Question about Cameras
Power button on aiptekdv 3500 has slipped back into casing. cannot turn on without fiddling.still takes picture then slips back again
  • Cameras Master
  • 19,396 Answers
You need to disassemble the external casing of the camcorderto fix or replace the button.
To fix the button you will need to disassemble the camcorder casing. This is done removing external screws. On some model you also need to remove screws inside the DV tape slot. Usually there are also screws on battery slot to be removed. unfortunately the schematics for this model are not available.
Disassembling the camera is quite a delicate operation, and there is an high risk to damage the unit.
If you do not want to risk damaging the camera, try contacting this company to get a quote on repair: Repair.
Posted on Jul 24, 2009
Aspire 750 CPU case button destroyed.
I'm not overly familiar with this model...but assuming its a desktop, try this. Open the side panel on the case and try to find the back of the power button. If you can find it, and there are two wires that come directly from the back of said button, follow those two wires to where they connect to the motherboard. If they run into something else or there are more than two wires connecting to said power button, you may be out of luck and need to get a hold of a new button before you can turn it back on.
I take no responsibility for any slips and mistakes you should make doing the following, do so at your own discretion and beware of possible damage to yourself or your computer.
I used to work in a shop, and when ever we'd get a desktop with a bad power button, we'd turn it on by opening the tower, tracing the wires from the power button to the two pins on the motherboard said wires plug into, unplugging said wires, and shorting the two pins on the motherboard together for half a second with a screw driver. Naturally, I'll tell you to be careful doing this. I'm not responsible if you short the wrong pins and a)fry your computer or b) fry yourself.
Hope that helps and good luck!
Apr 23, 2014 | Aspire Computers & Internet
Vw jetta 3 clx
Firstly please write in english ,is this a new word meachanic like it refers to a female mechanic of something or am i missing the plot ,because what was the original fault by the derivative meaning of the clutch was slipping or thought it was slipping now a proper trained mechanic would know if the clutch was slipping not just thought it might be slipping was the said vehicle test driven by the mechanic in question or just seen you as a cash cow and changed the clutch because its easy to do and a lot of mark up on the clutch unit without the labour charge involved.No take it back to the alledged mechanic and get him/her to sort it as i think the correct diagnosis wasnt applied to start with in this case.Perhaps a coil pack has gone done or a problem with the fuel whos knows without a drive of the vehicle to determine exactly whats wrong
Dec 05, 2013 | Cars & Trucks
Have a chevy express diesel 3500 it runs good except it sometimes stall while driving and at certain speeds it jerks every now and again
it sounds like the transmission is slipping. you can try a bottle of lucas transmission slip fix but thats more of a band aid. if any fault codes are present check those, could also be a shift solenoid going bad. make sure fluid is at proper level and see if it looks or smells burnt, good sign of a slipping trans is burnt fluid.
Mar 28, 2011 | 2000 Chevrolet 3500
DSC-W150 SteadyShot says turn power on & off & lens pops in/out
I had the same problem with my Sony DSC-W150 camera. It turned out to have an easy fix. At the same time, press the power button and depress the shutter button halfway (the one you snap to take pics) as if you were trying to engage the autofocus without pressing the button down entirely. The lens will attempt to autofucus, which in my case was enough extra power to dislodge whatever debris/sand had clogged the lens. Hope this works for you!
Jun 04, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Get rid of volume bar in middle of screen
I had this same problem a while ago. It was because the top "touch" button on the side was being triggered at a rapid rate. I took mine back to the retailer because it was within the Westinghouse 1 yr warranty. After getting a replacement display (same Westinghouse 22 in), I have had to take it apart because of a bad video processing board. In doing so I have seen that the side buttons are very easy to get to and fiddle with. If you are out of your warranty period, perhaps try taking off the case of the display and fiddling with the button board and connections
Jul 02, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Trans slip when pulling toy hauler
Heat is killing your transmission. Change the transmission oil and filter and slow down. Pulling something that heavy is best with a manual transmission.
Jun 15, 2009 | RTO Automatic Transmission And Engine Oil...
Do i need a differential case and pinion ket or just bearings
if you have limited slip, make sure you have fresh fluid and limited slip additive. does the differential whine or make noise? if so thats a dead giveaway of a bearing or gear problem, look for metal debris or chunks when you pull the diff cover off
May 07, 2009 | 2005 Dodge Ram 3500
Power button has sliped agine agine
Hmmmm, well even if the power button has 'slipped' you should still be able to press it with a pencil to turn it on (even taking off the button and just pressing the button Underneath may help).
Sorry if I don't understand, you might have to elaborate.
Dec 15, 2008 | MPC Computers TransPort GX3 Notebook
Blurry
You may have had a short in the picture tube. When you heard the click the short may have burned itself out. If this is the case it may happen again OR never again? The yoke shouldn't have slipped. They're either bonded or clamped the the neck of the picture tube. All the I've ever seen that have moved from their proper position have messed up the color convergence and the purity of the color. Stargazer
Aug 19, 2007 | Panasonic CT-32SL15 32" TV
Cameras Logo
20 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
