Question about Roper REX4634KQ Electric Dryer
I have a roper dryer electric model REX4625Ew2. It won't turn on. I suspect a blown fuse. It just stopped running in the middle of a cycle - nothing popped on the circuit breaker. Any ideas?
    President:
  • 1,714 Answers
Probably blew the 'thermal fuse'. it must be replaced
Posted on Jul 24, 2009
Kenmore 600 series dryer won't start. Interior light comes on
Strong possibility your dryer fuse has melted due to a lint buildup in the filter chute of your dryer. Check out my photos of a dryer tuneup I did last summer. ROPER DRYER TUNE UP
SERVICE MANUAL AND MORE PHOTOS
Jun 16, 2012 | Dryers
My roper dryer worked fine yesterday. It won't work today
remove back cover then locate the blower housing in the back,its round on this is a thermal fuse appx. 1" X 1/4" with 2 wires from it,this is the thermal fuse test it,if its open on continuity its bad and the dryer wont operate the pat number is FSR# 3392519
May 21, 2012 | Roper REX3614KW Electric Dryer
I have an admiral electric dryer. It stopped in the middle of a cycle and the light is out and it won't turn on. I checked the fuse box, the plug and the belt is still on, so what do I do now?
Did you test the power outlet with another device...Sometimes a power outlet will fail under the load of a high current appliance like a drier...If the drier runs on 220 volt current...and have circuit breakers instead of fuses...make sure the 220 volt breaker for the dryer is not tripped...If it is tripped...reset it....if not...have a tech to check the outlet. oncee it is established that the drier is getting power and still not working...you may want to get it checked out by service personnel....Hope this was helpful....PEACE.....
Jan 25, 2012 | Admiral Dryers
Roper by Whirlpool
send the model number,
Jan 06, 2012 | Dryers
Dryer won't start
This usually caused by a blown thermal fuse on the blower housing located behind the rear access panel. This thermal fuse is wired in series with the motor and if it blows, power to the motor is terminated and the motor cannot run. No dryer function works when the motor cannot run.
Unplug the dryer or disconnect power then remove the rear access panel. Locate the thermal fuse then bypass it for troubleshooting purposes.
Bypass the thermal fuse by disconnecting the wires and joining it together. Insulate properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
Clean the lint filter and make sure the vent system is not restricted then replace the thermal fuse including the cycling thermostat (thermistor for other models) as a standard operating procedure and preventive measure. The thermal fuse usually cuts out due to a failed cycling thermostat(thermistor for other models).
Jul 19, 2011 | Roper REX3614KW Electric Dryer
Dryer stopped running in the middle of drying cycle. Circuit breaker was checked and reset. The light inside dryer will not turn on when door is open.
check that you have power coming to dryer...check for burnt wires going into cord area...it also could have blown your thermal fuse. its best to have a electrical tester to check componants
Jan 14, 2011 | Maytag Dryers
Dryer just stoped working in the middle of a cycle. won't come back on
you could possibly have a bad doorswitch, tripped circuit breaker in the house, or a blown fuse inside the dryer. by removing the back panel you can take an ohm meter and check the fuses around the heating element or the white fuse if you have one to see if they have continuity. if not replace the fuse. also check the vent hose and vent to make sure the air flow isnt restricted which could cause the dryer to over heat and blow a fuse. Also a broken belt around the drum could cause the dryer to stop and not turn on.
Sep 17, 2009 | Roper REX4634KQ Electric Dryer
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
I ahve a Roper dryer that won't start. It started acting up a few
HI thanks for the question Thts a sure sign of a bad motor, stopping In the middle of a cycle. and then starting again, and now no start replace the motor
Nov 24, 2008 | Roper REX3614KW Electric Dryer
Roper REX4634KQ Electric Dryer Logo
349 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
