back and let me know. I can assist you further. I hope this helps.
Aug 13, 2008 | Dryers
Frigidaire Affinity ATF7000E Front Load Washer Logo
182 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
