SOURCE: remote no longer controlls recorder
Remote can be used to control more than 1 recorder, on the remote press enter and 1 simultaneously, this should switch the remote to control dvd 1.
SOURCE: recording
if u mean vcr. dvd burner combo, yes u can, , u can also tranfer from any video source such as a cable box, camcorder anyting that has a video out to your video in on your burner will work
SOURCE: How to record a VHS tape to a DVD disc
Read your manual first to make sure the unit will do this.If it does chances are it won't record unless it has a decoder built in.Most VHS tapes have macrovision protection that prevents you from copying them.It will however,record homemade VHS tapes.There are decoders out there you can buy to enable you to copy VHS tapes.
SOURCE: durabrand dvd player code
Here is the code for the dvd player
0449, 0405, 0446
code for the tv/dvd combo
0189, 0135, 0157, 0153, 0254, 0458, 0217.
website to find the other codes if you need.
http://www.jascoproducts.com/support/download-files/RemoteCode-4-digit.pdf
have a good day walmart shoppers.
SOURCE: Need code for Viore TV to program LG RC897T DVD/VHS Recorder
I believe Viore is the same as Samsung. I only noticed this by accident as I bought a Viore TV and my friend bought a Samsung and I noticed both remotes were identical. I tried the Samsung codes and the remote worked. Good luck! Kevin
