Question about Dyson Vacuums
While cleaning I got water in Dyson Animal now only runs a few seconds
    Habit-Forming:
    New Friend:
  • 108 Answers
Try hanging upside down in a warm place.if water has entered motor it may have to be replaced.motors for dysons are actually very cheap (uk £10/20 max) if u have the expertise to change it.youtube has step by step how to s.if "professional" is only option buy a second hand one off internet be cheaper than repair.dyson motors are not longest lasting motors ive found but cheap to replace
Posted on Apr 18, 2017
  • John F Pennett
    John F Pennett Apr 19, 2017
    I did that and it seems to be running well again. Thanks.
  • John F Pennett
    end
  • 61 Answers
SOURCE: Dyson Animal DC14 brush will not rotate. Removed
If this model takes a clutch then it is stripped and needs to be replaced.
Posted on Apr 15, 2009
rustysheriff
  • 344 Answers
SOURCE: Dyson cleaner keeps cutting out, no blockage found, filter clean.
1. Check the on/off button these can also be troublesome and if you've stood on the cable once or twice you could have a break in the wire and it's shorting, check by turning on and wiggle cable around where it enters machine.
2. Faulty thermocouple, it is held in a white plastic housing screwed with one T15 torx screw to the motor housing. You could replace it but I just shorted mine with some wire and it hasn't failed since and more importantly not caught fire yet!
Posted on May 28, 2009
  • 83 Answers
SOURCE: Dyson Animal 17 - brush stopped turning
The belt will stop itself from spinning if you accidentally picked up a shoestring or vacuumed the edged of a carpet and the carpet got caught. To have the brush spinning again, simply step on the front of the machine, pull back the handle, turn the machine on with the red power button and press the gray button next to the red button - that's the ON/OFF button for the brushbar. If it doesn't spin, press and hold the button down for 10 seconds. If it still doesn't work, call the Dyson helpline, they'll have you open up the cleaner and inspect the belt and brushbar motor and if all else fails, they'll refer you to a local repair dealer in your area to fix it.
Posted on Jul 30, 2009
VacuumRepair
  • 438 Answers
SOURCE: dyson dc07 animal\ no suction
There could be a few things that would cause your Dyson to have no suction. I will give you detailed step by step instructions along with pictures on how you can diagnose this.
Possible Problem #1. The first problem is extremely common. In fact, we probably see between 2-3 of these problems every week. It mostly happens after people take the bottom plate off the vacuum in order to clean the roller brush. What happens is when they reinstall the bottom plate, they put it on on incorrectly. It's actually very easy to do. When the bottom plate (soleplate) is installed wrong, there will be a gap between the bottom plate, and the agitator housing, or the purple tray the roller brush sits in. This will cause the soleplate to be a few inches higher off the ground then it should be, preventing the brushes from even hitting the carpet. This makes it seem to the user that vacuum has lost suction power because without the brushes hitting the carpet, the machine will not pick up very well on floors, but when they use the attachment hose there's plenty of suction power.
Here's a picture of the WRONG way to install the bottom plate. Notice the gap in between the two housings:
Here's another picture, that is the RIGHT way to install the soleplate:
I would say probably 6 times out of 10 this is the problem with the customers machine. If you checked the soleplate and it is installed correctly, move on to the second possible problem.
Possible Problem # 2. Turn the vacuum cleaner upside down so the brush roller is facing upwards. I found the easiest way to work on it is to put it on a counter top or work bench. On the left hand side behind the roller brush you should see a flexible transparent hose that goes from the motor to the agitator housing. This hose actually has a lot of strain on it when the vacuum cleaner is in the reclined position. When the first few series of Dyson DC07 models came out, they didn't make this hose long enough, so when the vacuum was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually right where the end of the hose that goes into the agitator housing. Examine your hose and see if you have any visible cracks in this hose. If you need to you may just remove the entire hose assembly by pulling on it. It will easily come right out of the machine so you can inspect it better. Here's a picture of where the hose usually cracks:
This would also explain why the vacuum works fine when using the attachments, but not on the floors. The attachment hose uses a different suction channel, and when the machine is in the upright position, no suction goes through this hose. If you do find a crack in this hose, the this hose needs to be replaced. Here's a direct link to that hose on our GoVacuum website.
Dyson DC-07 & DC-14 Upright Replacement Internal Hose Part # 904219
Possible Problem #3. I would suspect that this may not be the problem, but if neither of the solutions above worked, then try this one. Dyson's in general are prone to clogging. There are a few clog ports throughout the vacuum cleaner that were added there due to Dyson prototypes becoming clogged at these points. Here are pictures of how and where to check for these clogs. Simply remove the suction port covers at both of these locations:
Possible Problem #4. If none of the above solutions worked for you, try this last one. The Dyson DC07 models use a clutch mechanism that stops the roller brush from spinning when changed from carpet mode to bare floor mode. This clutch mechanism is a notorious problem with all Dyson models, in fact they were such a problem that Dyson had to redesign the DC07 model to a non-clutch system. Even if yours is one of the newer ones that don't use a clutch, yours still has a belt inside. You can tell if your model uses a clutch or not by the shape of the roller brush. If your brush is a perfect cylinder shape, yours does NOT have a clutch. To check and see if the clutch or the belt have gone bad, first release the handle on the vacuum as if you were vacuuming carpets. Make sure the machine is set to carpet mode. Now while the handle has been released, turn the machine upside down and see if the brushes are spinning. If the brushes are spinning then turn the vacuum right side up and put the brushes on the floor. Can you still hear the brushes spinning when they are hitting the carpet? If yes, then this is not the problem. If the brushes however are NOT spinning, this indicates either your brush roll, clutch, or belt have gone bad.
If these solutions still didn't fix your problem, I'd be happy to try and help you further. Just use the Clarification Request, or comment section here on the Fixya repair page.
If this repair was helpful to you, please be sure to rate this repair as helpful by clicking the thumbs up icons in the top right hand corner of the repair. Thanks so much!
Chris J.
GoVacuum
Posted on Apr 04, 2010
  • 3 Answers
SOURCE: Dyson Animal clogged
you just grab it and throw it away
Posted on Feb 12, 2011
Dyson V6 animal powerhead starts and stops does not run continuously
Hello, this is Ava with Think Crucial.
There are a number of reasons why your Dyson cleaner is pulsating off and on. First, it maybe due to a battery of the cleaner. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson+v6
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Nov 24, 2016 | Dyson V6 Animal Bagless Cordless Stick Vac
My dyson animal runs for a few and then shuts off I have cleaned the filters any other suggestions
Put the 'carpet, floor' selector switch on 'floor' . With the machine unplugged and turned over on it's face, sense how much pressure there is on the 'brush roller', to turn. Check how much hair there may be in the hinge areas on the ends. That's' my guess.
Dec 21, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
My handheld dyson is not working - initially it was cutting out after only a few mins then seconds now it won't work at all despite showing green light ??
Hi there, it's Jack at Dyson.
I'm sorry to hear your DC31 Animal is only working intermittently. When fully charged, this machine should have a maximum runtime of 10 minutes, or 6 minutes on the maximum power setting.
There are several factors which could cause this, and to determine what's at fault we'd need to take you through some quick diagnostic checks when you have your machine to hand. The machine would also need to be fully charged, so please make sure it's had 3.5 hours to recharge before calling us.
You can reach our freephone customer Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US). Our experts will be happy to help further.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Apr 07, 2013 | Dyson DC31 Animal Bagless Handheld...
Cleaning the filter
Hi, If you wash it, just run the water through it, squeeze it out and leave in the sun/near a radiator.
Once its dry its safe to put back in.
If you visit http://www.sparesaver.com/help-and-support/dyson-section/dyson-technical-advice-450/ they have alot of info on repairing dyson cleaners AND they sell the parts, cheapest ive seen online.
Hope that helps
Jun 12, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Whats proper cleaning maintenance for the dyson Dc07 animal
use water cleaning Hose Assy and Wand Assy and Pre-filter Assy and cleaning Cyclone Assy
Nov 15, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuums Logo
57 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
