Question about HP Photosmart R707 Digital Camera
Red lite on when battery inserted, no power on. Reset no effect.
If I remove the battery for 15 mins or so then reinsert it, the camera will power on (date & time display on LCD) but within a couple of minutes, the LCD starts to flicker then the camera hangs.
I can repeat the above with the same results every time.
hope you can help
thanks
Al
  • 43 Answers
Try to connect the camera to the charger. If it works, you need to change the battery.
Posted on Jan 29, 2010
How to reset sony dsc-w5?
  • To reset turn off the camera and remove the battery. Hold down the power button for 15 seconds then release. Reinsert the battery pack and power on the camera.
Feb 25, 2015 | Sony Cyber-Shot DSC-W5 Digital Camera
HP Photosmart M627
Try first removing battery and putting back.
Aug 01, 2008 | HP PhotoSmart M627 Digital Camera
How to reset sz-15?
With digital cameras there are no things like reset buttons or procedures. Just switching off and on, or removing the battery and reinserting it, will restart the camera like a cold boot from a computer.
When you touched the lens barrel, while it was moving, and the camera acts strange. Switch it of, remove the battery and the memory card. then reinsert them and switch on.
May 01, 2014 | Olympus STYLUS SZ-15 Silver Digital Camera...
I need reset my cannon sx 130, how i can do?
Remove the battery out of the camera for 15 mins, then insert the battery and go to the camera's menu setting and set the date and time.
Feb 26, 2012 | Canon PowerShot SX130 IS Digital Camera
I had just completed downloading my pictures and movies from the camera unto a dics. as i always do, after i completed downloading, i delete the pictures from the camera. at the completion, the camera...
Do you remember to use the "safely remove hardware" function when you disconnect? Most times, nothing goes wrong but it only takes once for your current problem to happen. My advice would be to reset the camera. The "reset"command can usually be found in the camera menu.
Jan 13, 2011 | Cameras
Screen goes black shortly after turning on
I'm sorry that the screen goes black shortly after turning on the camcorder. I suggest that you perform a manual power reset and check the operation. Follow the steps to perform a manual power reset:
  1. Turn off the camcorder.
  2. Disconnect AC power adapter.
  3. Remove the battery pack.
  4. Remove the lithium button-cell battery.
  5. Move the POWER switch to the CAMERA position for 15 seconds.
  6. Move the POWER switch to the OFF position.
  7. Reinsert the lithium button-cell battery.
  8. Reconnect the AC power adapter or reinsert the battery pack.
  9. Turn on the camcorder.
Jan 04, 2011 | Sony Handycam DCR-SR42 Camcorder
WHERE IS THE RESET BUTTON IN THIS CAMERA
The Camera does not have reset button. You can reset the Camera by either using the Initialize option from the Menu or removing the battery.
You can find the Initialize option under the Setup Menu of the Camera.
To Power reset the Camera, remove the battery it, press and hold the power button for more than 15 seconds and then reinsert the battery.
Thanks for understanding.
Dec 18, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
When i try to turn my camera on it flashes a small red light and then it won't turn on, how do i fix this?
The Red indicator flashing in the Camera may be the Access Lamp or the Power Lamp. The Access Lamp is located below the Control buttons and the Power Lamp near to the power button. If the Access Lamp is flashing, it indicates that the Camera is accessing the Memory. Do not remove the Memory Stick or Batter while the Access Lamp is lit.
If the Power Lamp is flashing, it indicates that the Camera is turned on. If the Lamp is lit in Red it shows that the Battery is not having enough charge. Insert new batteries or charged Nickel-Metal Hydride batteries to resolve the issue.
You may also try power resetting the Camera. To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally. If the issue persists, service may be required.
Thanks
Oct 21, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
Htc not turn on, red light on
Remove the battery from the mobile, press the power button, for 30 seconds.
Re attach the charger , switch on the phone. If it turns on switch it off again and reinsert the battery and check.
If none of the above steps work, you would have to take it in for repairs as there could be a problem with the power supply inside the phone , that would require special tools to open
Thanks
proton
Oct 11, 2008 | HTC P3300 Smartphone
Cassette problems
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Nov 03, 2007 | Sony Handycam DCR-HC42E Mini DV Digital...
HP Photosmart R707 Digital Camera Logo
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
