Question about Craftsman Garden
Lawn mower blades breaking 46'' cut , have not been hitting rocks, stumps or other objects.
  • 112 Answers
Possibly the wrong blades, (to long and hitting each other), or installed wrong or generic blades that are defective. Or bad spindle bearings allowing blades to move and hit each other. Check the blades for dents or nicks.
Posted on Jul 25, 2009
Ltx
Contact mtd.com help desk. Tech help can get you to the right parts to make needed repair. Most likely it is your blade spindle assembly that has been bent allowing belt to slip. It is not that diifcult to replace.
Jul 18, 2014 | Cub Cadet 2012 - LTX 1046 - 21.5 HP...
Loose blade
loose the lock washer before you cut your own feet off or kill the neighbor with blade flying off ! Put bolt in and tighten make sure alignment pins on blade are where they are supposed to be . make sure no grass is caked up around any of the blade or drive shaft
Jul 26, 2013 | Mtd 22" Yard Machine Push Mower
My blade keeps coming loose after hitting a rock on lawn mover
is the bolt stripped so it wont tighten?
Is the threaded hole on the Crankshaft of the mower cracked
Compression lockup on warm start
hi
did you hit any rocks or stumps? if your blade hit something it will sheer a key on the flywheel and will throw the timing out all is needed is that 2 dollar key if u can take it apart a good sign when the timing is thrown out like that the rope likes to rip your arm off
Joe
Sep 10, 2012 | Toro Power Lawn Mower
When mower is cranked, the enigine spits and sputters and balck smoke comes out from the side.
Did you hit something hard with your mower; like a stump or a rock? It sounds like your timing may be off. There is a key under the flywheel that is designed to break off if you hit something so that it doesn't bend the crank shaft on your mower. If that key breaks off, your mower will go out of timing and spit, sputter and backfire when you try to start it. Best of luck to you.
James
Aug 25, 2011 | Poulan Pro 22inch 625 Series Briggs ...
Runs rough and kicks back when pull starting
The timing may be off. Has this mower ever hit anything while running. There is a small aluminum key that keeps the engine in time (flywheel to magneto) and it breaks if the mower blade hits an immovable object (rock, tree stump, meteorite etc.) The timing will be skewed and symptoms like yours will result.You can check the flywheel key by removing the cover on top of the mower and the starter/recoil unit.The key is in a slot on the top side of the crankshaft and fits a notch inside the flywheel. Look carefully. If it is sheared, the notch in the flywheel will NOT be lined up with the notch in the crankshaft and a new key will need to be installed after removing the broken one.
May 04, 2011 | Briggs & Stratton Garden
I hit a rock with my push lawnmower. The
Oooh boy, I know you bent the shaft, but why it is blowing oil out the carb, I don't know if I would even bother with the blade, you could go buy the same mower, then you would have some parts. Unless you just bumped it hard enough to throw oil around in there, it might settle down, but it is a long shot. I hit a stump once and bent the crank, it was lights out for that mower. Hope this helps.
May 07, 2010 | Mtd 22" Yard Machine Push Mower
My Cub Cadet i1042 tractor shuts off when the blade is engaged. This happened after I ran over a ***** and/or stump. Every time I try to engage the blade the engine shuts off.
Check for bent blade against deck housing.Possible you bent something on mowing deck,check all spindles and pulleys.You could have something hung on blade and making contact with deck. Rarely will the motor be hurt from hitting object on rider.
Apr 24, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
170 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
