Question about Lexmark E220 Laser Printer
All leds blink on a Lexmark E220
Hi, I have been researching and I found out that the cause of all the flashing lights could be the fuser. I pulled and I noticed that the lamp is good. Termoswitch resistance is almost 0. Thermistor also gives me continuity for each wire. Any idea? How can I check that the thermistor is really working? Thanks.
  • 2 more comments
  • igscomp Jul 25, 2009
    Hi, thanks for your answer. I test thermistor as you said and thermistor is ok. When is cold have 215 omhs and when i apply heat, goes to 42... so i think that works propertly. Do you have any idea why all the leds blink? How can i test termoswitch? Thanks.
  • igscomp Jul 28, 2009
    Hi, thanks for your answer. I replace de toner cartridge and the blink problem was resolved, but I have a new one. Now, when a print everything, also check print from printer, all the paper is black... do you know why? Thank you very much.
  • igscomp Aug 03, 2009
    Hi friend. The cartridge is new. Sometimes, all the page is black but not others. I have read that an all black page can be produced by a bad charge roll, what is your opinion? At this moment, the impression is correct but i see some black shadows on one side of paper. I change the position of charge roll and now the shadows are in the other side. So, i think that charge roll is a little broken, is this possible? If you send my and e-mail i can send you an image... thank you very very much.
  • igscomp Aug 29, 2009
    Hi, i change charger roller and now problem is resolved, thanks!
    President:
  • 3,085 Answers
Thermistors work differently than resistors.
When you apply heat, the resistance goes DOWN. When cold, you should measure high resistance.
Test with a hair dryer.
Posted on Jul 25, 2009
  • Leroy Elliott
    Leroy Elliott Jul 25, 2009
    With the thermoswitch. They are usually just secewed to the base of the fuser. It may be open. You should have continuity through it when it's cool.
    If not, throw it down hard on a wood floor, this usually resets the bi-metal elements inside.
    I'm sure you have confirmed no jams and not out of toner.
    Good luck.
  • Leroy Elliott
    Leroy Elliott Jul 28, 2009
    Bad toner cartridge. Charge wire probably broken.
Panasonic th 42pu30a when i go to turn tv on the light flashes green then no light and no picture just a black screen
The led that is flashing is probably a trouble code indicator. Count how many times it flashes, then research the blink codes for your model and the number of flashes.
Aug 13, 2014 | Televison & Video
Error p1500
The printers first error code show all lights flashing:
Flashing Ready'Data
Flashing Toner Low
Flashing Load'Remove Paper
Flashing Paper Jam
Flashing Error
Flashing Press Continue
By pressing continue twice to get to second error codes the lights show:
Flashing Ready'Data
Off Toner Low
Flashing Paper Jam
Flashing Error
Pressing continue twice more shows:
Off Ready'Data
Flashing Toner Low
Off Load'Remove Paper
Off Paper Jam
Off Error
Off Press Continue
Pressing continue twice more brings back to all lights flashing
The computers ( I have tired more than one with diff USB and A parallel cables) do not see the printer as being attached. My toner is half full. I checked the internal power board in base of printer and the fuse is good. The error should not have anything to do with being connected to a computer or not because when it was working and not connect to a computer it would not blink all the indicator lights (If I remember correctly, just the Press Continue light would be lite).
Information I have found so far:
  1. http://support.dell.com/support/edocs/systems/p1500/en/index.htm#online_documentation
o Under PDF Documents Owner's Manual(English) (.pdf) (1.33 MB) shows very little about the indicator lights.
o Under HTML Documents User's Guide shows more information about the indicator lights but mentions nothing about the secondary error codes.
  1. The Lexmark E321/E323/E220 are very close cousins to the P1500 and on Lexmark's website the manuals have more info on secondary codes but nothing that matches my error.
Information I am guessing could be the problem:
  1. The fuser has gone out (need to know how to check) Why else would they sell the fuser if it didn't go out regularly Part Number: 56P1053
  2. Clutch Assembly I'm not sure of the accuracy of the info on this page.
Mar 12, 2014 | Canon Office Equipment & Supplies
Lexmark e322 all lights flashing
When a Service error occurs, all 6 LEDs will blink. Please click the link below for troubleshooting guidelines.
http://bitly.com/nRG8mI
If you need further assistance please contact Lexmark Technical Support.
Oct 07, 2011 | Lexmark E322 Laser Printer
I have a c920 lexmark with a fault code 920.000. my guess is that the fuserisnt heating up... based on the fact that its not getting hot... im guessing the fuser lamp has blown.... is there any other...
Hi, Majorly this Error 920.X display for a cold fuser. Some 920.xx error codes may be cleared by turning the printer on and off.
In general, fuser errors require replacement of the fuser. Fuser errors can be from a cold fuser or an overheated fuser. In your case you need to replace the Fuser.
Feb 22, 2010 | Lexmark C920 Led Printer
New fuser - do I need to reset
If all the leds are fast blinking, you have a fatal error.
Most likely something has been overlooked during re assembly (forgotten connector maybe ?) as there is no need to reset the fuser.
Oct 07, 2008 | OKI B4400 Digital Mono Printer - Black
42PF7321D/37 LED Light Blinking RED
my dad had this happen too. after some research, we found out that there are two capacitors on the power supply board right next to the connector for the main logic board that went bad. you can just pull those out and solder in new ones, and it works like new again! i found a repair kit on ebay for $35 including shipping, and that's all it took!
Jul 17, 2008 | Televison & Video
Blinks twice pause blinks 4 times
SYMPTOMS
Dead or Shutdown symptoms.
RESOLUTION
Dead symptom reported to be caused by the following:
1. Dead.
Found Q601 & Q602 shorted, R615 open, and IC600 on the A Board were the cause of the symptom.
2. Dead.
Found D614, Zener diode, on B+ line was shorted.
3. Set shutdown and the standby LED blinks 3 then 5 times.
Found 200v line was low. Disconnected CN706 on the C Board and found 200v now
present on CN706/pin 7.
Found: IC702 (C board) shorted the 200 volt line.
HQ Comments: C541 on the A Board could become defective if the 200v line is shorted since
the polarity on the capacitor will become reversed. R553 fuse resistor could also be opened
on the A Board.
4. Error code of 4 blinks .
Dead set press power button you hear the relay and you see red led flash 3 times and stops? Has no HV or other action. Tech removed the back as no 200 volt supply, did unplug CN706 and now has 200volts. Tech did remove the IC702 and same it comes up so needs this IC.
5. Dead. 5 blinks then 3 blinks. Found shorted Damper diode D504. Q502 has a built in damper, as well.
6. The TV does not turn On and the LED flashers 9 times.
Found one side of R610 open on the Base of Q690 on the A board.
7. Dead, 9 flashes, Q606
Would not start when cold, has stand by 5 but relay never energize.
No response from front panel or remote controls.
9 blinks is not in service manual.
Found Q606 (Zero Det.), on the A Board, had no soldered on the collector
of the transistor causing an intermittent connection.
Soldered the collector of Q606 and set returned to operation.
HQ Comments: Also refer to E30968554.
8. Dead. 5 blinks or 3 blinks
Found on the A Board D611 in the Power Supply open, and Hor. Output Q502 shorted.
9. Found Power Supply components D611 shorted causing Q600, Q601, and R615
to fail on the A Board.
10. No picture or sound. Standby flashes.
Found Q512 (Pin Out) shorted. on the A Board.
11. Dead. No sound or picture.
Found the FBT and Q502 were shorted, and R615 open on the A Board.
12. Dead
No power, Stand by light flashes 4 times.
Found T604 and IC601, replaced.
Found D611 on the A Board was the cause of the symptom.
13. Dead.
Found D534 shorted on the A Board.
14. Shutdown 4 Blinks.
Replacing R595, OCP Latch Q532 on the A Board, fixed the set.
PN 1-247-891-00, 330K 1/4 watt.
15. Unit shuts down after 15 mins.
Immediate shutdown - sometimes it give a 3 blink, sometimes nothing.
Found R595 (330K) was open located in the Q532 OCP Latch circuit.
R595 P/N 124789100 330k 1/4w
16. Won't power up. LED Blinks 4 times, B+ is very low
B+ is at 49V, +15/-15 only coming up to about 1 volt.
Wth Hor Out disconnected B+ only comes up to 50v.
17. Intermittently does not turn on
Found a intermittent C633 on pin # 3 of IC600.
C663 P/N 113647911 Film cap .001uf 100v
Billy
If you need the service manual contact me at:billyjones@fletchersite.com
Jan 27, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Toner light blinks and error light shows
1- you either got a bad toner ( the chip on it is telling it it is bad)
happens sometimes with recycled toners.
Return it and tell them it is defective.
The chip needs to be replaced.
Try this but doubt it will work,
open front door hold down go button, all lights will flash in sequence wait for it to stop turn off and on and close door.
Oct 24, 2007 | Lexmark E220 Laser Printer
Initializing problem
Possible problems are
1- there is a paper that has not been removed and is sitting on a sensor. ( most likely the fuseropen and loofrom both sides of where the paper is supposed to came out
2-fuser is gone and needs to be replaced
if there are no paper jams, then the most likely thing is the fuser ( where it come out) is not turning on and getting HOT)
replace fuser ( not for the novice) scale of 1-10 this is a 7-8
Oct 01, 2007 | Lexmark E220 Laser Printer
Lexmark E220 Laser Printer Logo
378 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
