Question about Uniden MC1010 (54 Channels) 2-Way Radio
Power cord ?
The power cord that goes into the radio has 4 wires , a red-black-white and another black,what are each of these 4 wires for ??
    Problem Solver:
  • 14 Answers
What kind of radio is it? Looks like a Marine Band radio. Do you still have the owner's manual, as it will show the purpose for each wire. If you don't, write or email the manufacturer to get one. Most Amateur and Commercial gear simply has a red and black wire to get DC power to the radio. Sorry I couldn't answer your question better, but I've never come in contact with a four wire radio.
Longshorts.
Posted on Jul 24, 2009
95 Jeep Wrangler wiring harnesses broke down by color to show where each wire goes to
Car Radio Constant 12V+ Wire: Red/White Car Radio Switched 12V+ Wire: Purple/White Car Radio Ground Wire: Black Car Radio Illumination Wire: Blue/Red Car Radio Dimmer Wire: Red/Black Car Radio Antenna Trigger Wire: N/A Car Radio Amp Trigger Wire: N/A Front Speakers Size: 4? x 6? Speakers Front Speakers Location: Dash Left Front Speaker Wire (+): Gray Left Front Speaker Wire (-): Yellow Right Front Speaker Wire (+): White/Red Right Front Speaker Wire (-): Brown/Red Rear Speakers Size: 4? Speakers Rear Speakers Location: Rear Roof Left Rear Speaker Wire (+): Gray/White Left Rear Speaker Wire (-): Brown/White Right Rear Speaker Wire (+): White/Black Right Rear Speaker Wire (-): Brown
Oct 04, 2016 | Crown Jeep Wrangler yj 95 94 93 92 91 90...
Where can I find a service manual? I need to change the 3 wire power cord to a 4 wire cord.
first install the RED & BLACK conductors on the cord to the L1 & L2 terminals or the 2 outer terminals on the 3 position terminal strip on the dryer,next take the WHITE ( NEUTRAL) wire on the cord connect it to the "N" terminal on the dryer terminal strip usually located between the 2 phase wires RED & BLACK so the terminal strip will be(RED-WHITE-BLACK) red & black can go on either outer terminal as they are not polarity sensitive due to the A.C. current, then the GREEN on the power cord goes to any metallic portion on the dryer case
Aug 23, 2012 | Maytag ADE7005AYW Dryer
I have a general lee cb with a 4-pin standard mic. the wires in my mic cord broke at the plug. does wnyone know how to wire this type of mic back and what color wires go to the correct pin?there are 6...
Here are the Pin outs for different mics that will work with your radio. If a wire is not listed then you cut it off. It's best to keep the wires as short as possible no longer than a half inch is suggested. Normally the Cobra pin out is standard for most radios.
Stock - 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - (4 wire) 1- Shield 2- White 3- Red 4- Black
Astatic - (6 wire) 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500, Cobra, CA Series - 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - (4 wire) 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI - 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta - 1- Shield 2- White 3- Brown 4- Green
Turner - 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Jul 12, 2011 | Magnum DeltaForce CB Radio
We were given a HOT POINT Heavy Duty Dryer with Automatic Dry Control, Model DLB2650BRLWH, Serial No. DG241274H and had to buy the power cord to go with it. Ordered the cord from a local appliance company,...
Technical explanation: Older 240 Volt appliances use a three-wire power cord (Black, White, Red). The White wire is the "neutral" connection, which is tied to Ground at the service entrance panel. The Black and Red wires are opposite phases of the 240 VAC (when one goes positive, the other goes negative). The neutral wire is "in between", so measuring the voltage between the black or red wire and neutral would give you 120 VAC. The green wire is frame ground; the electrical code requires newer (since 2008) 240 VAC appliances to have a separate ground bonding connection to the frame; the neutral connection is not considered adequate protection for certain failure conditions.
Look for a screw head or terminal stud on the frame or sheet metal of the dryer labeled "Ground", "Earth", or one of the following ground symbols:
The green wire goes to this point. DO NOT connect the green wire to any of the wiring inside the dryer, unless it is a green wire attached to sheet metal or a bracket!
The black, white and red wires go to black, white and red terminals you already found.
Mar 17, 2011 | Hotpoint Dryers
If you are installing a new power cord on a whirlpool dryer and you have a power cord with one green wire one black wire one white wire and one red wire where do you connect the wires when the terminals on...
Good day,
The green is screwed to any convenient place on the cabinet. It's a safety ground wire.
The white goes in the middle of the block. The red and black go on either end. Doesn't matter which.
Feb 27, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer cord
Your four prong cord has 4 wires. Black,Red,Green and White.
Remove the 3 prong cord from the dryer.
The Black and Red wires go to the outside terminals on the dryer. The White wire goes top the center terminal. The Green wire goes outside the terminal cover to any nearby screw for grounding.
Jan 03, 2010 | Roper REX4634KQ Electric Dryer
Changing electrical Cord from a 3 prong to a 4 prong. I need a wiring diagram
black to black lug white to white lug red to red lug green to ground(any bolt that is attached to body of dryer)
Dec 20, 2009 | Whirlpool Dryers
Wires for the maytag dryer are black, yellow, blue and white. We need to swap the cord for a 4 prong connection - are the yellow and black the hot wires - the white neutral and the blue the ground wire????...
The red and black wires of the cord go to the outside two terminals. The white on the cord goes in the middle. The green goes to the frame. Red and Black on the cord are L1 and L2, White is Nuetral, and green is ground
Nov 26, 2009 | Dryers
How do i wire a d104 desk mic to a madison base radio
You don't mention if the Madison is a 4 pin or 5 pin also you don't mention if the D104 is a 4 wire or a 6 wire microphone so this will be rather lengthly of an answer so if I help you could you atleast do the rating for me ? So here goes 4 pin / 4 wire 1]SHIELD 2] WHITE 3] RED 4] BLACK....O.K. 4 pin 6 wire 1]SHIELD & BLUE 2] WHITE 3] RED 4] BLACK YELLOW NO CONNECTION.....Are you with me so far ? Half over 5 pin 4 wire 1] WHITE 2]SHIELD 3] BLACK 4]N/C 5] RED.....5 pin 6 wire 1] WHITE 2] SHIELD&BLUE 3] BLACK 4]N/C 5] RED.I hope this helps you GOOD LUCK and have a good day Dan.
Jul 12, 2009 | Magnum DeltaForce CB Radio
I have to change the power cord of my dryer. the new power cord has 4 pronge. the 4 wires colors are red,white,black and green. on the dryer i have only 3 wire: red,blue,black. i want to know witch wire...
  • green = ground (attach directly to the case, should be a green painted screw near the opening
  • red = hot 110v connect to the red on the dryer
  • black = hot 110v connect to the black on the dryer
  • white = neutral connects to the blue (only if the blue is in the middle)
  • neutral is always in the middle with a hot wire on either side of it.
  • also make sure all the connections are tight
let me know if you need more help Mike
Jul 01, 2008 | Dryers
Uniden MC1010 (54 Channels) 2-Way Radio Logo
167 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
