Question about Campbell Hausfeld 1,350 Psi Electric Pressure Washer With Auto Detail Kit #PW1350
How do you get the cleaning solution to be incorporated into the water stream
    Sergeant:
  • 384 Answers
One end of pick-up hose is in bottle of cleaner the other end is attached to the "T" connection of the Washer. The spray head is set for low pressure by sliding in or out. Dispensing only happens at low pressure.
Posted on Jul 24, 2009
Decarbonising method
Introducing a water spray continually into a running engine's air intake will decarbonize cylinder head, given enough time. You will struggle to keep the engine running but if you ar epatient, it can be done.
It is commonly known that a defective cylinder head gasket that leaks engine coolant into a cylinder will clean that cylinder head and piston to "like new" condition.
Some performance engine enthusiasts incorporate "water injection" systems to generate more horsepower. Water flashing into steam increases cylinder pressures and, therefore, engine torque and the cylinders get "steam cleaned" in the process, which helps removes carbon deposits.
Nov 26, 2014 | Computers & Internet
Why does the water splash around the cup rather than stream out ?
Check the removable insert that pierces the K-Cups. It may be dirty from coffee residue and needs to be cleaned. The entire assembly turns and lifts out but be careful as the piercing needle is SHARP. After cleaning, try a new k cup and see if it works ok.
Sep 12, 2014 | Manufacturer KEURIG Brewer a: Mr. Coffee...
What is a drinking fountain?
A drinking fountain, also called a water fountain or a bubbler, is a fountain designed to provide drinking water. It consists of a basin with either continuously running water or a tap. The drinker bends down to the stream of water and swallows water directly from the stream. Modern indoor drinking fountains may incorporate filters to remove impurities from the water and chillers to lower its temperature. Drinking fountains are usually found in public places, like schools, rest areas, libraries, and grocery stores. Many jurisdictions require drinking fountains to be wheelchair accessible (by sticking out horizontally from the wall), and to include an additional unit of a lower height for children and short adults.
Jul 03, 2013 | Water Dispensing & Filtration
Faucet makes noise when turned on but produces only a tiny stream of water
sounds like u got some kind of blockage in it take apart and clean
Aug 13, 2012 | Kohler Plumbing
Small stream of water on kitchen faucet
The ruber seat inside the forcet needs replacing or it is getting stuck turn off your main water suply and remove the top half of the tap & inspect if ruber is hard,flatend,cracked or perished replace if not give the insides a good clean and reasemble.. hope this helps :)
Oct 21, 2011 | Plumbing
Cleaning dishwasher console contacts
It is not possible to clean. If it is made of touch mat material, you can not open. There are few designs which may incorporate plunger switches. but I doubt whether these are used in these dish washers. ( or any water related wash machines)
If it is working OK do not disturb!!
Sep 23, 2010 | Maytag Dishwashers
Low stream
these faucets have a single handel, and have a cartage that can be taken out and cleaned. Low water pressure is caused by minerals in the water to build up in the cartage and slow down water flow.
Mar 28, 2010 | Kohler K-10416-BN Fort½ Single Control...
Water is streaming out the bottom of my fridge on freezer side
the water should evaporate when hitting the coils,maybe coils s/b cleaned (dusty)
Mar 17, 2010 | Refrigerators
Espresso water is dripping not streaming
Try replacing the brew solenoid on the grouphead. Its the black or blue electrical box assembly connected to the side of the group.
Apr 17, 2009 | Coffee Makers & Espresso Machines
Campbell Hausfeld 1,350 Psi Electric Pressure Washer With Auto Detail Kit #PW1350 Logo
312 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Mike Squire
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
