Question about Westinghouse LTV-32w4 32.02 in. LCD HDTV
My Westinghouse LTV-27w6-HD picture is scrambled periodically
The picture on the TV is fine when I first turn it on but after 5-10 minutes it will start to scramble periodically, being totally unviewable. None of the horizontal or vertical adjustments seem to clear this up. This has been going on for months. The TV is about 3 years old but it is turned on only about 1/2 dozen times during the year so it really hasn't had much use. I would appreciate any help you could offer. Not sure if I should just toss the TV and buy a new one or try to get it fixed.
  • Westinghouse Master
  • 5,568 Answers
Before you bother to read the text below, you might be better served looking at this thread:
Westinghouse troubles
If you aren't nauseated yet, continue with my original reply:
If the picture seems 'pixelated,' broken up into randomly sized and placed blocks, then it is losing synchronization with the digital signal coming in. This is certainly repairable and may be due to lousy assembly quality rather than a failed part. Most of our modern sets are assembled by robots but there is a degree of manual soldering still to be done and this can result in 'cold' solder joints that can fracture and fail due to heating and cooling of the innards of a set.
Unfortunately, unless you have a semi-retired TV service man in your neighborhood who is already financially independent, the labor costs could run fairly high for this kind of service since it requires methodical searching of the circuitry and could eat up some time.
Posted on Jul 24, 2009
TV turns on screen is fine. Screen goes black
The problem can be bad caps in the power supply, or the backlight inverter board is bad, depends on how much you know about repairing electronics, you may want to look inside first for bad caps. You can look for replacement boards here: www.shopjimmy.com
But report back what you see inside first so we can you further. My had scrambled picture after warm up, yours will more likely to have this problem later on also. http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Jan 31, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse 27" lcd hdtv
Hi
what do you mean? The picture is running up vertically?
Jan 27, 2008 | Westinghouse LTV-27w6 27 in. LCD HDTV
Westinghouse LTV32W6HD. Turned it on and video is
If the picture goes bad after about 15~30 minutes, then more likely to be bad LCD controller bd. See sample of the failed LTV-32W3HD here: http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Parts: http://www.shopjimmy.com/catalogsearch/result/index/?q=LTV-32W6HD&limit=200
You can try running the TV with the back open with a small fan blowing in the back to keep it cool just to verify that it is heat related.
Jan 05, 2010 | Westinghouse LTV32W6HD 32 in. LCD...
I have a Westinghouse LCD TV model LTV 27W6 HD. TV is 1.5 years old and once TV it turned on everything works fine. After 10 - 15 minutes of operation the video changes to colored horizontal lines. The...
TV should be looked at by a qualified technician. The problem could be in the Power Supply PCB, Main PCB or Tcon PCB. Using cold spray is the quickest way to determine which board is faulty.
Sep 09, 2009 | Westinghouse LTV-27w6 27 in. LCD HDTV
42" lcd flashes picture
problem in the hdmi source......
Jun 03, 2008 | Westinghouse LTV-27w6 27 in. LCD HDTV
Westinghouse lcd tv ltv-27w2 no picture or sound
power supply first one...second one input hdmi pcb defective..
Mar 06, 2008 | Westinghouse LTV-27w6 27 in. LCD HDTV
Flickering/pixelating screen on LTV-27w6 HD after 30 minutes.
Sound like dry goint on Power Supply bord. I had the same problem and resolder most of the parts of the power supply and TV was ok.
Dec 22, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Model LTV-27w2 westinghouse
The tv got a heat sensor, the only way to fix tv , if you are a tv tech, is to buy a bottle of "freez it" spray small sections of tv in side. It will be clearly where the fault is if you spray correct part that give trouble. Replace that part and Tv will be Ok.
Nov 04, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Westinghouse LTV-27w6 27 in. HDTV LCD
Have you unplugged the set from AC power? Not just 'turn it off' but physically remove the power cord for 1 minute. Often this 'resets' internal circuitry when a 'power off' will not.
May 14, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Westinghouse LTV-32w4 32.02 in. LCD HDTV Logo
947 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
