Back to:
Tags:
GE JEB1095 800 Watts Convection / Microwave Oven
Not heating (by 3 users)
posted by MSnChrist on Nov 21, 2007
unit was making a funny noise and not heating, replaced magnatron, unit no longer making the noise, but it is still not heating. Any ideas?
Comment by MSnChrist, posted on Nov 21, 2007
Is there a schematic around that I could look at? On the magnatron, there is a cable that comes to the high voltage cap, the cap has two terminals for each one, does this connection go on the bottom of the top one, or the two of the bottom one? The ground cable is connected to the bottom terminal?
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by dyna05, posted on Mar 14, 2008
I also have a JEB1095 and it is about 5 years old. The unit runs (light comes on, Timer works) but it does not heat anything.
What could the problem be?
Comment by rdzj, posted on Nov 23, 2007
Our unit seemed to work when heating a cup of coffe (light came on and timer worked) but when done, the coffee had not heated. Tried again and it made a nasty noise. Our warranty covers the cost of the magnatron (up to 10 years), but not the service call to install it or anything else that may be wrong. Unit is 5 years old. Should we try to fix or replace?
Best Solution
Helpful (85)
bluenadas
Rank:Guru Guru
Rating: 85%, 223 votes
If the maggie went it's very plasible that it took out the Cap and/or HV diode with it.
Comment by bluenadas, posted on Nov 21, 2007
I currently don't have a schematic but the lead from the maggie should connect to the terminal opposite the ground. The maggie uses it's case as a ground and only one lead provides High Voltage.
Rating Locked! (?) MSnChrist has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on not heating:
I don't want to Accept this solution
Can you Help with these Microwave Ovens problems?
Microwave Ovens
It's a Panasonic Inverter SD986. The glass tray will start...
Microwave Ovens
few weeks ago the clock started going off and on. Then...
Microwave Ovens
ge profile microwave doesn't seem to be heating food real...
GE JEB1095 800 Watts Convection / Microwave...
Unit loses power after a few seconds. When power comes...
The convection part of the oven is not heating properly....
Loading problems.
Repair Service
Find Microwave Oven Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
