FOLLOW this steps and fix it. Merry Christmas
Spark Plug
Every chainsaw relies on a spark plug to ignite the air-fuel mixture for proper combustion. Over time the electrode on the spark plug will burn away and the engine does not start. If the engine does not start, remove and inspect the spark plug. If there is any doubt that the plug is working properly replace it.
Enter your model number to see parts for your chainsaw.
Help me find my model number
Carburetor
If the chainsaw won't start, the carburetor might be clogged or have bad fuel in the float bowl. If old fuel was left in the chainsaw for a long time some of the volatile ingredients may have evaporated, leaving a thicker, stickier product that is more like varnish or shellac. This sticky fuel can clog up the small jets and ports in the carburetor and it can be difficult to burn making it hard to start the engine. The only solution is to drain the old fuel from the float bowl and thoroughly clean the carburetor with carburetor cleaner. If that isn't effective, replace the entire carburetor.
On - Off Switch
Chainsaws are equipped with an on/off switch. If the chainsaw does not start, this switch might be defective. Check the switch for continuity. In the on position the switch should have continuity.
Safety Switch
If the chainsaw does no start, the safety switch - or throttle control switch - might be defective. If the switch isn't engaging with the throttle it won't provide enough fuel to the engine and the engine does not start.
Ignition Coil
If the chainsaw engine does not start the spark plug may not be getting voltage. Power to the spark plug is provided by the ignition coil. The ignition coil is mounted next to the flywheel. As the flywheel spins an electrical current is induced by the ignition coil. If the ignition coil is defective it will need to be replaced, it is not serviceable.
Rewind Spring
The recoil starter assembly has a rewind spring which spins the pulley backward to rewind the starter rope. If the rewind assembly is broken the rope will not rewind and the engine does not start.
Recoil Starter
If pulling the recoil starter assembly handle doesn't engage with the engine and the engine does not start. Repair or replace the recoil starter assembly.
Recoil Starter Pulley
The recoil starter pulley winds up the starter rope when not in use. If the recoil starter pulley is broken or stuck it may not rewind the rope and the engine does not start.
