Question about Craftsman Drills
CaN'T REMOVE A 1/2'' CHUCK FROM A 13'' FLOOR MODEL CRAFTSMAN DRILL
HOW DO I REMOVE A BAD CHUCK FROM A 1/2'' CRAFTSMAN FLOOR MODEL DRILL PRESS. I'VE TRIED EVERYTHING BUT A CUTTING TORCH.
    President:
  • 1,723 Answers
Try heating it up with a torch and tapping it off with a punch
Posted on Jul 24, 2009
How do i remove a keyless chuck from a Craftsman 19.2 volt 2-speed drill
Inside the chuck you will find a screw (probably torx) this is a left hand screw (Remove clockwise)
Insert a 1/2" allen key into the chuck and using a hammer strike it to spin the chuck off (Standard thread - Counter-clockwise)
Mar 09, 2015 | Craftsman Drills
How to remove drill chuck
Funny, I just did it 2 days ago on a similar machine. Easy: be sensible and gentle. Unscrew the block from the pole, and rest is firmly on the floor head down, chuck up. Tighten the chuck fully, as for a 0.0 mm drill bit. Then pull hard on the main axis with 1 hand (hold the chuck). With the other one tap gently at the tip of the chuck with a hammer, 2x to the right, 2x to the left, repeat and insist, and always gently tapping perpendicularly to the axis. Reason: The axis and the chuck have a slightly conical shape.
Aug 17, 2014 | Craftsman Drills
113.24520 chuck replacement
most drill press chucks are installed and locked on by a male / female taper fit. Tap chuck assy. downward with a soft hammer to remove. install new chuck tapping it upward.
Oct 28, 2013 | Craftsman sears 15" 1/2 Heavy Duty Drill...
I want to put a taping head on my drill press. What is the spindle size of a craftsman 12" drill press?
without the model number I am going to guess that as a general rule most smaller drill presses are a #2 morse taper socket and a #2 jacobs taper arbor (where the chuck presses on) you should have been supplied a knockout pin to remove the chuck assembly from the internal socket.
Apr 15, 2011 | Craftsman 12" Drill Press (21914)
Craftsman Model #315.271690 3/8 Professional Electric Drill (corded). What are the specifications (dia, threads per inch, etc.) of the left hand thread machine screw that holds the chuck on. The Sears...
How do you remove the chuck from a Craftsman Model #315.11441 3/8 vsr corded drill? Am trying to remove the chuck but I believe there is some type of a set screw or locking mechanism that needs to be undone. I can see a slotted screw head in the chuck Looking straight down on it but it is very tight and I don't want to break it or a screwdriver forcing it. Thanks for input. Bob
Sep 06, 2010 | Craftsman Drills
The chuck on my craftsman 8" drill press wobbles. How can I stop it from wobbling?? Can I get a manual for my drill. thanks. billybee3@yahoo.com
There are a couple of different ways that drill chucks are attached on smaller tools. You didn't specify the model, so I can't help much. But here is a link to where you can usually find manuals for Craftsman. If the press is not too old, you will probably be able to find the manual here.
http://www.searspartsdirect.com/partsdirect/index.action
Feb 25, 2010 | Craftsman Drills
I have a model 1689 drill press with a 33 taper jacobs chuck I need to remove the chuck to put a larger chuck on is the smaller chuck threaded on and if it is, is it RH or LH thread and how do you hold the...
you dont hold it, the chuck is a taper fit and you would need wedges to remove it. the newer chuck would also have to have the same taper to work. if replacing the new chuck you would need to make sure the parts are clean, use a brake cleaner and a paper towel to clean them and then they would press together. Let me know if you still need more assistance.
Jan 13, 2010 | Speed Clausing 15" Variable Floor Model...
Remove and replace the chuck
Most drill press chucks are held on with a screw. Open the chuck all the way. Look inside the chuck, there should be a screw in the bottom. Some are left hand threads, some are not. Good Luck
May 28, 2009 | Drills
Replace drill chuck on 23 year old Craftsman 8" drill press
Yes it does have a Morse taper and you can remove it by gently hitting it with a rubber or nylon mallet.
Feb 08, 2009 | Craftsman 4" Drill Press Vise, Side -...
Drills Logo
238 people viewed this question
Top Craftsman Drills Experts
Tim Venetis
Tom Chichester
Are you a Craftsman Drill Expert? Answer questions, earn points and help others
