Question about Fisher and Paykel DEGX1 Electric Dryer
Lid latch is not working . Dryer stopped working, reset button in front and then the latch light said NOT LATCH or something like that.
  • 6,784 Answers
HI. simply replacing the lid switch will correct this issue here. either the wires have separated from there contacts or, the switch has failed.
Posted on Jul 24, 2009
Whirlpool front load dryer will not start
Does your dryer have a reset switch on the back, usually a small red button, if it does press this and ten test dryer starts again.
Dec 21, 2012 | Whirlpool Dryers
Installed new door lock still have e27 error code
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
You can manually release the latch by removing the lower panel (Torx fasteners, I think) and finding a wire lanyard that releases the latch. However, I had read that there was a diagnostic code that could be used to reset the latch solenoid via the control panel.
There is no service manual available on line, as far as I can tell.
Here is what worked...
1. Set the knob to off.
2. Hold down both the Spin Selector button and the Allergy Rinse button simultaneously.
3. While holding these two buttons down, rotate the knob one click to the left, to the "cold" position.
4. At that point, the display will show a diagnostic code and the unit will enter a self-test mode. In my case, the solenoid latch started clicking repeatedly. I pressed the Spin Selector button once or twice, which resulted in the display of new codes and then the release of the latch.
Oct 15, 2012 | Bosch WFVC6450UC Front Load Stacked Washer...
Dryer worked fine yesterday. This morning it would run like always but would not heat. Machine is only probably (3 1/2) yr.s old
Hello there
The overheat protector is behind the machine's front panel, on front of the heater box beneath the drum. Access thusly: UNPLUG the dryer. Remove the lid. Carefully pry out the two lid bumpers at either side near the front corners. Remove the two screws beneath. Raise up the top deck, have an assistant hold it up. Remove the two screws at the edge of the front panel. Spread the sides of front panel just a little so the tabs that latch into the door grabber can clear. Pull the front panel forward and lift upwards to remove it. Be careful of the ground wire that clips to the lower edge of the panel. Shouldn't be necessary to remove the clip, you can turn the front panel aside enough to access the overheat reset button. Locate the reset button on the overheat thermostat and press it. The reset button is a large red button on electric models, but gas models have a small black button per pictures I've seen. The button should "click" when pressed if it was tripped. If so, reassemble and check if the machine now heats. It the overheat didn't seem to be tripped and it still doesn't heat after pressing the reset button, then something else is at fault. and yes the heating elements are normaly the first things to go out on these after a few years this is normal
Mar 01, 2011 | Fisher and Paykel SMARTLOAD DE62TG1...
Door latch assembly for maytag neptune MAH5500BWW
The plastic cord is for opening the door if the door latch fails. It should connect to the door latch mechanism and the other end should be routed to the soap dispenser corner. There should be two holes for the cord to go into and out again. The idea is to remove the soap dispenser lid / bezel to get access to the pull cord if needed.
Hear the new Neptune bearing song at http://www.neptunehelp.com.
May 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Dryer stopped working after working w/door open or closed
Sounds as if the door switch/latch had stuck.the smell was probably a small short. try unplugging unit. But I would imagine you need door latch/switch replaced
Feb 06, 2009 | Malber TD700 Electric Dryer
Bosch dishwasher won't latch
No you did good in ordering a latch ,that is a common issue i find with the bosch d/w, for no apparent reason the latch locks itself with the door open. Look at the door where the male part of the latch goes into the door, you will see that is locked. if you take it apart and manually unlock the latch u stand to break it. Again you did good on ordering the latch.
Jan 09, 2009 | Bosch 36 Inch Pyramid Chimney Hood - Black
Washer lid will not open after cycle
suspect bad lid latch there is usually a 4-6 delay after washer stops before latch will release anything much longer proably lid lock ..remove 2 screws bottom front panel front drops and comes off switch is on right remove screw each side of top lift up 2 screws hold latch in place remove wires and screws and replace latch
May 22, 2008 | Kenmore 98702 Stacked Washer/Dryer
Whirlpool Duet Front Loading Washer Won't Turn On
mains filter blown door lock fail main pcd fail appliance doctor
Jan 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Fisher and Paykel DEGX1 Electric Dryer Logo
107 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
