SOURCE: getting misfire codes for cyl.
it is your fuel injectors, replace them, and the problem will be solved..
SOURCE: 4 cyl. won't start,new plugs, wires,cap,etc.
a crank sensor tells the coil to fire.are you getting a signal at the coil to fire?
SOURCE: Only when it rains, I get an engine misfire and the check
i had the same problem with my truck...(i have a 99 silverado 4.3L also) i took off the cap, cleaned all of the electrical areas on the inside of the cap and rotor....and put a small thin layor of die electric grease on it all....then before i put the cap back on...i ran a bead of silicone around the cap surface that seats to the distributor...and i havent had a problem for the month that i have done that......hope this helps!
SOURCE: vehicle misfire... diagnostic code is 1351
Code 1351 is for the ignition control module.Ignition control circuit high.This module is on the same bracket as the coil.Before you buy a new one.Try a salvage yard and get a used one.
the codes r po301-302-303-304-300 is a multi misfire
Check fuel--spark--compression?
