Question about Kenmore 22422 Top Load Washer
Kenmore 70 Series Washer won't spin or drain
Just bought a used Kenmore 70 Series washer and 80 Series dryer. Washer did fine on clothes until the time to drain and spin. No motor sounds, no noises at all coming from machine! This was just moved to my apt., so it was jostled a bit from the move out of one house, the drive and into mine. Please help! Don't have the money for another one or repair costs, but have lots of clothes from a recent move and 2 little ones.
  • sonyamanley Jul 24, 2009
    Control panel? Wirenut? I'm confused.
  • 5,911 Answers
DO NOT by pass a lid switch. It is installed as a designed safety feature to prevent bodily when opening the lid from moving parts. The CORRECT solution is to replace the switch. The following link explains step-by-step how to replace a lid switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
Replacements can be purchased at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com, or repairclinic.com. All these sites offer great service with competitive pricing, so shop all of them for the best deals. The first two web sites have excellent exploded view diagrams of your appliance to aid in parts location and assembly.
If you have any questions about this repair, or if you require additional assistance, please let me know. I hope this helps you.
PS This is not a difficult repair and it doesn't cost much ($25 to $35) on average for a replacement switch. Begin, fisrt by making sure the switch isn't loose or the lid strike (if equipped) isn't broken off. You may not need parts.
Posted on Jul 26, 2009
    President:
  • 744 Answers
Hello, Your problem is going to be with the lid switch, to confirm this trace the wires for the lid switch back to the control panel. In the control panel with a wirenut bypass the lid switch (making sure you unplug the machine before servicing) now plug back in and test...machine working good now? Replace the lid switch :) Good Luck If you have any other questions or concerns please feel free to comment again. Thanks for using Fixya!! Mike
Posted on Jul 24, 2009
  • Mike Price
    Mike Price Jul 24, 2009
    Hello again, If you are confused you have no electrical experiance and should not really be fixing it yourself but will help you further :) the control panel is where the buttons and dials are. You need to access this control panel. Find the lid switch and trace the wires back to this control panel. when you have located the wires and there should be 3 - 2 greys and a ground you should cut the wires at a point where you have some wire to play with and strip the ends on the washer side not the lid switch side. Now twist the wires, put on an electrical wire nut and test...if the machine is working ok then you know you have a bad lid switch..replace it. If this all just flys over your head and you still are not sure what to do get a service guy in..If you can't afford one maybe you know some one who has some electrical experiance? Mike P.s make sure you unplug the washer before servicing :)
  • Mike Price
    Mike Price Aug 02, 2009
    Bypassing the lidswitch is an acceptable way of checking the lid switch is working, as i mentioned you must replace it if you find it to be faulty because it is there for a reason!!
I have a kenmore 70 series washer machine that won't go threw a spin cycle. It has a power and the motor sounds like it wants to work. I just don't see or hear the bin moving. What could be wrong with it and is it repairable for a simple mechanical guy to fix
Posted on Sep 14, 2010
Kenmore Washer 70 series Model #110.22722100 won't spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped.
Feb 25, 2013 | Washing Machines
Our kenmore 80 series (110.27812692) pooped out on us,... the motor and water pump needed replaced, so we bought a used kenmore 70 series (110.82872820) from a friend,... it works fine, but the control...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer(s):
http://www.searspartsdirect.com/partsdirect/index.action
Enter the model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Check the part numbers for both machines in the "Console" section.
Also see the following Whirl[pool Service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Whirlpool top load, washers use one of two different timers. Depending on the timer the knob comes off differently.
For most, by holding the back of the timer shaft with a thin needle nosed pliers, the knob unscrews.
Sep 13, 2010 | Kenmore Washing Machines
Kenmore Series 70 washer, does not spin out the clothes like it used to. Makes a noise it didn't used to. Sounds like a dryer that has clothes with metal buttons on it.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 31, 2010 | Kenmore Washing Machines
Kenmore 80 series spins but won't ring out clothes
Check for buildup of detergent/foaming while washing. Check for oil leaks around the clutch area. Could also be the clutch lining is worn out. Replacement parts kit includes all parts
Mar 06, 2009 | Kenmore 22422 Top Load Washer
Kenmore 82372110 70 series heavy duty plus won't spin
If it drains and won't spin you have to replace the direct drive coupling.
Feb 25, 2009 | Kenmore Washing Machines
Kenmore 70 series
First thing is to remove the 2 screws from the console, they may be hidden in the front or bacl of console. After removing screws, lightly push the base of the console towards the front of the washer and pick up. This will expose your lid switch connection. Using a jumper wire, jump out the black and white wires then try advancing your washer into spin/drain. The culprit will usually be the lid switch assy.
Apr 04, 2008 | Kenmore 24032\24036 Top Load Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
2,941 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
