Question about Kitchen Appliances - Others
My doorbell started buzzing 2 weeks ago, so I bought a new door bell. Now it won't even ring and is still buzzing. What did I do wrong and how can I fix it?
  • janet4duke Jul 30, 2009
    If it's the transformer, then why does it ring when I push the other doorbell? BUT, when I hit the wall, it stops buzzing...for a little while. Very odd to say the least.
    President:
  • 1,273 Answers
Chances are that it is the transformer.
--W/D--
Posted on Jul 24, 2009
Phantom bell rings on Siemens wirreless door bell chime jsjs-204, I do not have instructions
You may need to change the frequency of the chime. In this model, you need to remove the batteries from the receiver unit and wait for a while. Then replace the batteries. The doorbell unit should automatically set itself to a different frequency once you press the button, which will(hopefully) solve the problem.
It seems impossible to find the instruction manual for the doorbell. But see http://oddsnsods.net/blog/?p=68 who had a similar problem with a different Siemens model, which works on the same principles. (I can't seem to be able to remove the battery from the door bell unit on the jsjs204, but it reset itself after changing the batteries in the receiver).
Nov 01, 2011 | Desa International White Wireless Plug In...
I have a Siemens Wireless Doorbell (Model No. JSJS-204. It started making ringing tones when no one was pushing the doorbell. I replaced the battery thinking that it was wearing out. Now the unit does not...
Hi
To fix the issue you need to remove the batterys from both the bell push and the bell unit for 10 mins, then replace the batterys and then push the bell push so it can switch channels and be different from the house down the road
Sep 17, 2011 | Vacuums
Have had major snow storms in the past few weeks. Installed, prior to storms, new door chimes that worked. Since the storms, neither the front nor side bells function. The bell button has a light on...
Most times, doorbell problems are button, especially since indicator light shows you have power.
Take off front doorbell button and see two wires.
These wires are low voltage and safe to touch.
Use screwdriver and touch both screws together, or remove wires from button and then touch two wires together.
If doorbell rings, then replace button.
If bell still doesn't work then scratch two wires together and look for static-type spark that says wires have power.
If wires have power, and you crossed both wires and bell didn't work, then new door chime is suspect.
If wires do not have power, then transformer is suspect.
Open following link to see example transformer:
http://waterheatertimer.org/images/attic-transformer10.jpg
Transformers are located in basement or attic.
Scratch a wire across both screws on transformer and look for static-like spark.
If no power, then check circuit breaker.
Home centers sell transformers in the doorbell section. They are 12 and 24 volt. Check markings on old transformer.
If transformer has power, then new door chime is suspect.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 12, 2011 | Garden
How do i fix my doorbell
99% of the time, you need a new doorbell button
Also check if any circuit breakers are tripped
Check GFI breakers in baths and kitchen
Real-estate lady answer: buy a new doorbell button and connect 2 wires on back of new button.
Doorbells are low voltage and not dangerous.
If screws are loose in the holes, break off toothpicks in hole so screws have something to bite.
You need small screwdriver:
Repairman answer
Doorbell problems have 3 parts
1) The button
2) The chime or bell located in house
3) The 12V or 24V transformer located in attic or basement
4) rarely the wiring because it's low voltage and does not get hot
1) start at the button.
Remove button from wall
There are two LOW-voltage wires on back of button
Remove 1 wire and touch other wire, copper to copper
Does doorbell ring? Do you see a spark?
If bell rings, then button is bad
2) Chime or bell doesn't ring when button wires are crossed
Take cover off chime
The button works, so have helper push button while you're looking at chime
Can you hear any noise? Have helper push button on-and-off
Chimes have 2 or 3 wires >>> 2 wires if only front door has button, 3 wires if back door also has button
Take one wire loose and scratch it across each of the other wires
Remember front button is held down (or front button wires are twisted together)
Can you see a spark when wires are scratched together?
Try this with more than one wire ... but don't mix up location of each wire
If you are getting a spark, then chime is getting power, but it's not working
Replace chime
3) Transformer in attic or basement looks similar to this:
Use a wire and scratch across both screws to see if you get a spark
If you get a spark ... and the crossed wires dont ring the chime... and there is no spark at chime, then there is a bad wire
If no spark at transformer, then check circuit breaker
At last resort, but new transformer at Home depot in the doorbell section near light department
Oct 05, 2010 | Garden
Doorbell Byron SX81R keeps ringing different tunes when no one there
I have the same thing happening, it’s your neighbours, they have a similar door bell to yours but set with a different chime. When someone presses their bell yours rings too hence why when you go to the door there is no one there. It was driving me mad!!
Nov 15, 2009 | Kitchen Appliances - Others
New wired Heath/Zenith doorbell buzzes until disconnected
it sounds like you have a bad push button . if the wires where crossed you would most likely have this problem as soon as you turned on power .
Mar 15, 2009 | Honeywell Electrical Supplies
Kitchen Appliances - Others Logo
737 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
