Question about Monarch 9855 Thermal Printer
Monarch 9850 Error code 04 and 101
I am trying to print a small custom label from Loftware to a Monarch 9850 attached locally. I get errors 04 and 101. Sometimes I can get the 04 error to go away, but not the 101. Any ideas? I'm stuck!
  • jason_sipos Jul 24, 2009
    How do I fix the data length error and format error? I don't seem to be able to get the format in memory and I'm not sure how to manipulate teh data length.
  • 1,555 Answers
Meaning of errors
You are getting error 004 because of Supply length is invalid i.e. the data length which you are sending to your printer is not valid and system is ignoring it. You are getting error 101 because format referenced by the batch is not available in the memory.
For your future reference
http://choiceprinters.com/other/Monarch/9830/me9830en.pdf
Here is your printers manual download it and keep it with you for checking out future errors if any.
Solution
For providing best solution I require to know What is your operating system and which application you are using to give the print command or what media you are using to give command.
Posted on Jul 24, 2009
  • Aruna Singh
    Aruna Singh Jul 24, 2009
    Sorry for the delay, fixya froze my premiums for few minutes. Here is your solution just download this software install it and use it for future label printing. You shall choose driver for your own OS and printer 2nd one is for you.
    http://www.technoriversoft.com/downloadd...
How do I fix error 571 on my 9800 monarch ticket machine using my loftware 32 design ticket?
If you are getting error 571 from Nebraska Book Company's WinPrism inventory control system, File --> System Settings --> set the Receipt Type to 8-1/2 X 11. It seems irrelevant but it works.
Another possible resolution to the problem is to remove the Windows (XP, 7, 8, 10) profile of the offending user:
0. Login as the offending user and backup anything they want to keep, like browser bookmarks/favorite or documents on the desktop.
1. Log into Windows as a local administrator.
2. Control Panel --> User Accounts --> select the offending user --> Remove.
3. Restart.
4. Log into Windows as a local administrator.
5. Delete C:\Users\offending_user
6. The following is necessary to avoid a "temporary profile" error: Regedit.exe HKEY_LOCAL_MACHINE --> Software --> Microsoft --> Windows NT --> Current Version --> ProfileList --> select each entry until you find the one with a ProfileImagePath of C:\Users\offending_user and delete it.
7. Control Panel --> User Accounts --> add the user.
8. Login as the offending user, add the printer, and now it should work.
Jun 15, 2012 | Office Equipment & Supplies
Im useing the monarch paxar 9800 and, I have an error code its 909 what can i do
A 909 error is a control board failure code.
Either the battery on the main control board needs to be replaced, or the whole board itself needs to be replaced.
You can't clear the error yourself...
Aug 30, 2010 | Paxar Monarch 9850 Thermal Printer
I am using a Monarch 9850. We do not print much with it - maybe 10 or 15 thousand misc sizes labels a year. It does not print dark enough. I am printing black ribbon. I have changed ribbons three or four...
I would suggest an update on your printers firmware after which it will perform a calibration procedure. please check here for for further guide on update information
Apr 08, 2010 | Paxar Monarch 9850 Thermal Printer
Monarch Paxar 9855 Printing Errors
can you try a serial connection, what type of operating system are you using?
Aug 07, 2009 | Monarch 9855 Thermal Printer
Paxar 9855 print error
You have a format problem. Something isn't correct in your mpcl code.
Error 400 - "The character immediately following { is invalid or not an ASCII character."
Jun 01, 2009 | Monarch 9855 Thermal Printer
Problem to print label when Monarch is installed on network
101 : The format referenced by batch isn't in memory. (Try rebooting printer or closing/opening software)
005: Supply width is invalid. (Check your format data)
May 29, 2009 | Monarch 9855 Thermal Printer
How do you speed up he printing speed on a Paxar 9800/9850?
Are you printing a serial or parallel barcode? If you don't know, a serial barcode looks like a ladder as it prints out on the label. A parallel barcode looks like a picket fence. A serial barcode (ladder) prints at 2.5 ips by default. You can't increase the speed. If you're printing a parallel barcode (picket fence) you must hit "enter' once you adjust the speed setting in the printer menu. If you've done that and it still won't increase speed, then the speed is set by the software itself, and overrides any changes you make in the printer menu. The speed adjustment must then be made in the software, not the printer.
Apr 08, 2009 | Paxar Monarch 9850 Thermal Printer
Error 409 Memory full on Monarch 9850 printer
409 is a memory full error, so if you have reset the printer, then your memory should be "flushed". You may also have an incorrect flow control, so when you send too much data to the printer, you can get a 409.
Not knowing which your issue could be, try calling the company's support number 1-800-543-6650.
Mar 19, 2009 | Monarch 9850 TABLETOP PRINTER
I work in a lab and we use a monarch paxar 9825 label printer and this morning it has an error code 400. What is this error code?
These types of errors are data errors. If you post your datastream, I may be able to tell you where the error is at.
Dec 11, 2008 | Paxar Monarch 9825 Thermal Label Printer
Monarch 9855 Thermal Printer Logo
760 people viewed this question
Top Monarch Office Equipment & Supplies Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
David Payne
David Payne
ka4iup
ka4iup
Are you a Monarch Office Equipment and Supply Expert? Answer questions, earn points and help others
