Question about RIM BlackBerry? Curve 8330 Cellular Phone
1x display and can't reeive emails or send,no blackberry service
1x display on the 8330 and can't receive emails or send, service provider/reseller doesn't know what problem is so here I am without access to/from my clients...good news..my problem has been escalated to higher level although everyone went home last night, catchya in the AM they said....service??? I don't think so !!!!
HOW DO YOU COMMUNCATE BLACK BERRY SERVICE PROVIDER TO RESET MY EMAIL.
Troubleshooting Email on a BlackBerry smartphone Troubleshooting Email on BlackBerry smartphone
ARCHIVED: What should I do if my BlackBerry cannot send or receive email? What should do if my BlackBerry cannot send or receive email
Cannot Send or Receive Email Messages Blackberry TroubleshootingCannot Send or Receive Email Messages
How to fix internet and email on your BlackBerry smartphone
Aug 24, 2016 | Cell Phones
Looking for free unlock code to my blackberry curve
No one can give you unlock code for free. i suggest you if you get free unlock code . do not try this code. because it's not safe for your Blackberry. it may be hard lock your blackberry. there are other options to unlock your Blackberry Curve safely . call your service provider ask him your Blackberry Curve Unlock Code. or second option is buy your Blackberry Unlock Code from third party. these two option is safe and trusted.
I hope this will help you :)
Oct 20, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
How to get internet after whiping a blackberry 8330
go to settings, options, advanced options, host routing table, press the menu key and select register now. If it says it will send when data is available then go back to home screen and select manager connections, mobile network options, and switch data to "on". If data is already on then pull your battery while the phone is on and leave out for 5 full minutes. Then replace battery. Your phone may be froze for a few minutes while it is receiving all the data service books.
Feb 04, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
I have no service to my blackberry curve 8330, i checked under manage connections to see if "Mobile Network" has a check mark next to it and it does.... what could be the problem??
Do you have 1XEV in capital letters?
If not dial *228 and press Green button and try following option again to PROGRAM YOUR PHONE.
1X - means you have a cell phone plan
1XEV - means you have a cell phone and a data plan.
if you don't have 1x, you need to *228 again.
Nov 30, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Losing call connection - cannot receive calls
This could be because of the network issue you need to get in touch with the service provider.
Aug 02, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
My blackberry curve has a 1x but full bars and wont let me txt call or anything how can i fix this
the 1x refers to your data signal strength. It must say 1XEV to have full coverage. Full coverage allows you to email, txt, etc. It might be the area you are in but if travel around and no changes, check you connections. "Manage Connections", the icon is an antenna, make sure your network check box is checked. if so, scroll down to "mobile network options" and make sure your "data services are on". If it is on, power down the phone, and remove the battery for minimum 2 minutes, then put battery back in and turn on. if you data is still only 1x contact your service provider.
Jul 30, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry cant receive pics from nokia via bluetooth
Email the picture.... and then open the email on your blackberry.... that should work if the nokia 6680 has Email capabilities...
Jun 02, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Get error messages when sending or receiving MMS on Blackberry
YOUR BB MMS SETTINGS IS CORRUPTED SO CALL YOUR SERVICE PROVIDER AND ASK THEM TO SEND THE MMS SETTINGS TO YOUR BB.
Apr 28, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Blackberry curve 8330's blocking mobile network
Sounds like you're in a dead zone. If not then ...
Check in the upper left corner... IF:
1x = you are not connected to any data at all - No emails, text, internet will work send/receive.
1xev= you're connected to data but not blackberry usually the same as above though sometimes you might get lucky and receive only text/pix messages.
1X= Phone calls only. Usually no data (email, text, web, etc)
1XEV = everything is connected and you should be working fine.
If you have 1XEV (upper case and lower case matter ALOT...everything should always be UPPERCASE) and you're still having that problem then go to:
options> advanced options> host routing table
In the host routing table click the button to the left of the roll ball (called the blackberry button) and click on "Register now" and just leave the phone alone for a minute so it can register all your service books again. Then try the web again.
If all else fails pullthe battery and try again ..> Still no good? Call your carrier.
Hope this helps
Mar 16, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
RIM BlackBerry? Curve 8330 Cellular Phone Logo
193 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
