Question about Garden
Spary a little startingfluid in carb to see if it start if it start rebuild carb.to change fuel line
only if there dryrotted if it go thourght the gastank in little hold cut new line on a angle and thread through hold.hope helps you.let me know ok
Posted on Jul 25, 2009
SOURCE: i need the fuel/oil mixture
The fuel/oil mixture is 40:1. That is 3.2 oz. oil/US gallon. Now for the fuel lines:
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
Posted on Jan 11, 2011
Jul 24, 2011 | Tools & Hardware - Others
Oct 19, 2009 | Husqvarna 28cc Gas Line Trimmer
Oct 13, 2009 | Garden
Sep 05, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Aug 01, 2009 | Ryobi Garden
Jul 17, 2009 | Garden
Jul 16, 2009 | Ryobi Garden
Jun 10, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
May 22, 2009 | Ryobi Garden
Apr 30, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Apr 25, 2018 | Electric Garden
Apr 25, 2018 | Garden
1,624 people viewed this question
